More music. Useful if you want to mod the gear doors... pitot tube ....gun covers...see what a balanced spinner looks like ...and hear a sound system. How are those sound systems going I wonder ?
I couldn't stand were some of those people are after seeing Aros's video.
Or you could go back to Split Enz. Rob / Ray - we're getting some of your surplus rain. Thankyou. JForbes - Hope you do decide to buy one of these and give it a new AMERICAN livery.Would make a nice change wouldn't it ? |
Found this posted over here http://www.rcuniverse.com/forum/m_11212181/tm.htm Just something to keep us in touch.
Bryan Cox again - " The most enjoyable exercise we performed was the line astern aerobatics' with 4 P40's in open line astern. This was no doubt designed to give us experience in throwing the aircaft around in close proxity to other aircraft, as in a dogfight. The leader was always one of the instructors who were experienced combat pilots and he would take us to about 10,000 ft then commence up to 30 mins continuous aerobatic manoeuvers, generally consisting of loops, rolls, upward rolls, roll off the top of loops and half-rolls. Entry speeds were about 300 mph for loops, 330mph for rolling off the top of loops, and over 400mph would give several upward rolls depending on the rate of roll. With more than four tons of streamlined metal wapped around you, it was quite easy to reach these speeds by merely pushing the nose down with no power increase necessary. At such speeds, which were indicated airspeeds, it was not difficult to black youself out by being a little rough on the controls - Bob Liddle's advice in the old Tiger still held good. Although hard to believe now, I had less appreciation then of the difference between indicated and true airspeeds than the average private pilot does today! Nor was the relationship between compressibility and the speed of sound known at the time - all we knew was that at some extremely high speed the air would stop flowing over the wings and fuselage and compress, causing the aircraft to break up. I fequently seemed to draw #4 position at the rear of the group and would achieve frightening speeds due to the whiplash effect of being at the end. On one occasion I vividly recall, F/O Pat Bradlley was leading the section with myself at the rear, and after a number of continuous manoeuvers we all got strung out a little and to catch up I applied almost full power and was gaining on the front 3 aircraft at a great rate, at least 50mph faster than they were flying. Just as I began to decelerate, Pat Bradley and the other 2 Kittyhawks rolled on their backs right on 6000ft to pull through underneath as in the second half of a loop. I immediately rolled inverted with them, notwithstanding that I was travelling much faster than they were, and about twice as fast as one would normally be at the top of the loop! By the time I was pointing vertically downwards the ground was rushing up at a frightening speed, and without time to look inside at the airspeed indicator or altimeter I found that I was commencing to black out. Trying to restrict the back pressure on the stick so as not to black out too violently I had a momentary blurred vision of green grass and fences at close quarters before once again enjoying the reassuring sight of beautiful blue sky. It took me some time to rejoin the rest of the section still exercising up above, and I realised why P40s fairly regularly dug deep holes in the ground around the Feilding and Marton areas, and also knew what it felt like when expecting such an impact to be imminent." Bryan Cox started his own very succesfull business in 1966, the " Manukau Flying School. He became the Chief Flying Instructor with Motor Holdings Aviiation Ltd. |
In touch..., in deed..!
Smooth flying there and those were super landings. I can't help but comment that they seem to have 25 or so acres to fly over! Very nice field. I figure I make do with about 3 to fly over at a school field and really get to 'stretch out' with 10 at a construction site for the P-40N. Gosh, I wouldn't mind the noise if weren't just, well, noise. Hard to relate the sound of the two strokes to flying any more. If they were mine though, I'd probably be tickled they got along so well. Still would like to see and hear an in-line 2.0 Saito twin performing in a P-40, Spitfire or P-51. Seems like it would be just right for about a 2m span plane. |
http://www.hobbyking.com/hobbyking/s...dproduct=18911 Retract Upgrade http://www.hobbyking.com/hobbyking/s...dproduct=20969 They're both out of stock at the moment but they usually restock pretty regularly. Tig |
Hawk , I started a thread on the new FMS rotating gear for the 66" Corsair .
I think they would be a great match for the P40 . $69 and they come with two wheels and working struts |
Latest blog entry: The Ultimate Hobby shop "Orange...
Here: http://www.rcgroups.com/forums/showthread.php?t=1814939
Until he, or someone, can put up the center-to-center distances between the mount screw holes and the dimensions of the part of the unit that fits down into the wing pocket, no telling how it would fit into the H-K P-40N without heavy modification. My hunch is that the units are a good bit larger than the stock plastic pockets. He shows the overall length, retracted, to be 8 1/2". Measurement of the same thing on this P-40 is 8 3/16" so is too long to fit as is into the plane. He shows the unit body length to be 3 5/8" whereas the same part on the P-40N is just 3" . |
Scale speeds...(allow me, oh no not again !! ). See http://www.rcgroups.com/forums/showp...postcount=4222
"entry speed for loops 300mph....... Divide by 6 = 50mph. "400mph plus"................................... Divide by 6 = 66.6666mph plus. Does that sound right ?
| Thread Tools | |
| For Sale Pulse, Big Stik, Mustang all ready to fly | kyle1745 | Aircraft - Fuel - Airplanes (FS/W) | 7 | Mar 26, 2011 09:43 PM |
| Sold 4 blade prop and spinner for big Airfield P-51 EPO Mustang $12 shipped | RCGill | Aircraft - Electric - Airplanes (FS/W) | 1 | Feb 24, 2011 09:04 PM |
| Sold JPower/HobbyKing 61in Big Foam Mustang | Mikemynameis | Aircraft - Electric - Airplanes (FS/W) | 7 | Nov 30, 2010 08:08 PM |
| Discussion big ol' mustang | Driggs | Electric Warbirds | 4 | Nov 22, 2010 07:38 PM |
| Mustang "Big Beautiful Doll" | Tracon | Scale Fuel Planes | 0 | Jun 14, 2005 02:11 PM |
