Old Mar 21, 2011, 06:47 PM
335driver is online now
Find More Posts by 335driver
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Question
What does OPTO mean?
I was looking at an Exceed RC 80A ESC and it said 80A OPTO
(without BEC) I know that means you need a separate BEC unit wired in to provide power to rcvr & servos. Is that all OPTO means? Or is it something else. I have several Exceed RC ESC's and they seem to work for me. Anyone else use these or am I swimming against the flow?
335driver is online now Find More Posts by 335driver
Old Mar 21, 2011, 07:36 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
OPTO is supposed to mean 'opto-coupled', where the throttle signal is coupled into the ESC via a light beam. The idea is that there is no direct electrical connection between the receiver and the business end of the ESC, therefore stopping electrical inteference from travelling down the wiring into the receiver.
However there quite a few cheap 'OPTO' ESC's available that don't have an opto-coupler, and should really just be called 'No-BEC'. For most applications these work fine. If you have a 2.4GHz radio then interference won't be a problem, and if you connect an external UBEC to the motor battery then it bypasses the opto-coupler anyway.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Mar 21, 2011, 08:48 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Thanks for the explanation, Bruce. I really had no idea what it meant?
Old Mar 22, 2011, 03:25 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
If it's a real opto ESC, you always need to use all three wires to the receiver. Don't cut the red one, like you normally do with a regular ESC, when using a separate receiver power supply.
abenn is offline Find More Posts by abenn
Old Mar 24, 2011, 07:35 PM
Rosie is offline
Find More Posts by Rosie
Joined Apr 2006
Hi Guys .. I have a Jeti JES 40 - 3P OPTO ( 6 - 10 NC ) that I used with a nicad
powered plane. My question is ... can I use it with a 3S lipo battery ? Any information
will be appreciated.
Rosie
Rosie is offline Find More Posts by Rosie
Old Mar 28, 2011, 07:15 PM
joallen001 is offline
Find More Posts by joallen001
Tennessee
Joined Dec 2005
So how do you determine if you should cut the red wire on the esc.
joallen001 is offline Find More Posts by joallen001
Old Mar 28, 2011, 07:48 PM
Joined Jan 2001
Try powering the receiver directly from the ESC (no receiver battery or external UBEC). If this works then the ESC has an internal BEC, so you should cut the red wire when using an external receiver power source.
If the receiver dosn't work directly off the ESC then it does not have an internal BEC, so you should not cut the red wire (this applies to all 'OPTO" ESC's).
Old Mar 28, 2011, 08:20 PM
FastFlite is offline
Find More Posts by FastFlite
United States, FL, Melbourne
Joined Mar 2011
Opto isolator.
FastFlite is offline Find More Posts by FastFlite
Old Mar 28, 2011, 08:26 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
I've been cutting all the red wires or at least not plug them in...(even opto ones)
if you don't cut the red wire off and it plugs into the receiver, I take it this would share the same place (plug) with the power wire from the external BEC. Is that the recommended setup???
rcalldaylong is offline Find More Posts by rcalldaylong
Old Mar 28, 2011, 08:52 PM
Joined Jan 2001
A true opto-isolated ESC will not work if you cut the red wire. It needs 5V from the receiver to power the input side of the optocoupler.
You can wire an external BEC into the ESC's servo cable, and you can even use the red wire to feed battery voltage into it (but you will have to re-route the wire to battery +ve at the ESC end). You also need to splice into the negative (black/brown) wire. Doing it this way eliminates extra wiring, and frees up an extra channel on receivers that don't have a dedicated battery port. However it may be a bit tricky to impliment.
Alternatively you can just use a Y cable, but this is bulkier and may reduce reliability (one extra connector for the power to go through). It's best to wire the UBEC directly onto one leg of the Y cable.
Discussion Reynolds Number - what does it mean ? knlever Modeling Science 18 Oct 01, 2010 11:22 AM
Discussion Hyperion EOS - What Does It Mean Acrow Batteries and Chargers 4 Aug 31, 2010 04:26 AM
Discussion What does "opto" and "dual conversion" really mean? Buzz Bomb Electric Motor Design and Construction 2 May 27, 2006 02:58 AM
What does OPTO in an ESC mean??? aireze Power Systems 12 Dec 28, 2002 06:17 PM
