Old Mar 22, 2011, 03:50 PM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
HobbyKing CL-415 Canadair 1390mm wingspan Foam Kit
Just wondering if you guys have seen this kit yet? Personally Im going to wait till the US warehouse gets it in stock.
http://hobbyking.com/hobbyking/store...dProduct=16548
JGuilty13 is offline Find More Posts by JGuilty13
Old Mar 22, 2011, 04:18 PM
gotime242 is offline
Find More Posts by gotime242
Boynton Beach, FL
Joined Jul 2005
Wow, i havnt seen that. Id like to hear how it flys.
gotime242 is offline Find More Posts by gotime242
Old Mar 22, 2011, 10:54 PM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
subscribed... ordered... will sea
ggtronic is offline Find More Posts by ggtronic
Old Mar 23, 2011, 06:38 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I plan to order one tomorrow morning. I have previously scratch built a 52 in span Catalina and converted a GWS Islander to a seaplane.
When I built and flew the Islander conversion I thought that I would like a larger seaplane of similar configuration and the CL-415 immediately came to mind. Now this kit looks to be just what I want.
Ken
kensp is offline Find More Posts by kensp
Old Mar 23, 2011, 08:21 AM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
The New Canadair CL-415 Water Bomber Amphibious Plane (9 min 2 sec)
Old Mar 23, 2011, 08:39 AM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
ggtronic
Thank you for posting the video. If I had not made the decision to buy before watching the video then I would definitely be buying it now. It flies a bit faster than my Catalina but not by too much.
Ken
Old Mar 23, 2011, 09:04 AM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
oh and congrag on your black catalina... looks great !
agree with you... seems little heavy thus flying faster
maybe 1100g AUW ?
I want to fly it in FPV mode so weight is important !
i`m totaly sold to this plane since i live
40km away from the BOMBARDIER plant !
http://www.bombardier.com/en/aerospa...01260d80018aa7
Oh & thanks to Saucisse down here who actually find this plane
and gave hint to me !
Old Mar 23, 2011, 09:50 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Thanks for posting the video my friend! I also have one coming in (ordered yesterday morning) so cannot to put my fpv gear on it and go to the lake!
saucisse is offline Find More Posts by saucisse
Old Mar 23, 2011, 12:27 PM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Originally Posted by ggtronic View Post
Nice plane! I wonder what the Nitroplanes.com price will be..?
This looks like it flies very similar to my Catalina, which is one of my favorites! I guess I now have something to spend my tax refund on!!
baddb1 is online now Find More Posts by baddb1
Old Mar 23, 2011, 05:54 PM
hpiguy is offline
Find More Posts by hpiguy
If it's R/C, it's all good.
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
I started a thread about this in the Parkflyer forum as well when I got the HK email.
Cool plane.
hpiguy is offline Find More Posts by hpiguy
Old Mar 23, 2011, 06:04 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
My 415 has been ordered. I chose the following to go in it.
TURNIGY Bell TR2410-12Y 1000kv Outrunner http://www.hobbyking.com/hobbyking/s...idProduct=6664
HobbyKing 12A BlueSeries Brushless Speed Controller http://www.hobbyking.com/hobbyking/s...dProduct=11429
HobbyKing Micro UBEC 3A / 5v http://www.hobbyking.com/hobbyking/s...dProduct=15212
HXT900 9g / 1.6kg / .12sec Micro Servo http://www.hobbyking.com/hobbyking/s...?idproduct=662
I plan to fit GWS 9 x 5 DD propellers which are the same diameter as the ones used in the Nitroplanes video. http://www.gwsprops.com/direct_drive.htm
Once the Model is shipped I will purchase some ZIPPY Flightmax 2200mAh 3S1P 20C batteries from the Hobby King Australian warehouse http://www.hobbyking.com/unitedhobbi...dProduct=16753 It should take about 2 weeks for the kit to arrive.
Ken
Old Mar 23, 2011, 07:40 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
I have looked on the Nitroplanes web site to try to find more details of the CL-415 but it is not yet on their site. They did list a similar size Catalina kit that is priced at US$44.95 http://www.nitroplanes.com/4chcararecoe.html
Ken
Old Mar 23, 2011, 08:51 PM
ggtronic is offline
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
hello Kensp
i`m not shure your 12A esc will keep up ?
sometime its better to use higher amp in case of
motor upgrade (your motor description ask for 20ampESC)
i already had a twin power setup in stock to built something else...
motor: 40g 9$ http://www.rctimer.com/index.php?gOo...4&productname=
i may use 8x4.7 prop to limit max amp to 18 ?
ESC : 18g 10$ http://www.rctimer.com/index.php?gOo...8&productname=
this combo should provide 300w peak to retrieve that
ship from water...
Old Mar 23, 2011, 09:06 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
hello Kensp
I normally prop my motors to run at half the rated maximum Watts. Then they tend to last longer and run at higher efficiencies.
For my set up MotoCalc predicts a current draw of 8.3 Amps per motor, a 1:1 thrust ratio and a top speed of 2 1/2 time the stall speed. In my opinion to go for more performance will give lower efficiency and so waste energy. Going to an Amp draw of 12.5 amps will drop the efficiency of the motor from 70% down to 42%. The power losses will rise from 26 watts to 77.5 watts and most of these losses are caused by heat generation. So the motor temperature will rise from around 100 deg F to 400 deg F.
Ken
Last edited by kensp; Mar 24, 2011 at 12:28 AM. Reason: Add text for clarity and coorect Grammer
Old Mar 24, 2011, 03:01 AM
Rudi is offline
Find More Posts by Rudi
Rudi's Avatar
Österreich, Oberösterreich, Laakirchen
Joined Jan 2001
Hi Guys,
I build a lot of wonderful models (included a CL-415) and I enjoyed every second of building and flying but I was never able to build one for 38.- bucks I ordered one just for summer fun on our wonderful lakes here in austria
Rudi
Thx for the video !!!!
Rudi is offline Find More Posts by Rudi
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 01:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 06:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 05:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 12:36 PM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 10:54 PM
