Old Feb 10, 2013, 03:27 PM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Thanks Jim.
It seems "just spraying" the ESCs with Cx has not been enough.
The ones I'm installing now have been soaked over night then sealed around the heatsinks and shrinkwrap with heat conductive silicone
Kev
Berkie is offline Find More Posts by Berkie
Old Feb 10, 2013, 03:59 PM
dav3uk is online now
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Originally Posted by Berkie View Post
Thanks Jim.
Kev
Sounds like a good plan
Dave
dav3uk is online now Find More Posts by dav3uk
Old Feb 10, 2013, 08:09 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
I put a firewall in mine, however I just glued them to the existing surface. I've only run mine on snow so far, so I don't have any issues with corrosion. I've put my ESCs in the fuselage anyways.
I'm running these motors in mine, I've had very good experience with RC Timer motors, these pull just under 300W together both with the stock props and APC 8X4 SF.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Feb 10, 2013, 08:29 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Nicely done!
I can see how the firewalls would keep out the water.
Have you done enough flights with her though to confirm ESCs in the fus. are not overheating? Do you use heatsinks on them?
Kev
Old Feb 10, 2013, 08:50 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Kev
Well, they're 40A ESCs and each motor is pulling only about 15A, plus I've never flown it when it's been warmer than -5C so it really hasn't been a concern yet. I'll let you know in May...
Site Sponsor
Old Feb 10, 2013, 10:59 PM
parkcityskier is offline
Find More Posts by parkcityskier
Parkcityflier
parkcityskier's Avatar
Park City, UT, USA
Joined Aug 2001
Nicely done!
Kev
Just so that you understand my motor/ESC setup, I made the chin scoops functional by hollowing them out. I did this to aid in ESC cooling as I felt that the firewall could hinder some airflow through the nacelle. So, it is probably likely that I do, in fact, get some water passing through the nacelles, too, and over the ESCs but since I have treated the ESCs with the CX as described I have had no problems with over 100 flights on the plane, and often in very choppy water, which this plane handles very well. Good luck with yours.
Jim
parkcityskier is offline Find More Posts by parkcityskier
Old Feb 13, 2013, 12:17 AM
Griphin is online now
Find More Posts by Griphin
Griphin's Avatar
Joined Mar 2012
I've cut off the front of the nacelle to make a removable cowling for access to the motors. Works simple and use magnets to hold it on.
I think I'm going to have to put in a firewall to put in X mounted motors too.
Griphin is online now Find More Posts by Griphin
Old Feb 13, 2013, 03:20 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Jim
Thanks Jim
Kev
Old Feb 16, 2013, 07:19 PM
flying jeep is offline
Find More Posts by flying jeep
Brownsburg, Indiana
Joined Aug 2005
I went with the idea from an earlier post of cutting off the front of the nacelle and mounting a firewall. Then glueing the nacelle nose back on. I measured the motor from mount base to back of the prop. Then I added the thickness of the
1/8" ply firewall, and then I added about 1/8" for prop clearance. Turns out that measurement is exactly the same as the top of a Testers spray paint can top in this particular case. I then took my razor saw and held it down flat on the paint can top. The I took the nacelle and held it down nose first to the bench while sawing all the way around holding the saw to the paint can top. The results were perfect. I did mark each pair A's and B's so I don't get them mixed up. Then I hollowed out the nose section of each one. Then I took each nose section and traced the inside on 1/8" ply to make my firewall. I left a section open at the top for the wires. Once again I marked them A and B. This way the nacelle front will sit around the firewall and match up to the rear without making a firewall ply "sandwitch" in between. Now I have to decide if the speed controllers will be in the nacelles or the fuselage.
flying jeep is offline Find More Posts by flying jeep
Old Mar 02, 2013, 10:27 AM
robusp is offline
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
Finished mine today. Got a coat of minwax on a whole plane and filament tape on bottom of fuse.
I went with esc's in fuse, motors on stick mounts. Cut away more than a half of water rudder.
Had a hard time to get CG in the right spot, until I moved the esc's way forward.
I will maiden her today on snow. Will let you know how it worked.
Rob
robusp is offline Find More Posts by robusp
Old Mar 02, 2013, 04:36 PM
robusp is offline
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
Maiden was good.
I was surprised, how easy it was to taxi on the ground. I was afraid, problem would be with it leaning to one side, but soonest it started moving it leveled of and stayed that way.
It flies slow extremely well and that's big plus.
I am planning on flying it in the summer in the same pond we have sailboat regattas and the place is rather small.
Steering on the ground is good too. It helps I have rudder mixed with throttle and the motors are on separate channels.
With 1600kV cd-rom motors and 6x4 props it has plenty of power, but nothing extreme. I flew two 2200mAh packs for 7 min each.
I only wish it wasn't made from eps.
Rob
Old Mar 02, 2013, 04:53 PM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Originally Posted by robusp View Post
Maiden was good.
Rob
congrat i really like the color sheme... nice spinner !
also agree with easy ground handling using differential
throttle...
any video ?
CL415 fpv (0 min 48 sec)
ggtronic is offline Find More Posts by ggtronic
Old Mar 02, 2013, 05:10 PM
robusp is offline
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
Color scheme might be nice, but I bet you didn't see the white one up close.
Awful chalky white paint. Its better now, after a coat of minwax.
No no video. Too cold as it is. (it was 25F)
Rob
Old Mar 02, 2013, 06:51 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Rob
Wow! What a great finish to her!
A $35 kit that looks a million $$'s
Kev
Old Mar 02, 2013, 07:07 PM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Finished mine today. Got a coat of minwax on a whole plane and filament tape on bottom of fuse.Rob
minwax ? can you gave us a link ?
i was looking for a light clear glase in the past : WellBound... not so good
you may have found something good for us...
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
