Old Apr 14, 2011, 04:56 PM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Not as hard as you might think.
I opted to run my wires through the wing. Filed some teeth on the end of a carbon-fiber tube, and just twist it through the wing. You stop, occasionally, and push the slug of foam out of the tube, with a dowel.
I think I'll take it right on out to the vicinity of the aileron servo.
Lancer31 is offline Find More Posts by Lancer31
Old Apr 14, 2011, 06:05 PM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
I'm not there yet, I always fly the plane several times before installing any FPV gear in it. Since the rear compartment underneath the wing was free up from the rudder servo this might be a good place to put the vtx and other gear. I will try to put the cam on the tail where there is that black cone shape thing...
As for power, 300W is IMO more then enough to move this rig with a GoPro and should take the ''stress''. Again being made out of EPS I'm more scared about rough landings then anything else.
Originally Posted by BloomingtonFPV View Post
Looks great! Where does the FPV gear go?
Do you think this would be robust enough with 300 watts of power in the motors to pull a gopro in a waterproof case off the water?
saucisse is offline Find More Posts by saucisse
Old Apr 14, 2011, 09:36 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
It's alive!!!
Well, it's done!!! Almost... need to install the wings bracing wires thing and it's done.
Here's a quick vid I did while testing it...gotta love the twin motors sound The cat don't seem to think alike...notice on the bottom right corner she's drinking...well not for long lol.
AUW is 1246gr or 2.75 lbs (including a 3s 3000mah pack)
*edit* looking back at the video I just noticed that the left motor's ESC does have brake ''on'' but not the right one.
HobbyKing Canadair CL-415 tests (0 min 49 sec)
Old Apr 15, 2011, 06:21 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Beautiful, I like that idea. I think I will route the wires that way too.
What size and type bit did you get to modify the props? Do you have a link? Do you think that process has weakened the blades at all?
Bill
baddb1 is online now Find More Posts by baddb1
Old Apr 15, 2011, 06:25 AM
baddb1's Avatar
Joined Jan 2009
http://www.youtube.com/watch?v=CRiCTy8QJBA
Whoa, yeah make sure both ESC's are set to either brake on or off. That could be a big problem on landing if they were set differently!
It looks good! Good luck on the maiden and be sure to get some video!
Still waiting for mine to arrive, <sigh> going on 3 weeks now! It should be any day now...
Old Apr 15, 2011, 08:23 AM
hpiguy is offline
Find More Posts by hpiguy
If it's R/C, it's all good.
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
Very nice.
Do you have a wattmeter to tell us what kind of draw you are getting?
hpiguy is offline Find More Posts by hpiguy
Old Apr 15, 2011, 08:33 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Sure! Was about to post it... 259.4 watts @ 23.74 amps. That is with the stock 8x3.8 props that came with the kit. Going try different prop sizes.
Old Apr 15, 2011, 08:50 AM
Lancer31 is offline
Joined Jun 2005
Bill
I used a 1/2" aircraft counterbore, with a 1/8" pilot, but if I had it to do over, I would buy a 17/32" counterbore, for these props, so I wouldn't have to do so much hand-fitting & trimming. Check here;
http://www.spenro.com/aircraft-count...ers-p-414.html
Since I have removed half of the material from the hub, each propeller is obviously greatly weakened. The plan is to use a threaded shaft, with a pair of large-area, #6 washers & nuts, to encapsulate the entire hub area in JB Weld, a very strong metal filled epoxy. Once so treated, finished & balanced,
a very thorough & careful spin-test will be conducted.
Disclaimer: Not everyone will have the means & wherewithall to make such
modifications, therefore I must point out that I am only reporting on my own activities, without recomendation.
Old Apr 15, 2011, 01:28 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Well now it's ready for the maiden flight which will probably be tomorrow if it's not too windy.
I've put my 720p keychain cam on the tail to record the maiden flight:
...and mark position of the lipo to have the correct CG with or without the cam:
Small clip with the cam just to give a rough idea, will have to fix the vibrations issue:
CL-415 test (0 min 50 sec)
Old Apr 15, 2011, 01:35 PM
baddb1's Avatar
Joined Jan 2009
Nice! Is that a 3000maH pack in there like you mentioned above? It just seems pretty far forward for that large of a battery....
Old Apr 15, 2011, 01:40 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Yeah it's the 3000mah pack. It's that forward because I've put my modded 720p keychain on the tail + rudder servo is also now in the tail.
When removing the keychain cam you can see the mark where the pack is going to be for proper CG.
Old Apr 15, 2011, 02:43 PM
Lancer31 is offline
Joined Jun 2005
Best of luck to you!
Looks ready to fly!
Old Apr 15, 2011, 03:54 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
That's good news. That means that I can move the batter back when I put a gopro on it as well. Can you try it with a gopro in a waterproof case balanced in the middle of where the canopy would go (and yes I'm assuming that everyone has a gopro on rcgroups...).
Good luck with the maiden. Hopefully all your lakes are free of ice at this point. Tough winter for your part of the country.
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Apr 15, 2011, 04:16 PM
Lancer31 is offline
Joined Jun 2005
Not everone....
I probably would, if they could only lose that stupid rubberband horizon!
Just can't live with that.
Old Apr 15, 2011, 04:22 PM
ramw5p is offline
Find More Posts by ramw5p
cincinati, oh
Joined Jul 2001
wow..love the camera
i have no idea about cameras...what are you using? how do you power it? Thanks for any info on that, i have no experience with cameras on rc planes. Looks great.
ramw5p is offline Find More Posts by ramw5p
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
