Old Jun 04, 2012, 12:29 PM
baddb1 is offline
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Originally Posted by jdlilfan View Post
Bad news for me. I attempted to maiden this spring with someone assisting me in handlaunch and the plane just nosed dived right out of the guys hands into the ground. Nose got busted up and broke the plywood wing mount. Got it all back together and decided it would be best to maiden at a lake since I would have a super long runway to work with.
Went to remaiden this weekend. Saturday night was dead calm, all the boats had cleared off the lake, and the water was glassy smooth. Did some taxi tests and the props kept catching water and gurgling. I had seen this before though in youtube videos of the plane and it seems like the plane will end up powering thru it. Decided to fly it. Started the takeoff run, props were gurgling here and there, started to power out of it and get on step. Plane started to look light and take flight. Then all of a sudden as it was starting lift, it just dug into the water nose first, and then flipped over onto it's back!
I just stood there stunned for a minute! I couldn't decide to swim out and get it or run up and grab my kayak (which was stored away behind a shed). Decided to kayak and it took several minutes getting out out and carrying it down the steep shore. By the time I got out there, water was seeping in and it was starting to sink! It was sitting pretty low in the water. The motors were beeping and twitching. I unplugged the battery and got it to shore.
I let everything dry and decided to power up the plane and see what the damage was. Servos all seemed to work fine but the motors were twitching and the right ESC started smoking within 30 seconds. Unplugged everything quickly and luckily no fire. Battery was a turnigy 2200mah and it seems to be fine.
I guess the motors and esc are toast. I will see about getting new ones eventually. Really bummed at what happened. I'm still not really sure what had caused it? Im thinking maybe cg was too far forward although I balanced it at the recommended spot. I installed extra velcro and the battery couldn't really move? I had added up elevator to keep the nose up on takeoff. I am running 3 blade props and my other possible explanation is that I was rolling on the power smoothly and by the time I got to full power, due to the high placement of the props/motors, the change in torque, p-factor, and power, added to the nose in, downward motion. Maybe I need more throw on the elevator?
I had plenty of power. Using the rc-timer 1400kv motors 2212-10's. Using 8x4 3 blade GWS props. Full throttle and the plane will pull out of my hands. Running counter rotating. Detrum 30amp ESCs. 9g HXT900 servos all around (the water proof claim seems to be holding up well). 11.1v 2200MAH battery.
Your motors should be fine. I have dunked mine many times w/ no problems. After dunking your electronics you should let them dry for days though, or, even better, force dry them with a heater fan on low power before trying to connect the battery again.. BTW - Did you apply Corrision X on your ESC's? That may have saved them if you had!
I use those same motors in mine although I run 3-blade 7X4 props. The 8" props on that motor I think may be drawing more current than should be. The side benefit is with a 7" prop, they will be less likely to hit the water. I also noticed with this plane it needs a fair amount of up elevator and from 80 to 100% throttle to ROW quickly and cleanly. Just my 2 cents. Good luck on the next flight!
baddb1 is offline Find More Posts by baddb1
Old Jun 04, 2012, 12:46 PM
jdlilfan is offline
Find More Posts by jdlilfan
jdlilfan's Avatar
United States, IN, Indianapolis
Joined Mar 2010
I will order some 7x4s. I ordered some HK 20amp esc's just a bit ago. I know the right side esc is toast. Smells like fireworks. Both esc's and motors were submerged for 10+minutes. I placed the ESC's in the nacelles behind the motor for cooling thru the nacelle.
jdlilfan is offline Find More Posts by jdlilfan
Old Jun 05, 2012, 12:59 AM
Bo43 is offline
Find More Posts by Bo43
Bob S.
France, Auvergne, Luneau
Joined Aug 2008
Sorry about the crash. Please tell me where you order the 3-blade 7x4's.
Bo43 is offline Find More Posts by Bo43
Old Jun 05, 2012, 05:27 AM
baddb1 is offline
baddb1's Avatar
Joined Jan 2009
HobbyKing
2 links listed for counter-rotating props.
http://www.hobbyking.com/hobbycity/s...idProduct=8092
http://www.hobbyking.com/hobbycity/s...idProduct=9670
Old Jun 05, 2012, 06:30 AM
va3mw is offline
Find More Posts by va3mw
va3mw's Avatar
Joined Sep 2008
If you look book in this thread, you can find my notes on how to waterproof the ESCs, receiver and Servos. The motors are impervious to fresh water, so they won't be a problem at all.
I've drowned many a plane and flown it moments later.
Sorry about your crash.
Since you had 2 episodes with the same problem (diving down), you might want to look at your elevator. The CL415 will climb right off the water with just about no human input.
va3mw is offline Find More Posts by va3mw
Old Jun 06, 2012, 05:41 PM
parkcityskier is offline
Find More Posts by parkcityskier
Parkcityflier
parkcityskier's Avatar
Park City, UT, USA
Joined Aug 2001
Thanks, I'll see if I can get them; none in stock recenytly.
I'm also looking for an authentic prop for the CL-415, that's to say a 4-blade prop. I tried the 6x3 from Graupner, but it's a bit too weak. Anyone have any ideas from anyone where to purchase a not too expensive 4-blader?
The APC 9" four bladed props look very nice. I was able to adapt the kit provided spinners to the props by cutting two more openings in them. Painted black, the props look very scale. However, the plane flys so well with the stock two bladed props that I never got around to installing them. I've got over 50 flights on my CL-415 and I'm ready to try something different so maybe I'll try them out one of these days.
parkcityskier is offline Find More Posts by parkcityskier
Old Jun 07, 2012, 08:02 AM
pookielips1954 is offline
Find More Posts by pookielips1954
Joined Aug 2004
If someone was building a Vickers Viscount or Fokker F-27 those props would be perfect!
Russ Farris
pookielips1954 is offline Find More Posts by pookielips1954
Old Jun 14, 2012, 07:19 AM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Russ Farris
I got a part built F-27 in my attic, but its 120" span so may be a bit big...........lol
Dave
dav3uk is offline Find More Posts by dav3uk
Old Jun 18, 2012, 02:39 PM
AirbusDriver is offline
Find More Posts by AirbusDriver
Canada, ON, Toronto
Joined Jan 2012
Kmp version
So I just bought the KMP version of the CL-415 and it came with motors pre-installed. The box says they're "2410" but don't list any kv rating and I can't read anything off he motor in the cowl. Does anyone know the specs on these motors? I'm going to start with the stock props (8038 counter-rotating) but I'd like to move into a 3 blade soon.
Thanks!
AirbusDriver is offline Find More Posts by AirbusDriver
Old Jul 22, 2012, 06:36 AM
fun2av8rc is offline
Find More Posts by fun2av8rc
Fly Micro Scale to Full Scale
fun2av8rc's Avatar
United States, VA, Brandy Station
Joined Nov 2011
Joining the Thread & Building R/W CL-415
Morning Guys.... I ordered the RED/WHITE CL-415 from HK and have received the notice that it has been picked & are on the truck headed for the HobbyKing Front-End Warehouse.
So the wait begins. I really don't expect it to arrive for another two weeks .... but with one exception (which was my fault - I chose the wrong shipping option), I have always gotten stuff from HK quickly and it has always arrived in great shape.
I also ordered
- 6 HXT900 9g / 1.6kg / .12sec Micro Servos
- 2 Hobbyking SS Series 25-30A ESCs
- 2 Turnigy L2210C-1200 Brushless Motors (150w)
- 2 GWS HD8040 3 Blade Props sets, both clockwise and counterclockwise.
I am placing another order today for
- 2 DX8 batteries
- 2 D2822/14 Brushless Outrunner 1450kv motors
. . . . . Insurance in case the L2210s don't work out.
- 2 OrangeRx R710 Spektrum DSM2 Compatible 7Ch Rxs w/Failsafe
I am going to add lights to mine for dusk flying
Questions:
- Has anyone put wheels / retracts on one of these?
- Is anyone actively flying FPV with this airplane?
Jim
fun2av8rc is offline Find More Posts by fun2av8rc
Old Jul 22, 2012, 07:54 AM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
Originally Posted by fun2av8rc View Post
Morning Guys.... I ordered the RED/WHITE CL-415 from HK - Is anyone actively flying FPV with this airplane? Jim
i do fly it FPV really fun ! take off & landing splash lots of water all over this plane so make shure the camera is in a water tight environement...
orange RX+satellite are really good choice, specialy the 7ch wich you can place the
wire antenna for good diversity...
aileron are not much effective, make shure to get BIG 45deg throw up & down...
CL 415 FPV flight :
CL 415 au lac Brompton (5 min 43 sec)
i also own a FPV POLARIS XL :
FUN (3 min 48 sec)
ggtronic is offline Find More Posts by ggtronic
Old Jul 22, 2012, 10:08 PM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
I also ordered
Mmmmmmmmmm.Don't like those little buggers.
I used to order them all the time, but about a year ago found that one after the other had problems.
I go for Corona 939s now. Only $4 with metal gears.
Kev
Berkie is offline Find More Posts by Berkie
Old Jul 22, 2012, 10:14 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
CL 415 FPV flight :
http://vimeo.com/35098265
http://vimeo.com/45642929
Hey gg - like the idea of lights for dusk flying!
Reckon that would look fab with a sunset backdrop.
I live on a beach (can't afford a house ) and if we ever DO get our sun back again from you guys then I'll enjoy giving the beach walkers a display on some of those warm evenings.
That guy on the nose of the CL-415 - he's not fishing is he? Can't be - he's wearing headphones.
OK I give up what IS he doing?
Re the cam location. Why not Corrosion X the inside of it? It works!
Kev
Old Jul 22, 2012, 11:30 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Kev
Most probably connecting or disconnecting a line from the seaplane to a mooring buoy.
Ken
kensp is offline Find More Posts by kensp
Old Jul 23, 2012, 07:45 AM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
That guy on the nose of the CL-415 - he's not fishing is he? Can't be - he's wearing headphones. OK I give up what IS he doing?
Kev
yes i might try that cX some day...
Kensp... yap i think that what he's doing
Berkie... fully agree... i use HITEC hs55 with plane i want to "survive"
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
