Old Aug 21, 2012, 01:15 PM
Crowstooth is offline
Find More Posts by Crowstooth
Lotsa stuff
United Kingdom, England, London
Joined Apr 2010
Hi Furballll,
Thanks for the reply but I don't understand the velcro part
" as for making them removable you can for some blocks the shape fo the bottom of the wing and put velcro on there its plenty stong, mayby cut down the part that goes into the wing abit but keep some of it as a centering guide."
Do you mean I should add side blocks (wooden?) to the legs flush with the wing and velcro to the underside of the wing? I can see triangular blocks but I'm not sure that's what you mean.
If the tip floats are fixed do they not catch and cause a cartwheel if the landing is not level? This is what I'm worried about and why I'm thinking about removable tip floats.
Crowstooth is offline Find More Posts by Crowstooth
Old Aug 21, 2012, 03:46 PM
furballll is offline
Find More Posts by furballll
lost in the addiction of flyin
furballll's Avatar
Canada, BC, Kelowna
Joined Dec 2009
sorry. make blocks and glue them to the upright part of the tip floats then attach velcro to the bottom of the wing and the block this will make them tear off and not break hopefully. i never did this on mine and i did hit a wave hard and and hooked a tip float that resulted in it breaking off at the wing. i have never had an issue with the tip floats on land they just skip along nicely almost never touch the ground.
furballll is offline Find More Posts by furballll
Old Aug 22, 2012, 11:36 AM
parkcityskier is offline
Find More Posts by parkcityskier
Parkcityflier
parkcityskier's Avatar
Park City, UT, USA
Joined Aug 2001
Here's how I did it on mine. Glue the 1/32" plate to the strut while pushing it up against the underside of the wing so that it follows the underside camber. You can then permanently glue the float to the wing, or use nylon screws, or velcro.
parkcityskier is offline Find More Posts by parkcityskier
Old Aug 22, 2012, 08:32 PM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Originally Posted by parkcityskier View Post
Here's how I did it on mine. Glue the 1/32" plate to the strut while pushing it up against the underside of the wing so that it follows the underside camber. You can the permanently glue the float to the wing, or use nylon screws, or velcro.
Thanks for the pic Parkcity. Worth a '000 words
Kev
Berkie is offline Find More Posts by Berkie
Old Aug 23, 2012, 07:16 AM
robs is offline
Find More Posts by robs
robs's Avatar
United States, NY, Dutchess
Joined Jun 2002
I did something using triangle stock to add width and then embedded magnets on each surface for attachment.
robs is offline Find More Posts by robs
Old Aug 25, 2012, 02:41 PM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Originally Posted by furballll View Post
yes finding mounts and motors that take stick mounts is the biggest reason, but secondly most of the photos i have seen of the plane with stick mounts look weird. the motor usually gets placed out in front and higher due to the offset in most mounts.
agree... motor mount was one of my concern with this model :
http://www.rcgroups.com/forums/showp...&postcount=916
still enjoy this twin ! didnt see much ground takeoff & hand launch ?
easy to do...
CL415 fpv (0 min 48 sec)
ggtronic is offline Find More Posts by ggtronic
Old Aug 27, 2012, 08:29 AM
fun2av8rc is offline
Find More Posts by fun2av8rc
Fly Micro Scale to Full Scale
fun2av8rc's Avatar
United States, VA, Brandy Station
Joined Nov 2011
Interesting head gear .... What are the dodadds you have attached to your hat?
easy to do...
https://vimeo.com/48208053
fun2av8rc is offline Find More Posts by fun2av8rc
Old Aug 27, 2012, 11:12 PM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
its a TRIMERSION moded google to fly in FPV mode...
(fly with video down link to screen)
Old Sep 06, 2012, 05:01 PM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
latest flight with the 415 :
Lac Bompton (4 min 17 sec)
Old Sep 06, 2012, 05:39 PM
dav3uk is online now
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Jealous....me.............hell yes..........
Dave
dav3uk is online now Find More Posts by dav3uk
Old Sep 06, 2012, 08:46 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
https://vimeo.com/48976670
Bewdy mate!
Well flown
Well shot
Well edited
Interested in your aerial mast. Where can I get one and did you combine the 2 aerials into one?
Kev
Old Sep 06, 2012, 09:53 PM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Originally Posted by Berkie View Post
Bewdy mate!Interested in your aerial mast. Where can I get one and did you combine the 2 aerials into one?Kev
aerial mast ? what you mean ?
thanks i have 2 HDkeychain camera location on my 415:
(flying with 1 camera only... one at a time)
--on top of rudder (fixed part) wich get plane on the field
--on the nose
this video was made out of 5 flight i'v done last weekend
Old Sep 06, 2012, 11:20 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
--on the nose
Sorry, I thought I saw an aerial mast sticking up near the nose and that you were using it for your Rx with 2.4
There has been a few comments here that 2.4 might have a problem over water & a way to fix it is to elevate the aerials
Kev
Old Sep 07, 2012, 08:19 AM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
There has been a few comments here that 2.4 might have a problem over water & a way to fix it is to elevate the aerialsKev
i do have fail safe happend to me but i was really far away with tree
blocking los... i strongly recommande diversity 2.4 receiver :
twin antenna or satelite RX addon
Old Sep 09, 2012, 02:30 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Australia
Joined Feb 2007
Do you waterproof your cameras?
Kev
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 01:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 06:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 05:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 12:36 PM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 10:54 PM
