Old May 14, 2011, 07:16 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Put the bit larger motors on my 415. I used the 2212-10 motor (1450KV) w/ 8X4 3-blade props. Much better overall performance now! Here is a video taken yesterday of my flight. Notice how slow she can fly! I also was having a little fun in the air with differential thrust programmed in!
HobbyKing Canadair CL-415 flight (7 min 5 sec)
baddb1 is online now Find More Posts by baddb1
Old May 14, 2011, 07:41 AM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Very nice flight. Can you post a link to your motors? What escs did you use?
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old May 14, 2011, 10:09 AM
baddb1's Avatar
Joined Jan 2009
I used these motors: http://cgi.ebay.com/NEW-1400KV-Outru...item3cb72d6546
Or these are good too: http://cgi.ebay.com/New-RC-Hobbies-1...item19b5c51c87
ESC's were HK 20A : http://www.hobbyking.com/hobbyking/s...dProduct=15202
I would not advise to anyone to use the HobbyKing recommended motor on their CL-415 webpage. I tried them and I feel they were too underpowered. They worked ok, but the plane was "sluggish" in the air!
Old May 14, 2011, 10:26 AM
KC9TPL- Get Legit
Joined Aug 2007
Thanks. Ordered. If anyone else wants these, they are slightly cheaper here:
http://www.rctimer.com/index.php?gOo...7&productname=
Old May 15, 2011, 05:30 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I was not happy with the fit of the forward hatch. This fit was loose and would have leaked water. I have made the mods shown in these two photos to force the hatch down tighter onto the fuselage. I also I plan to place some vaselene on the joining surfaces to help stop water getting in.
Yesterday I scouted my local ponds and found that my usual flying pond is now half covered with water lillies. But luckily I found a brand new pond that has no weed or lillies yet and has a perfect sloping bank.Today I took my floatplane out to this new pond for some practice water flying. I am glad I did as my water landings need a bit of practice to get back up to a good standard.
Ken
kensp is offline Find More Posts by kensp
Old May 15, 2011, 10:17 AM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
i'm also concern with elevator servo thanks to report...
will make cover for it
i'm also concern with front canopy... will modify with
higher inside border to prevent water in
i'm also concern with motor+ESC water dammage...
so i'v made near 100% enclosed motor pods:
My ESC's will sit inside the motor pod and i hope they
will stay pretty cool ? will see... (i dont use them as BEC
and are 18amp)
I'v set the ESC timming to high and motor start rock
solid... i wont take OFF before everything look 100%
reliable
ggtronic is offline Find More Posts by ggtronic
Old May 15, 2011, 12:25 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
What I did;
I removed the elevator servo and it had water in it :
when fully dryed it again worked normally ,
so I decided to take a new servo and fill the upper gear section
with petroleum jelly ( like you would stuff the shaft box on a boat)
then filled the bottem half with GE waterproof clear Silicone ,
this should make the the servo waterproof to where it is located
on the model
another small mod I did was to the water rudder I took an extra
control clevis and made my own longer less deep rudder from plywood
and mounted it on the clevis so as to allow it movement and not
break evertime it hit bottem - it also had a shallower draft and
worked well with out the use of D throttle .
pulsery2k1 is offline Find More Posts by pulsery2k1
Old May 15, 2011, 12:54 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
baddb1, What if you add some splash guard to the hull to divert the splash outward away from the props? TW
TripleW is offline Find More Posts by TripleW
Old May 15, 2011, 02:01 PM
kcaldwel is offline
Find More Posts by kcaldwel
The post-truth world
kcaldwel's Avatar
Joined Jan 2007
Common RTV silicone sealants are bad news around electronics. They contain acetic acid (vinegar smell), which will corrode the electronics you are trying to protect. The silicone oils in them can also migrate, and since they are non-conductive, they can cause problems in switches, connectors, or pots.
There are special electronic potting silicones, but they are harder to find (a very good electronics store possibly) and more expensive than the hardware store silicone sealants.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old May 15, 2011, 03:43 PM
chir72 is offline
Find More Posts by chir72
Space User
chir72's Avatar
Italia, Sardegna, Nuoro
Joined Dec 2007
This is my maiden flight..
Canadair CL-415 HK Maiden Flight (1 min 58 sec)
chir72 is offline Find More Posts by chir72
Old May 15, 2011, 03:53 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Very Nice! TW
Old May 15, 2011, 04:09 PM
ramw5p is offline
Find More Posts by ramw5p
United States, SC, Rock Hill
Joined Jul 2001
great flight chir72
What engines and prop are you using? Thanks
ramw5p is offline Find More Posts by ramw5p
Old May 15, 2011, 04:32 PM
chir72 is offline
Space User
chir72's Avatar
Joined Dec 2007
I use two turnigy 2830 1000 Kv with gws propeller 3 blades 8x4..
here some pics
Old May 15, 2011, 07:21 PM
baddb1's Avatar
Joined Jan 2009
Sure, that could be a solution. I had this problem on my Catalina and went to a 7X4 prop with no more water splashed into the props. So, I am thinking it could be just the prop actually striking the water waves and not being splashed from the hull...? I will try the smaller props and see what happens.
On the subject of water ingress into the hull,, after 4 flights now I have had absolutly NO water get into my hull, not even a drop! So the the stock setup seems to work fine for me. The hull and battery hatch area sits quite high out of the water which helps!
Old May 15, 2011, 07:26 PM
baddb1's Avatar
Joined Jan 2009
Nice flight!! Is that a camera mount you added on top?
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
