Alien Aircraft Dragon Seaplane
Hi
I was wondering if this plane could be converted to nitro?My mane question is how to rig the throttle servo. Here is a link http://www.alienaircraft.com/k304.htm |
Milton, WI USA
Joined Dec 2007
Throttle- No Sweat
Tom |
Yeah it is convertible. A .049 engine would work fine.
For a throttle you use a throttle cable, and mount the throttle next to the aileron servo on its side and route the throttle cable up to the engine as needed. Looks like it might be a three channel setup too, so you'd only have rudder. elevator and throttle then, if that is true. |
Latest blog entry: My Low Wing plane
Joined Oct 2008
Joined Jul 2007
The problem would be redisigning the pod for a fuel tank. I have a 'House Of Balsa Chea-Pass Float Plane' that I have a OS10LA in at 2 lbs and 318 sq inches it flys great. A .10 on Dragon Seaplane would be a ton of power. Prop clearance would also be fine as the plan calls for a 7x4 which is what I run on my Floatplane. If you can put a tank behind the engine you would be ok. Towers out of stock of the Cheap A** or I would suggest you get it instead.
Here is a link to the Chea Pass http://www3.towerhobbies.com/cgi-bin...?&I=LXAGD2&P=0 |
Joined Jul 2007
This kit is definately different but perfect for a .10LA. Here is a short video..very short and very poor. http://www.rcgroups.com/forums/showa...8&d=1301278574 |
Joined Nov 2009
The Dragon should fly pretty good with a .049 (TD or Norvel). The aileron servos are out in the wings so there is plenty of room on the bottom of the center section for the throttle servo. You'd just have to modify the pylon to hold the fuel tank.
Keep it light and you will be happy with the performance. The hull is designed to optimize water performance so doing R.O.W.'s should not be a problem. It is a lot different than the Aqua Star in this respect. They may look similar, but the Dragon is a completely new model. I know because I designed them both. Tom |
Joined Jul 2007
Very nice looking plane Tom. I might look into one of the Dragons for next winter. It looks perfect for a "Go fly and get back in the house before I get cold" kinda plane. My glow powered floatplane I have to spend time fueling and starting it in the cold. An electric Dragon looks like a good snow plane.
| Thread Tools | |
| Discussion Alien Aircraft Blinker | EdLokken | Flying Wings | 21 | Apr 15, 2012 02:34 PM |
| Discussion My Alien Aircraft models | EdLokken | Parkflyers | 2 | Aug 01, 2011 03:20 PM |
| Question anyone deal with Alien Aircraft? | sgtdirt | Vendor Talk | 8 | Jul 16, 2011 01:18 PM |
| Build Log Alien Aircraft Gadget | EdLokken | Parkflyers | 9 | Aug 25, 2010 10:08 AM |
