Old Apr 30, 2011, 11:13 PM
jdlilfan is offline
Find More Posts by jdlilfan
jdlilfan's Avatar
United States, IN, Indianapolis
Joined Mar 2010
Originally Posted by pulsery2k1 View Post
saucisse
then the final one the model must have dropped below
V2 ( safe single engine speed) and when you gave it
throttle it just rolled over and sprialed in.
about what would happen in a real twin on one motor.
once the aircraft drops below V2 the aircraft is no longer
controlable with full power on the good motor
so I don't think it was radio failure-
Actually I think you mean Vmc. Vmc is minimum controllable airspeed. It is the minimum speed under several factors in which a multi-engine aircraft can be certified to maintain directional control. Below that speed; torque, p-factor (or thrust), and asymmetrical aerodynamics overcome the ability to maintain directional control of a twin.
V2 to V2+10 is for FAR certified Part 25 aircraft. All it is is the speed required to maintain a 35 Ft. clearance off the end of a runway while taking off with a balanced field length. Commonly referred to as the "second segment climb" of the 4 segment certificated climb profile for single engine ops of transport category aircraft.
jdlilfan is offline Find More Posts by jdlilfan
Old May 01, 2011, 02:57 AM
huntingfield is offline
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
I am using a stand alone v-tail mixer to mix channel 3 and 4 for throttle differential. I have a Spektrum dx6i radio and use it's built in mixing feature to combine rudder ( now throttle) with aileron. I did have another y-harness for the rudder servo but as I have said throttle differential makes the rudder pointless now.
huntingfield is offline Find More Posts by huntingfield
Old May 01, 2011, 06:52 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
A little HD video of my maiden flight as promised. Hoping for another flight today. Only used my hatcam so excuse the video goof-ups. Also, ignore the date on video.....
cl415 (3 min 41 sec)
baddb1 is online now Find More Posts by baddb1
Old May 01, 2011, 10:52 AM
lupy is offline
Find More Posts by lupy
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
That took off much nicer than the video that nitroplanes took. May have to take another look at this one.
I don't like to fly behind trees, made me vervous just watching you do it...
Thanks for the view though. I want to see more when you get some more experiance with it.
lupy is offline Find More Posts by lupy
Old May 01, 2011, 01:48 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Look at the second takeoff on the nitroplanes video. It needs up elevator to really clear the water.
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old May 01, 2011, 05:29 PM
baddb1's Avatar
Joined Jan 2009
@Lupy - Yes I agree, I hate to fly behind trees too but our water is much higher than usual and there wasn't a clear view of the lake. Luckily the leaves are not out much so I could see thru the tree!
Nice plane though, lots of room for your FPV equipment!
I notice I needed a bit of up elevator too on takeoff. I also run a bit nose heavy so that may be why....
Old May 02, 2011, 06:39 PM
KC9TPL- Get Legit
Joined Aug 2007
That is too bad. It was a really pretty plane.
I'm wondering if these esc are failing because the becs are connected. I know that it isn't supposed to be a problem, but maybe one bec could be left unplugged.
Old May 02, 2011, 06:47 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
I had both esc disconnected and was useing a seprate 5 amp ubc
I popped a fet on the the left esc ,it was new , I test ran the motor.s to take watt / amp readings and it was ok - but it failed ????
pulsery2k1 is offline Find More Posts by pulsery2k1
Old May 02, 2011, 08:35 PM
KC9TPL- Get Legit
Joined Aug 2007
Bummer. What brand was it?
Old May 02, 2011, 08:52 PM
baddb1's Avatar
Joined Jan 2009
It sounds like a case of rotten luck and electronic infant mortality. Sorry to see the failure and resulting crash. Good thing it missed the car though!!
It was a beautiful looking plane but I have faith you'll whip her back into shape in no time!
I'll be doing a little re-motoring myself. I bought a couple of 2212-10 motors I'll be installing soon. After flying again yesterday, I realized it is much to sluggish for my liking with the "recommended" Hobby King motors.
Old May 02, 2011, 10:06 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
BloomingtonFPV
the esc was this one
http://www.hobbyking.com/hobbyking/s...idProduct=2165
but I have used thes turnigy esc with very good luck , including
3 other twins
just bad luck some glue some fill some paint and it will fly again
Old May 03, 2011, 01:18 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I have just opened my kit to check the contents and found that the tip plates for the wing were missing. Could someone please take a close up photo of the plate on the wing tip and give me the outside dimentions including the thickness of the plate. I have pleanty of foam to make replacement plates if I have the dimentions.
As a consolation an extra set of floats were included in my Kit.
Oher than the missing tip plates the kit arrived in good condition and I am impressed with its size. Not so big as to make transporting it a problem but big enough to make water handeling easy.
Ken
kensp is offline Find More Posts by kensp
Old May 04, 2011, 07:27 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
kensp
hope this helps
Old May 04, 2011, 07:31 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
well almost done ,
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
