Old Apr 12, 2011, 09:10 AM
huntingfield is offline
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
Originally Posted by Lancer31 View Post
Thank you very much for the info & the links!
A few years ago, a friend built a twin engined flying boat with differential throttle controls. His was done mechanically, but the end result was splendid!
No one should have to operate a flying boat without this benefit.
Glad to help. Using throttle differential for steering on water is great. My Catalina can turn within its on length. I also mixed it in with ailerons using my radios aileron rudder mix (Opitc 6 ). Using this setup makes the rudder servo redundant. My plane will now do coordinated turns ( in flight ) with no rudder input at all. When I flew the CL-415 using the stock water rudder I found it was quite ineffective in even in calm wind conditions, in addition its just hanging down back there waiting to get broken off.
huntingfield is offline Find More Posts by huntingfield
Old Apr 12, 2011, 10:24 AM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
I have ordered my mixer.
From Dionysus Design. Cheaper ones can be bought, but I have had good luck with this guy. He says it is better, and I believe it.
http://www.dionysusdesign.com/produc...roducts_id/174
Lancer31 is offline Find More Posts by Lancer31
Old Apr 12, 2011, 12:29 PM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Here is how to do throttle differential with a capable radio (no external mixer). I did it with my DX7 on my Catalina and it worked great!
http://www.rcgroups.com/forums/showthread.php?t=489099
baddb1 is online now Find More Posts by baddb1
Old Apr 12, 2011, 12:30 PM
va3mw is offline
Find More Posts by va3mw
va3mw's Avatar
Joined Sep 2008
Originally Posted by kensp View Post
What is the shelf life of Plastidip? Itís horribly expensive and I would not use much each time I use it.
Ken
I soak all my servos and electronics in Corrosion X http://www.corrosionx.com/marine.html. I think here in Canada I buy Corrosion Block.
I have totally drowned my Seawind, drained the water out of it and then flown 2 minutes later.
This stuff is an oil like substance that you just coat everything with including the ESC's. For the ESC's, I actually take off almost all the heat shrink and just leave enough to hold the heat sink in place. I then cover it with Corrosion Block.
You can even coat the ESC's in a conformal coating first which is like a sealing fluid and that will totally protect them.
Now, I can't wait for these to be back in stock so I can add it to the fleet.
va3mw is offline Find More Posts by va3mw
Old Apr 12, 2011, 03:47 PM
aferguson is offline
Find More Posts by aferguson
Joined Apr 2006
"That being said, it is a beautiful, impressive model, worth waiting for!"
Yes, i'm quite looking forward to it. I'm normally a warbird guy, but this one has really caught my interest.
aferguson is offline Find More Posts by aferguson
Old Apr 12, 2011, 03:51 PM
Joined Dec 2007
Originally Posted by baddb1 View Post
Here is how to do throttle differential with a capable radio (no external mixer). I did it with my DX6i on my Catalina and it worked great!
Thanks for the heads up. I have a DX6i and didn't know about this. Thank you.
Old Apr 12, 2011, 04:35 PM
hpiguy is offline
Find More Posts by hpiguy
If it's R/C, it's all good.
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
I want to see someone convert their foamy to a water bomber like this guy did to his nitro one.
CANADAIR CL-215 rc-3 (9 min 49 sec)
hpiguy is offline Find More Posts by hpiguy
Old Apr 12, 2011, 07:58 PM
hpiguy is offline
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
OK, post office says it's here. We'll see if it really is this time or if it's yet another China order I forgot all about like last time.
Also, I see HK is now out of stock of this plane. Lucky us that ordered it right away.
Old Apr 12, 2011, 08:02 PM
baddb1's Avatar
Joined Jan 2009
http://www.youtube.com/watch?v=ywSHD...eature=related
Cool stuff. I would love to try it.
Old Apr 13, 2011, 09:01 AM
Lancer31 is offline
Joined Jun 2005
Warning!
As we gain experience with this big, beautiful model, things will come to light that should be shared & adressed.
Here are two such items; The rudder pushrod is of low-grade steel, and passes through a plastic tube, between the servo & the rudder horn.
I noticed that mine was sticky, & difficult to move, and it has not even been near the water! (It is rust)!
I also noticed that the rudder tube stantion, on the servo end, was not glued down. These are typical of the things we must always be on the lookout for, in kits. The stantion is an easy & obvious fix. The threaded-end
steel pushrod offers several possibilities to fix. my first thought was to use a
lighter, stronger, and completely waterproof carbon-fiber rod, with appropriate end fittings, but another good way would be Sullivan plastic pushrods. your choice.
Old Apr 13, 2011, 09:47 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Lancer31: This is exactly why I will put the rudder servo on the tail...I did not like the quality of that tube/rod combo and IMO changing/fixing the whole thing is as much work as relocating the servo in the tail. The rod in the tube was already showing signs of corrosion and was draggy like you've said.
I'll post some picture and comments of the rudder servo being installed in the tail when done.
Cheers!
saucisse is offline Find More Posts by saucisse
Old Apr 13, 2011, 10:38 AM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
lancer+saucisse : i received my kit and agree with your comment,
rudder linkage is crap and paint seems not dry yet and still sticky
still we got plenty of things for our money
i also thought of CF linkage inside actual rudder tube , or
may go with proximity servo as suggested by saucisse
power setup : i use these motor
to get 300W peak while staying light and i will have a fully enclosed split mode motor mount
(thin aluminium plate that will block motor pod opening while
holding these motor inside the pod )
ggtronic is offline Find More Posts by ggtronic
Old Apr 13, 2011, 11:55 AM
hpiguy is offline
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
Mine is here!
It wasn't double boxed though. They just took the box top, ripped it open and taped it on backward so it was brown. Probably when they were tossing in the extra stuff I ordered.
But it all seems in good shape from what I can tell in my office.
I'll unbox it all tonight and double check it all.
Old Apr 13, 2011, 12:49 PM
Turbobeaver is offline
Find More Posts by Turbobeaver
Ottawa,Canada
Joined Dec 2003
Howdy!I'm not quite understanding your choice of motor for this plane.The specs on the 2208-14 1450kv motor according to RC Timer, show a maximum prop size of only 7x4.5 on 3S.I actually have this motor and run it on an Aerocat on 3S with 6"x4"-5" props so unless I'm not fully understanding your intent,I don't see how your going to swing a larger diameter prop like say a 8"x3.8"?Seems awful close to the end limits of this motors capabilities.I know sometimes these motor specs are not quite accurate but I'm curious to find out your thinking on this one.My CL-415 is still in the mail system.I've got a few motor choices up my sleeve but haven't really settled on a final choice yet.I'm curious to see what others are using and how there models perform.
Cheers!
Turbobeaver is offline Find More Posts by Turbobeaver
Old Apr 13, 2011, 01:03 PM
ramw5p is offline
Find More Posts by ramw5p
cincinati, oh
Joined Jul 2001
This is a great thread
I have to have this plane...obviously!!!..just trying to get up the nerve to stomach that shipping cost...more then the plane to usa...anyhow. I am confused as to why some people are ordering BEC circuits? Isnt this in the ESC or your RX??? Is this a 2.4 thing, i still have older equip? Thanks for any knowledge here. Also, any word on someone doing Canadian decals for this thing? Also...sorry...has anyone come up with an easy motor and mount option? I see lots of discussion but have not yet seen an easy way to do this, just talk that the stick mount option wont work. THANKS.
ramw5p is offline Find More Posts by ramw5p
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 01:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 06:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 05:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 12:36 PM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 10:54 PM
