Old Sep 23, 2012, 12:30 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Originally Posted by KTL13 View Post
I did a test and I am pulling 24 amps and 240 watts on full throttle. Running 8x6x3 props. A 2200mah battery sure doesnt last very long flying at about 3/4 throttle. Is there another 3 bladed prop thats more effecient? 9" perhaps? Or change the pitch?
GWS make 9 x 5 x 3 blade propellers in both right and left handed rotation. GWS propellers develop slighty less thrust than other brands but they draw less current and run at a higher RPM.
http://www.hobbyking.com/hobbyking/s...2pc_pack_.html
http://www.hobbyking.com/hobbyking/s...tate_2pc_.html
Ken
kensp is offline Find More Posts by kensp
Old Sep 23, 2012, 09:54 AM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Flew it again today, Do I dare say this plane is more fun in the grass than the water???? ......this plane is sooo awesome.
fully agree with the grass fun make it ideal park flyer with long grass
i use 8x4.7 2 blade with 35g 1400kv motor and run good ....250w is an excellent target to have fun with 415... 8x6x3 seems a little aggressive ? what are your motor kv ?
Kensp : i'v try these with a quad and they are way out of balance... almot impossible to balance
ggtronic is offline Find More Posts by ggtronic
Old Sep 23, 2012, 08:39 PM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Hi all
To those that don't know, it is probably a good idea to glue the standard motors into the heatsinks. One of mine pulled out at half revs. The little screw for the collar that tightens the heatsink around the motor, apparently is not up to the job, so I epoxied around the motor shaft then tightened the screw.
Also, thanks to a previous poster, I used the idea of drilling a hole through the foam nacelle to undo the screw that holds the heatsink to the motor stick. Then it's easy to pull out the motor.
Don't remount the motor back onto the stick until the glue is completely dry, otherwise some glue may get onto the stick & you will find it hard to remove the motor in the future
Kev
Berkie is offline Find More Posts by Berkie
Old Sep 23, 2012, 10:53 PM
KTL13 is offline
Find More Posts by KTL13
Canada, AB, Sherwood Park
Joined Jan 2011
Im running 1200 kv, the 8x6x3 was all I could find at the time, a shot in the dark. I'd like to stick to 3 blades for the scale look. Might have to try the 9x5x3.
KTL13 is offline Find More Posts by KTL13
Old Sep 27, 2012, 12:53 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
[QUOTE=Berkie;22816024]Hi all
Update fellas.
Epoxy didn't grip the steel well enough, so this what I finished up doing.
Use a 2mm hex head screw (so you can tighten it really tight).
In the pic it's a 3mm because that's all I had.
Kev
Old Sep 28, 2012, 05:20 PM
wmcneal is offline
Find More Posts by wmcneal
AMA 125691
wmcneal's Avatar
Jacksonville Florida
Joined Jul 2002
Just got my CL-415 kit in the mail today. Looking forward to building and flying it. Thanks everyone for posting all the tips in this thread.
A friend of mine told me an easy way to remove the paint from areas that are to be glued together is to just apply a piece of tape to that area and then pull it off. I tried it and it works. It's a lot easier than sanding the paint off.
Subscribed
wmcneal is offline Find More Posts by wmcneal
Old Sep 28, 2012, 05:29 PM
wmcneal is offline
AMA 125691
wmcneal's Avatar
Joined Jul 2002
The USA warehouse currently has this kit in stock for $57.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
And the global warehouse currently has the red and white kit version for only $40.
http://www.hobbyking.com/hobbyking/s...hite_ARF_.html
You still have to add shipping and your own electronics, but I think this is hard to beat for such a cool plane.
Old Sep 30, 2012, 04:28 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Yes, it is cheap, but only EPS .
It is also a good flyer but needs a fair amount of re-inforcement & replacement of just about all hinges, struts, horns etc. A lot of work.
I think next time I would rather pay more for EPO & a better finish with a note that the freight cost is no dearer for a better model
Kev
Old Oct 06, 2012, 11:17 AM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Just been overflown by 2 full size CL-215s....awesome...especially as I am in the UK so never get to see these birds.
They are the 2 from the Discovery show 'Ice Pilots'.
I am told they have arrived in St Athan in Wales for 7 months of refurb before going to Turkey on Fire patrol..
Was a Vulcan bomber last week........
Dave
dav3uk is offline Find More Posts by dav3uk
Old Oct 06, 2012, 11:40 AM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Originally Posted by dav3uk View Post
Just been overflown by 2 full size CL-215s....awesome...Dave
thanks to share Dave... i dream of a full CL415 ride since a long time !
and never see them airborn in my area even if they are built here
here is a nice intro to this airplane :
Mega Machines - Super Scooper (7 min 5 sec)
Old Oct 11, 2012, 09:48 AM
wmcneal is offline
AMA 125691
wmcneal's Avatar
Joined Jul 2002
Guanli CL-415
Did the maiden flight on my CL-415 this morning. The differential thrust made taxiing very easy on the wet grass. The plane is a very good flyer and will slow down nicely for smooth landings. I just want to add a couple more magnets to the hatch before trying it off the water. Can't wait!
Old Oct 11, 2012, 06:37 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Don't forget to seal the canopy with low stick tape
Kev
Old Nov 18, 2012, 04:35 AM
inthrustwetrust is offline
Find More Posts by inthrustwetrust
Joined May 2012
Water Drop / Scoop System in my HK CL-415 Canadair ( Hobbyking )
Hi everybody - I am building it - see here:
http://www.wattflyer.com/forums/show...d=1#post889301
inthrustwetrust is offline Find More Posts by inthrustwetrust
Old Nov 21, 2012, 06:59 PM
cosey321 is offline
Find More Posts by cosey321
Joined Sep 2012
Awsoome. I got the new Greatplanes Waterplane G-44 stocked, for a propper build in a year or two.
I hope very much to see the CL-415 stocked by hobbyking; then i need it as a trainer-plane for the G-44
Greatings from a serious boatbuilder..twoo.
cosey321 is offline Find More Posts by cosey321
Old Nov 25, 2012, 06:27 PM
bettsmums is offline
Find More Posts by bettsmums
bettsmums's Avatar
Jacksonville, FL
Joined Jan 2006
Water Drop Tank
I just finished the maiden flight on my new CL-415 this weekend. I used KDA 22-20L motors, Plush 30 amp speed controls, 3S-2200, MAS 8-6 three blade props and Dubro 2 inch spinners. I also decided to add a water drop tank. The plane flies great and will take off of dry grass in less than 10 feet even with the water tank full. The water tank holds 1 pint of water which is almost half the weight of the ready to fly plane. I cut the plane in half at the half way point of the water tank and used the water tank as a doubler when I glued the plane back together. The tank is made from 6mm Depron foam and has a piece of styrene plastic on the bottom around the hole to help the suction cup seal. I used Gorilla glue to hold everything together without leaks. The valve is a 1 1/2 inch suction cup used for mounting christmas lights on windows. I used a 2-56 threaded rod that just happened to fit a molding hole already in the top center of the suction cup. The drop hole is 1 inch in diameter and drops the full load of water in slightly over two seconds. The water tank is centered right on the CG. The water effect was not as good as I was hoping as the water did not foam up like it does on the real plane. I even tried dropping at full throttle without much improvement. It is still fun to watch and is a show stopper at the field. You can see the water marks on the runway after a bombing pass. I haven't tried flying from water yet but I am hoping that the water will be scooped up through the bottom water exiting while flying along the surface. I beveled the exit holes to channel the water up. Then hopefully it will fill the tank until it overflows out the air vent up just under the wing.
bettsmums is offline Find More Posts by bettsmums
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
