Old Nov 09, 2011, 04:02 AM
Luke2000 is offline
Find More Posts by Luke2000
Ireland, Dublin, Dublin City
Joined Apr 2011
Originally Posted by kensp View Post
My CL-415 weighed 38.5 oz ready to fly complete with a Zippy 1600 mAH 3 cell 20 C battery pack.
Ken
Oh dear,
47.5 oz without battery. I think it's been eating all the pies! Time for a diet
Luke
Luke2000 is offline Find More Posts by Luke2000
Old Nov 09, 2011, 05:01 AM
Luke2000 is offline
Joined Apr 2011
Originally Posted by parkcityskier View Post
If you want to add the splash guards, I made mine from .020" styreen sheet. I tacked them in place with thick CA glue and accelerator. I then poured in a small fillet of 30 minute epoxy, thinned with a drop of alcohol to make it flow a little easier. The fillet makes a nice transition from the hull to the splash guard and adds strength.
Parkcityskier,
Just looking back at this post, I thought that spray rails would have to come "out of the side" of the fuselage to stop the water being flung into the props. Do these help? I see in your post that your weight is 3lbs, so I'm still lighter than that
Old Nov 09, 2011, 08:13 AM
parkcityskier is offline
Find More Posts by parkcityskier
Parkcityflier
parkcityskier's Avatar
Park City, UT, USA
Joined Aug 2001
The spray rails should be an extension of the molded area of the forward bottom of the hull (where the scalloped area is on the side of the hull). Mine eliminate just about all of the spray hitting the props. At a seaplane flying meet this last weekend I flew my CL-415 in very strong winds and wave action with no problem.
parkcityskier is offline Find More Posts by parkcityskier
Old Nov 09, 2011, 08:21 AM
Luke2000 is offline
Joined Apr 2011
Ours appear to be the same weight and that scalloped area is underwater on mine. Is yours the same do you remember?
Luke
Just found this pic of a twinstar with splash guards. I would have thought that along each side above the waterline was where they are needed ?
http://www.parkflyerplastics.com/car...roducts_id=397
Old Nov 09, 2011, 12:38 PM
pookielips1954 is offline
Find More Posts by pookielips1954
Joined Aug 2004
Luke - the spray rails shown on Parkcityskiers model work perfectly. Same set up on mine, completely eliminates the spray into the props. The main affect is the sharp edge, because water will climb over a rounded edge like on a foam molded hull. I've had to add spray rails or chines to every R/C seaplane I've ever had since 1970. No need to over think it here
Russ Farris
pookielips1954 is offline Find More Posts by pookielips1954
Old Nov 09, 2011, 01:06 PM
Luke2000 is offline
Joined Apr 2011
Russ Farris
Thanks for that Russ. Just one more question. Looking at parks plane, do I glue the strips to the corner at the bottom/side point, as if they were a small extension of the fuselage side pointing down and same direction as the sides?
TVM
Luke
Old Nov 09, 2011, 11:21 PM
Joined Aug 2004
TVM
Luke
You got it, Ace! The top of the spray rail would be even with the top of the red, giving you about 1/4 inch of gluing area for the spray rail.
Russ Farris
Old Nov 09, 2011, 11:47 PM
GLM is online now
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Hi All,
I should have posted this a while ago - We held a float fly on October 14-16th at a lake nearby.
Pardon the language of the cameraman the sun was an issue.
I'm hoping cheek strakes at the bow chine will help the rough landings - it looks like it stalls right at the last second and I guess that me
Cheers!
Gary
Gary's Canadair (6 min 7 sec)
GLM is online now Find More Posts by GLM
Old Nov 10, 2011, 02:58 AM
Luke2000 is offline
Joined Apr 2011
Russ Farris
Thanks Russ, have it now.
Nice video Gary.
Luke
Old Nov 12, 2011, 06:27 PM
fly time is offline
Find More Posts by fly time
Electric flyer
fly time's Avatar
Renton, WA, US
Joined Oct 2007
Structural repairs are complete, but I still have to fill in the wrinkles and cracks and probably repaint. That will be another day though. First order of business is to get her back in the air and fix the problems that caused me to crash. I got all of those things checked off the list this morning, and got down to the lake just ahead of the rain
Here is some on-board video of my first flight since the crash. It is not my most graceful flying but about half the flight was devoted to getting the trims set properly, and the air and water were just slightly choppy. It also cut short for some reason. I actually made about a half dozen landings and takeoffs before switching to a second battery.
Guan Li Canadair CL-415 (4 min 16 sec)
fly time is offline Find More Posts by fly time
Old Nov 12, 2011, 06:57 PM
fly time is offline
Electric flyer
fly time's Avatar
Renton, WA, US
Joined Oct 2007
Here are a few pics of my repairs (in progress). I need to fill, sand and paint still, but the good news is that it flies just fine like this
I fixed the thrust differential at WOT by re-programming the ESC's (after spending forever trying to figure out what I had done wrong with the radio programming!). I corrected the flap trim problem by mixing in 2% left aileron with the flaps. And I also found that the thrust angle of the left motor was higher than that of the right, so I shimmed them level with each other with some thin washers.
After a couple of flights this morning, I no longer have any noticable problems with WOT (still not needed), but the flaps need some adjustment still. Maybe I will try mixing in a little down elevator because the plane pitches up ever so slightly and wants to stall unless I push the stick forward.
Old Nov 12, 2011, 07:34 PM
shock is offline
Find More Posts by shock
High Voltage
shock's Avatar
Motorcity
Joined Sep 2010
Make sure your ESC's are throttle matched. I had this problem on an A-10 build. Have to program each separately to match them.
-Joe
shock is offline Find More Posts by shock
Old Nov 13, 2011, 02:41 AM
fly time is offline
Electric flyer
fly time's Avatar
Renton, WA, US
Joined Oct 2007
-Joe
I did do that before my maiden flight....or so I thought. For some reason it did not take. Did it again after the rebuild and now they seem to be fine. Unlike before, I did not witness any adverse yaw from advancing the throttle this time.
Old Nov 13, 2011, 05:06 PM
Luke2000 is offline
Joined Apr 2011
Fly time, nice video, where's the bang at splash at touchdown . I'm amazed how from the hatch back looks so new - you seem to be able to do precision crashes
I found in mine that one of the bullet connectors to a motor was undone, may have happened in the crash, but It would explain the spiral dive.
What do you guys mean by making sure that the ESCs are throttle matched?
Luke
Old Nov 13, 2011, 06:23 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
My method of obtaining two matched ESCs for my twins is to always use brand new ESCs purchased two together. This improves the chances that I get two ESCS from the same manufacturing batch that are therefore matched. I have built and flown seven twins so far and this method has given me trouble free flying.
Ken
kensp is offline Find More Posts by kensp
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
