now the wing can support 1.5 kilo without flex ! |
Joined Dec 2004
Also forgot to mention that I was very pleased with the almost nil water penetration inside. The technique I used to seal it was to put a good amount of white glue on the bottom and move the plane slowly to let it slide from the rear to the front and left the plane drying for a few days, seem to pay off now.
For the servos I put plenty of vaseline over the arms and all around. |
Thanks for the comments on the wing joining issue. |
Latest blog entry: Polaris Aileron Pushrods
My two cents on wing reinforcement....
I believe the real purpose of the wing struts is to add strength to the wing attachment to the fuselage and not to the wing itself. So if you go without the struts and think that just adding wing strength will compensate, you could surprise yourself in spectacular fashion ![]() I went without the struts but did not add any reinforcement to the wing. IMO the plywood spars are plenty strong enough to keep the wing in one piece short of violent high-g maneuvers. But I did reinforce the wing saddle area inside the fuselage by layering up some thin ply and adding some hardwood bracing. |
Joined Dec 2004
France, Auvergne, Luneau
Joined Aug 2008
Props and Spinners
Something I have not yet read about, but experienced.
Usually, props turn clockwise and the spinners are also tightened clockwise, This is of course not very good; If you tighten the spinners too much (often aluminium threads) you can rip the thread; if you tighten them too loosely, the props can (and have done with me) spin off into the undergrowth. Solution: use anti-clockwise turning props and clockwise (normal) threaded spinners, or vice versa. I haven't heard of spinners tightening anti-clockwise. Has anyone? |
Joined Dec 2004
For your information, I'm going to try using a 2650 Mha pack for additional flight time and curious to experiment the change. Here's what I ordered from HK: http://www.hobbyking.com/hobbyking/s...idProduct=9947
I use the contra rotating props and like the way that they keep the plane tracking straight on takeoff. To keep from losing a prop I have inserted a small pin into the backplate of each motor. This pin locks into the backside of the propeller hub to keep it from turning against the prop nut and loosening it. I lost one prop on another larger twin before I did this. I've never had a problem since.
Joined Dec 2004
I used Dubro 1 1/2'' plastic spinners and they lock the propellors in position, blocking any movement. If you choose the same motors as I did, the locknuts fits right into the propellor receptacles. With the additional security of the spinners this is what I call ''belt and braces''
Joined Aug 2008
Thrust??
Interesting, must try, but in the mean time, I have just had the maiden flight with the CL-415.
Would like to say, Hurray! but unfortunately - problems: Using maximum thrust, I get it to take off, but when it is at an altitude of about 5 feet, giving it some elevator has no effect, and the plane continues at 5 feet, but with an upwards angle of about 30°, so it sort of ‘ploughs’ its way ahead, not gaining altitude. What should I do? Lack of adequate thrust, surely? Planes specs: Plane weighs 1350g, and on its wheeled stand, I measure a thrust of 780g using a spring balance, with max. thrust. Motors: 2 Turnigy 1350 brushless motors (rated at 1350rpm – how can I measure this?). ESC’s: 2 x HKing 20A HKz20A 2 x props delivered with kit: 8 x 3.8 Battery, fully charged: Turnigy Lipoly 2200mAh, 11.1V. |
Thoughts on Hobby King CL-415T mods, (see post 919).
Original wooden spars removed and 6mm x 1000mm carbon-fibre tube spar fitted. Flaps cut from wings are driven to 15deg & 25deg by two wing-top fitted 9gm servos. Rudder servo relocated to fin and elevator servo, (standard Futaba 148 type), now drives via snake into fin with a transfer linkage to the elevator. Spray chines fitted to front hull and hull resin/glassed. Hatch and wing-seat waterproofed with in-situe cast silicone rubber gaskets. Two off Turnigy L2210C-1200 Brushless Motors (150w each) fitted to bulkheads in nacelles driving GWS 9x5x3 props controlled by Hobby King ESCs, (Max Current: 25A – 30A burst), in nacelles. (I cut off the original nacelle fronts because they were just SO ugly). Contra rotating props with rudder mastered differential throttle for surface steering, (very effective on carpet, should be fine on water). Total weight including 2200mA battery at 1.4 kilos, (3lbs).
Had about 20 flights now, unfortunately none yet off water, all from grass. Value for all the modding work, some good some surprisingly unhelpful. Carbon spar insertion highly recommended, ply-spars tore out very easily. Re-inforcement to wing-seat area worthwhile, high stress area when tip floats dig in. Resin-glass hull bottom, a must if you want it to last past its first brush with a twig. Past experience would indicate benefits from spray chines, silicone rubber sealant at wing seat and keep your elevator servo inside and dry... Surprisingly unhelpful,---the differential throttle proved to be VERY unhelpful in the air at low speed, (I programmed a switch to cut it out). It will still be a god-send when I finally get to need water steering. (thanks dav3uk for posts 924 & 927). Flaps, can't tell the difference at any setting, cut the throttles and it flies into treacle-air, stops in 2 lengths. Surprisingly easy to get into air from grass strip and P.O.P. to spot-land. I'm well pleased with it. |
Joined Dec 2004
Another very successful series of flights. The 2650 Mha packs don't really provide more punch (the motors are pushed to the limits) but useful to add a little bit of weight in windy conditions and provide longer flight times - all in all, pretty satisfied but they make a bigger difference with my Mini Funtana!
Lots of applauses and positive feedback by the crowd :-) |
http://www.hobbyking.com/hobbyking/s...tor_100w_.html Those motors are pretty minimal for a 3lb model. They are rated at 100 watts, which means that if they are developing maximum power, you've only got 66 watts/pound. The old rule of thumb was that for good performance you need 100 watts/pound. You can certainly manage with less than that but you don't have much reserve at 66 watts/lb. Note that the rating of the motors is 1350KV, which stands for rpm/volt. In theory, the props should turn at about 1350 x 11.1 x 80% = 12,000 but I doubt whether the motors are capable of doing it. If you want to measure anything, it's not KV (which requires special equipment) but amps and propeller RPM, which can be measured easily. Static thrust tells you how the model will accelerate but not how it will perform in the air. |
| Thread Tools | |
| For Sale MR Aerodesign Canadair CL-415 Kit Complete | Rudderman98 | Aircraft - Fuel - Airplanes (FS/W) | 0 | May 09, 2009 07:05 PM |
| Found Canadair CL 415 kit,ARF, ARC,or plans | rcdude01 | Aircraft - Electric - Airplanes (FS/W) | 2 | Nov 13, 2008 05:41 PM |
| Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans | rcdude01 | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 17, 2008 04:54 PM |
| For Sale Canadair CL-415 Kit NIB | EAMRC | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 29, 2006 11:36 AM |
| FS: Canadair CL-415 Kit | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 3 | Oct 11, 2004 09:54 PM |
