Old Apr 01, 2011, 07:58 AM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Originally Posted by kensp View Post
The mount that is used will depend on the offset of the stick. If the original design was for geared motors then the black GWS style stick mount will not work as the prop shaft will not be in the center of the hole in the front of the nacelle.
I will wait until I have the model before making motor mount selection. I have two types of mounts with the two most common offsets that I can use.
My work with MotoCalc indicates that a 1600 mAh battery will give around 6 minutes at WOT and around 20 minute flights at reduced throttle. The final decider in my case will be," Can the correct CG be achieved with the lighter battery".
Photo No 8 in the Hobby King add shows that two spinners are supplied with the kit.
Ken
Looks to me like the Guan'Li kit comes all set up right for doing the 4-blade prop mod, that I mentioned above! You get the 2 extra props, and the extra
notches are easy to add to the spinners. Bravo, Guan'Li! (Mine was finally shipped, yesterday).
Lancer31 is offline Find More Posts by Lancer31
Old Apr 01, 2011, 09:03 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Do you have any pics of the mod? I'm a little confused on how you did it..
Thanks!!
baddb1 is online now Find More Posts by baddb1
Old Apr 01, 2011, 10:55 AM
Lancer31 is offline
Joined Jun 2005
Thanks!!
Going out today, to get the tools. I will post a "How to", here. Standby.
Correction; I couldn't find an aircraft counterbore, locally, so I ordered one online. May take a few days to get. Cost about $20, plus S&H, so maybe I will make 4-blade, counter-rotating propellers for modellers. We'll see.
Old Apr 01, 2011, 01:36 PM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
Originally Posted by huntingfield View Post
I watched the nitroplanes video and was very impressed ( might need a little rudder mixed with aileron). I ordered one of these planes yesterday(Hobbyking). The power system that they show in the video is the one I will use. I plan on using flaps and a lighting system and differential throttle for water handling. Thank you Hobbyking for this plane, now where is the Dehavilland Dash 8 ?
How are you going to do the flaps? a split flap or is the room to do a regular stlye flap?
Also what do you guys think of this motor.... http://www.hobbyking.com/hobbyking/s...idProduct=6246
Dak
Dakrat is offline Find More Posts by Dakrat
Old Apr 01, 2011, 04:24 PM
JCE1 is offline
Find More Posts by JCE1
Belgique
Joined Feb 2011
Receive mine today. Very light and thin EPS,like old's GWS, probably easyly breakable.
Good aspect, well done.
Need some work for masking wires between aileron's servos, motors and fuselage. Guanli don't preview another solution than under wings...
Start assembling tomorrow ...
JCE1 is offline Find More Posts by JCE1
Old Apr 01, 2011, 04:33 PM
hpiguy is offline
Find More Posts by hpiguy
If it's R/C, it's all good.
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
Pics?
Are the directions any good for assembly/ideas or total Engrish?
hpiguy is offline Find More Posts by hpiguy
Old Apr 01, 2011, 04:58 PM
JCE1 is offline
Belgique
Joined Feb 2011
Just a poor chinese-english translation helas. But its possible to understand every point easily. Sorry for pics., i 'dont have my Digital phot. here in my house at this time.
It's the first canadair with wings struts
Old Apr 01, 2011, 10:29 PM
hpiguy is offline
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
Wing struts?
Oh yeah, if I look at the video really close it has wire supports on it. Funny.
Old Apr 01, 2011, 10:42 PM
aferguson is offline
Find More Posts by aferguson
Joined Apr 2006
can someone confirm that the length of the hobby king cl 215 is only 750mm? Is that a typo? It doesn't look that misproportioned to me, given that the span is 1390mm. Should the length be 950mm not 750mm?
aferguson is offline Find More Posts by aferguson
Old Apr 01, 2011, 11:53 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I measured up on my one of my 3 view drawing of the Cl-415 and found that if the model is to scale then the length should be 973 mm.
Ken
kensp is offline Find More Posts by kensp
Old Apr 02, 2011, 04:45 AM
JCE1 is offline
Belgique
Joined Feb 2011
lenght of my model: 970 mm
Old Apr 02, 2011, 06:09 AM
JCE1 is offline
Belgique
Joined Feb 2011
If you want to use motors like 2410 Towerpro, hextronik, or similar, don't forget to order proper stick mount like: hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=3613
Plastic genuine tp don't fit in place...
Old Apr 02, 2011, 08:10 AM
Lancer31 is offline
Joined Jun 2005
Dak
Looks pretty good, but it is backordered. KV is a might low.
Old Apr 02, 2011, 12:04 PM
Joined Apr 2006
JCE1, thanks for the info. So that is a typo on Hobby King's site. Good to know. I thought it looked pretty well proportioned, so was wondering why it was so short. The answer is, it's not short, it seems to be perfectly proportioned.
Goody.
Old Apr 02, 2011, 12:52 PM
hpiguy is offline
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
What is "plastic geniune tp"?
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 01:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 06:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 05:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 12:36 PM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 10:54 PM
