Old Mar 21, 2011, 04:59 PM
Hobster is offline
Find More Posts by Hobster
He who dares ... repairs!
Hobster's Avatar
Joined Jun 2005
Aerofoil analysis help
For several years I've had a Mini Graphite wing (MH32 airfoil) on top of a cupboard gathering dust. My plan back then was to fill it full of carbon and turn it into a DS hack. But then I got Opus MCTs and forgot about it. Recently I started playing with XFLR5 airfoil analysis software and ran some results..
What surprised me is that according to the software, the Mini Graphite's MH32 section is much lower drag than the Opus' RG14 at >300mph (Re 2.5e06 to 3.0e06 and Mach 0.4 to 0.5). Lower Cd even than Rk40 and DS19, popular sections for DS. Am I running XFLR5 too far from its design? Using the software wrong? Are there other aerofoil properties that also need to be considered?
Hobster is offline Find More Posts by Hobster
Old Mar 22, 2011, 11:51 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Hobster, I'm not sure what you did. I just ran 2 identical wings (3D analysis), one with the MH32 and one with the DS19 at 300 mph. The CL(CD) is different than your findings. The DS19 definitely has lower drag at low to moderate CL. In fact the MH32 wouldn't converge above 5* at this speed. I normalized and refined the airfoil before processing.
When you defined the polar did you use the same definition for each airfoil?
wyowindworks is offline Find More Posts by wyowindworks
Old Mar 23, 2011, 12:02 AM
Just fly it!
Cody, WY
Joined Nov 2007
Here is the CL(CD) polar with the RK40 added. Both the DS19 and the RK40 have better performance with this wing at 300mph. This again is a 3D analysis.
Old Mar 23, 2011, 12:31 AM
Just fly it!
Cody, WY
Joined Nov 2007
Here is a 2D analysis at Re 1,000,000 and 2,000,000. Polar shows DS19, RK40, an MH32.
Old Mar 23, 2011, 01:01 AM
Just fly it!
Cody, WY
Joined Nov 2007
Hang on a second...
Oooops. I just realized that I was comparing modified airfoils.
Here is a 3D analysis of the original 3 foils on an average 2 meter wing at 300 mph. The MH32 has higher drag than both the DS19 and the RK40 at low to moderate CL.
Old Mar 23, 2011, 02:45 PM
Hobster is offline
Hobster's Avatar
Joined Jun 2005
Many thanks wyowindworks for replies. Your results look more like what I would expect.
I originally tried 'Normalise' and 'De-rotate' the foil but had little effect. This time I tried Normalise and 'Refine-globally' which appears to interpolate more points on the airfoil (so hopefully more accurate calculations)
The results are more bunched up but still show mh32 as low drag (at Re 2.0e06, Mach 0.4)
Guess I will have to read the manual!
Old Mar 23, 2011, 09:45 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Maybe you've accidentally discovered a new airfoil masquerading as an MH32. Better post up the coordinates
before it is lost.
ian
Daemon is offline Find More Posts by Daemon
Old Mar 23, 2011, 11:42 PM
OZPAF is offline
Find More Posts by OZPAF
Sydney
Joined Apr 2009
Hobster I also did a quick check as a 2D comparison on XFOIL at around 300mph on an average 200mm chord which was 1.8 to 2,000,000 Re.
It supports Wyowind's comments both the DS19 and the RK40 have lower drag especially at < 0.5CL.
The MH32 is not too bad and would be easier to land perhaps although it would require lots more ballast to fly with similar L/D to the DS19 and the RK40.
Give it a try if you have it.
John
OZPAF is offline Find More Posts by OZPAF
Old Mar 24, 2011, 03:18 PM
Hobster is offline
Hobster's Avatar
Joined Jun 2005
before it is lost.
ian
Beginning to wonder, lol. Coords were downloaded from UIUC Airfoil Database.
Old Mar 24, 2011, 03:28 PM
Hobster is offline
Hobster's Avatar
Joined Jun 2005
John
Thanks John.
Your graph appears to shows that mh32 is lowest Cd between about Cl 0.4 and 0.8. According to my alpha/cl graph, that equates to AoA of about 0.5 to 4 degrees. So it might be quick if I dont yank the turns too hard. Perhaps I should just give it a try as you suggest.
I was originally most interested in mh32 vs rg14 (9% ish) to compare against the Opus wing, so interested in any comparison against that if any one has the time
Thanks again, Steve
Old Mar 24, 2011, 05:32 PM
OZPAF is offline
Sydney
Joined Apr 2009
Steve, these should help.Note the RG14 appears to have an edge on the DS 19 at CL's >0.3.
Girsberger certainly designed some classic foils.
The DS19 indicates however why it is so popular. A very fast and forgiving airfoil from these plots and would carry more weight.
John
PM Just discovered this on a reread.I Stumbled a bit here Steve wrt to the drag of the RG14. The RG14 has less drag(should have shown< instead of >) than the DS19 below approx 0.3CL - which may not mean much as Adam points out below.
My guess would be that the DS19 would be the better overall choice.
Old Mar 24, 2011, 06:07 PM
Hobster is offline
Hobster's Avatar
Joined Jun 2005
Many thanks John
Old Mar 24, 2011, 06:17 PM
Just fly it!
Cody, WY
Joined Nov 2007
BTW, a 2M with 480 square inches flying 300 mph, weighing 80 ounces, and pulling 50 G, requires a CL of .326. If you hit 80G you need a CL of .521. Flying the MH32 tighter may be the faster way to fly it...if it can actually get up to 300.
Old Mar 31, 2011, 04:21 PM
Hot Air is offline
Find More Posts by Hot Air
Hot Air's Avatar
United Arab Emirates, Dubai
Joined Sep 2009
Assuming a flight path of a circle (not quite real but a rough approximation of DS) and std density of 1.225Kg/m^3, using the above data, you would need to fly a circuit every 1.7 seconds. I don't think even aliens like Spencer L could do that.
Flying the same weight and wing area plane at 300mph in a circle at a more human lap time of say 4s would require a CL of approx 0.14. If you inherited SL's flying skills and flew 3.3s laps, a CL of approx 0.17 would be required.
The point I hope to illustrate is that, despite the tremendous 'G' forces, because of the high speed the actual CL or alpha required to generate the necessary lift force is surprisingly low. L= CL 1/2 p v^2 S. Because the value of v^2 is very large, in order to provide the required lift force the value of CL is low. Therefore, provided you can launch and land, an aerofoil with lower drag at low CL should be better.
I worked it out thus:
300mph = 134 m/s. Circuit time = 4s, therefore circumference is 134 x 4 = 536m.
radius = c/2pi so 536/2pi = 85m
Centripetal acceleration = v^2 / r so 134^2 / 85 = 211m/s^2
Force = mass x acceleration (80oz = 2.27Kg) so F = 2.27 x 211 = 479N. This is close as dammit to the lift force required to fly the plane in the assumed circle. You can work out the total lift vector required to account for the vertical component to overcome gravity but you will find the difference it makes is only about 1N so can be considered negligible during these extremely hard turns.
Rearranging the lift formula we get CL = L / .5 p v^2 S
(480sq in = 0.31m^2) so CL = 479 / .5 x 1.225 x 134^2 x .31 = 0.14
If we be more realistic and use a racetrack pattern to simulate our DS path, this does require tighter radius turns. If we approximate a racetrack using straight edges, say 30m each, we end up with a 4s circuit requiring a CL of 0.16, still a low value.
I hope this is of interest.
Best regards
Steve (another Steve, there are plenty of us in the DS world!)
Hot Air is offline Find More Posts by Hot Air
Discussion aerofoil programs anzacjack Flying Wings 2 Oct 18, 2010 01:39 PM
Discussion Help in choosing UAV aerofoil breezeit UAV - Unmanned Aerial Vehicles 11 Mar 03, 2010 05:11 AM
Discussion Aerofoil help breezeit Flying Wings 5 Feb 02, 2010 07:59 AM
Please help me choose and Aerofoil Lewist Modeling Science 6 Nov 23, 2005 02:32 PM
I need help choosing an aerofoil! Lewist The Builders Workshop 0 Oct 31, 2005 08:36 AM
