Old Dec 15, 2012, 05:04 PM
wmcneal is offline
Find More Posts by wmcneal
AMA 125691
wmcneal's Avatar
Jacksonville Florida
Joined Jul 2002
Video and a few static pics on the pond
Flew it off the pond again today. Finally got some video.
Hobbyking Guanli RC Canadair CL-415 on the pond (5 min 25 sec)
wmcneal is offline Find More Posts by wmcneal
Old Jan 18, 2013, 06:58 PM
flying jeep is offline
Find More Posts by flying jeep
Brownsburg, Indiana
Joined Aug 2005
I'm not having any luck with Heads Up RC on the motors or mounts. I was looking for the recommended 2410-12t motors and aluminum mounts. Anywhere else I can look?
flying jeep is offline Find More Posts by flying jeep
Old Jan 18, 2013, 09:40 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
This mount and motor should be acceptable alternatives if the stock stick mount is used.
http://www.hobbyking.com/hobbyking/s...idproduct=3613
http://www.hobbyking.com/hobbyking/s...dproduct=18546
Both are listed as in stock
Ken
kensp is offline Find More Posts by kensp
Old Jan 19, 2013, 04:23 PM
Brownsburg, Indiana
Joined Aug 2005
Ken
Ken, about what amp controllers? 20A? Or should I go 30A just in case they get hot? And yes, it looks like both are still in stock! I should get an order in tonight. I wonder if I should get servos now as well? I'll probably get the reciever locally. This 2.4 Spektrum I bought is all new to me. I may need help from my LHS.
Jay
How do you use that adapter on that motor? Does the flat mount come off the motor and the adapter clamp to the back of the motor?
Old Jan 19, 2013, 04:34 PM
Ramblin is offline
Find More Posts by Ramblin
Canada, ON, Carleton Place
Joined Jun 2011
I am getting ready to order this airplane but will be traveling in a small car. Can anyone give me the dimensions of the shipping carton?
Ramblin is offline Find More Posts by Ramblin
Old Jan 19, 2013, 04:45 PM
Brownsburg, Indiana
Joined Aug 2005
Mine just showed up in a box 11"x12"x36". And very well packed. Double boxed as well.
Jay
Old Jan 19, 2013, 05:56 PM
Ramblin is offline
Joined Jun 2011
Jay
That will be no problem.
Old Jan 19, 2013, 05:58 PM
Ramblin is offline
Joined Jun 2011
I am all set to order and now I cannot find the orange version, just the red and white. Does anyone have info on this?
Old Jan 19, 2013, 08:03 PM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
I went for the red and white , I wanted the yellow too.
jmolwitz is offline Find More Posts by jmolwitz
Old Jan 19, 2013, 08:29 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Jay
I used the older motors on my CL-415 and a pair of 12 Amp ESCs . If I remember right my motors each drew around 8 amps when fitted with 9 x 5 propellers. I had more than enough power to fly the CL-415.
The round mount is removed and the new mount is slipped over the tube projecting from the rear of the motor and tightened. Th square part of the motor mount is then slipped over the Motor mounting stick and , after adjusting fo the motor lengt a screw is placed trough the mount into the wooden stick.
Ken
Old Jan 19, 2013, 08:41 PM
Brownsburg, Indiana
Joined Aug 2005
Ken
Without looking at the specs again, I thought that motor pulled 14amps. I've never used that type of motor before, but it makes sense to mount it either way depending on the situation and mount.
Jay
Old Jan 20, 2013, 05:51 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Jay
Unfortunately the specs only state the maximum amps that can be drawn before the motor is damaged. They do not state the Amps drawn with a particular propeller and battery pack. Maybe someone has carried out propeller tests using this motor.
Ken
Old Jan 20, 2013, 08:37 PM
Ramblin is offline
Joined Jun 2011
I won't be able to fly it until spring so I'll wait for a while. Hope it is just out of stock and not discontinued.
Old Jan 21, 2013, 07:45 PM
Brownsburg, Indiana
Joined Aug 2005
Ken
I bit the bullet last night and ordered the motors and 20amp controllers as well as servos and props. Now all I have to do is wait for the China Express to show up and deliver my parts!
Old Jan 22, 2013, 01:08 AM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Ken
I have just purchase the following items for testing. I want to know if this motor is suitable for replacing my current motors that are no longer available.If they are then I will buy several for spares.
http://www.hobbyking.com/hobbyking/s...dProduct=18546
http://www.hobbyking.com/hobbyking/s...idProduct=2161
http://www.hobbyking.com/hobbyking/s...idProduct=3613 This ESC has a burst current of 15 Amps.
The items will take about two weeks to arrive at my home and once i test them I will post the results.
The wet season has arrived and the local billabongs (ponds) are quickly filling with water, so I do not want any delays during the limited time of our wet season.
Ken
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
