Old Apr 27, 2011, 10:18 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
started mine , I purchased 2 kits one arrived ok the other had a lot of
dings that needed to be filled and painted, Home Depot does a
great job with color match - 2.99 you get a jar with enought
to paint several models, and a perfact match
I didn't like wing wires so I added two hard wood spars , next
to the the 2 very thin fatory spars. so no wing wires will be needed.
I also added flaps , its almost completed I just need to decide
how to power it ,I have a couple of diffrent motor's but will
most likly use the 2408-21's one powers my 26 oz tiger moth
very well so 2 should power this well .
should finish tomorrow , I removed the lousy decal by putting a
hot towel on it and it just lifts up
on the rudder I cut the end of the exit tube ,changed angle and
put vasiline on the rod -- better but still a lousy set up
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Apr 29, 2011, 05:39 AM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
Nice job! I can't wait to hear how you flap mod works!
Dak
Dakrat is offline Find More Posts by Dakrat
Old Apr 29, 2011, 06:34 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Looks good pulsery2k1! Honestly, you won't need flaps...this bird can fly so slowly it a joke!
saucisse is offline Find More Posts by saucisse
Old Apr 29, 2011, 07:25 AM
baddb1 is offline
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
I agree. I slowed my down to a crawl before landing which was very nice. I also had it literally hovering still while flying into about a 5 mph headwind.
I think I will try the Home Depot color match to touch up the wing screws, etc. Thanks for the tip!
Cool video to watch of the CL415 fighting a fire:
Canadair CL-415 (1 min 51 sec)
baddb1 is offline Find More Posts by baddb1
Old Apr 29, 2011, 07:55 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
I sort of knew I didn't need the flaps , but thought they would look nice
I decided to try to improve the ugly motor pods so I cut the end's
off made a fire wall and will try to make more scale cowls
should finish today and try flying it tomorrow.
Old Apr 29, 2011, 08:09 AM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
it's a damn shame these things are out of stock....
struggleforlife is offline Find More Posts by struggleforlife
Old Apr 29, 2011, 08:18 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Nitro will have them shortly
Old Apr 29, 2011, 04:49 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
[B][SIZE="4"]converted to a C-215 [/SIZE][/B]?
99% done , only 3 of the wing bolts will line up
but it looks good -- I could not stand there cowl's
and didn't want to waste time making new ones
so I converted it to a C-215 round engine
I just need to fix wing bolt and hopefully the weather will
be nice to fly it tomorrow
Old Apr 29, 2011, 07:10 PM
hpiguy is offline
Find More Posts by hpiguy
If it's R/C, it's all good.
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
That cowl mod looks really cool. And definitely makes your plane unique. Good job.
hpiguy is offline Find More Posts by hpiguy
Old Apr 29, 2011, 07:25 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
hpiguy
thanks , they did make a c-215 version of this
Old Apr 29, 2011, 07:32 PM
hpiguy is offline
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
I know, but you just might have the first electric R/C version of one.
Old Apr 30, 2011, 12:49 PM
Joined Feb 2011
very nice mod pulsery2k1 !!
How did you make the cowl?
Old Apr 30, 2011, 07:12 PM
huntingfield is offline
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
I have equipped both my Guanli Catalina and CL-415 with differential throttles. I also have the rudder channel mixed with ailerons to allow coordinated turns. From my expiences with the Catalina the aircrafts' rudder now seems to be redundant, in other words its a waste of a servo! I now fly the plane with no rudder input at all all turning is accomplished by throttle on the water and by a combination of throttle/ aileron in the air. I have now disconnected the rudder pushrod and secured the rudder to neutral on my CL-415 and will see how she flys. Has anyone else had similar findings?
huntingfield is offline Find More Posts by huntingfield
Old Apr 30, 2011, 07:35 PM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
really like your philosophy Hunt...
dont know yet, but i have the exact same scenario in mind for my CL415 ... the rudder watter fin is a waste of gramms and will get ript off on ground so i remove it including its control rod... also the rudder linkage was so poor ! change it with full efficient carbon rod ... i may kept the rudder opperational + your throttle mixing & also mix with aileron (i'm a poor pilot that like to fly with one stick only )
ggtronic is offline Find More Posts by ggtronic
Old Apr 30, 2011, 08:18 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Huntingfield- can you expand on how you do the mixing? I assume you have differential ailerons, so each aileron has one PWM channel. Then you also have two throttle channels; could one be the channel that you would ordinarily use for the rudder? I have a Hitec Eclipse 7 and every channel except 5 can be mixed, so I could use 1 and 6 for the ailerons and 3 and 4, or possibly 3 and 7 for the throttles.
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
