The ones I'm looking at if I don't go with those Alphas are the Blue Wonders from headsuprc.
This: http://www.headsuprc.com/servlet/the...lectric/Detail The ratings they give it with a 9050 and the 8040 props on 11.1V are pretty good. I'm no expert on picking brushless motors and such, so I always try to read the reviews and take as much advice as I can get before picking a power package. |
Seeing as the plane comes with sticks for the motors, I think that's the way it will go. BUT, I can always be wrong and I'm sure someone will correct me. You can see how it's done with different motors in these pics: http://www.headsuprc.com/servlet/the...r-Mount/Detail Or use a metal one like this: http://www.hobbyking.com/hobbyking/s...idProduct=6782 The stick mounting hole in the nacelle is off center towards the bottom, so the stick style motor mount brings it back to center. You get a good view in this pic: http://www.rcgroups.com/forums/attac...mentid=3887436 |
The prop adapter they come with will either secure to the shaft with a set screw or it will be a compression fit when you screw on the spinner.
Based on the looks of the shaft and the included spare shaft, it's a compression fit. You place the adapter on the shaft, then the prop with proper insert, then screw down the spinner on top of it. As it screws down it will tighten the adapter onto the shaft. It may assemble slightly different, I'm just quoting from how other ones work. I'll be modifying the $1.50 three blade black spinners from gwsprops to fit over the top of the prop adapter. If they look bad, block too much airflow or plain just won't work that way, I'll save them for my GWS T6 and paint the included blue spinner a nice flat black. This video will give you a great view of it installed with adapter, mount, etc. It's right from their site.
The mount that is used will depend on the offset of the stick. If the original design was for geared motors then the black GWS style stick mount will not work as the prop shaft will not be in the center of the hole in the front of the nacelle.
I will wait until I have the model before making motor mount selection. I have two types of mounts with the two most common offsets that I can use. My work with MotoCalc indicates that a 1600 mAh battery will give around 6 minutes at WOT and around 20 minute flights at reduced throttle. The final decider in my case will be," Can the correct CG be achieved with the lighter battery". Photo No 8 in the Hobby King add shows that two spinners are supplied with the kit. Ken |
Correct, those are two blade spinners. I'll be using three blade props, hence the three blade spinners I bought. For some reason I'm just hooked on the three blade prop for this one.
I see that the stick mounts are quite a bit lower in the nacelle from the picture, so that's where I was assuming the offset mounts would be what we needed. You are correct again that we'll have to see exactly what the offset is once they arrive. |
| Thread Tools | |
| For Sale MR Aerodesign Canadair CL-415 Kit Complete | Rudderman98 | Aircraft - Fuel - Airplanes (FS/W) | 0 | May 09, 2009 07:05 PM |
| Found Canadair CL 415 kit,ARF, ARC,or plans | rcdude01 | Aircraft - Electric - Airplanes (FS/W) | 2 | Nov 13, 2008 05:41 PM |
| Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans | rcdude01 | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 17, 2008 04:54 PM |
| For Sale Canadair CL-415 Kit NIB | EAMRC | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 29, 2006 11:36 AM |
| FS: Canadair CL-415 Kit | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 3 | Oct 11, 2004 09:54 PM |
