Old Feb 23, 2012, 04:04 PM
rcrich is online now
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
very nice. waiting on a video good luck
rcrich is online now Find More Posts by rcrich
Old Feb 24, 2012, 04:17 PM
Vectorflyer is offline
Find More Posts by Vectorflyer
Joined Feb 2011
...see first pictures of the 2-D-vector-leon.
new: with the two back lines i can quick lift up the trailing edge (by wrapping the line around the top of the vectorframe).....works like an elevator (creates pitch)
Vectorflyer is offline Find More Posts by Vectorflyer
Old Feb 24, 2012, 07:05 PM
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
can the lines be attatched to a servo to control pitch?
Old Feb 25, 2012, 01:20 AM
Joined Feb 2011
hi rcrich
nice idea,
but if you attache the lines to a servo, you will not get enough pitch for acrobatic flight. The better way is then to build a 3-D vector unit (with motor up and down)
advantage of my adjustable back lines is to find up a perfect setting on the flying field without using tools
...i have the posibility to change very quick the CG by pushing the lipo forward or backward
and i can increase/decrease the trailing edge (to change pitch) in a second.
by the way, the back lines helps a lot to stop "trailing-edge-fluttering"
thanks for your interest !
Old Feb 25, 2012, 03:57 AM
tedrobphoto is offline
Find More Posts by tedrobphoto
Joined Jun 2006
Hi, Vectorflyer
Looking at your simple 2D design and wondered whether you can't use the same idea for 3D ie more powerful servo attached to the smaller servo which is then attached to motor?
Ted(UK)
tedrobphoto is offline Find More Posts by tedrobphoto
Old Feb 25, 2012, 12:41 PM
Joined Feb 2011
hi Ted
this is the thread "2-D-vector units", so i can`t fly here around with a 3-D-unit
(ha, ha, ha)
i have a 3-D-unit for the leon to, which works excellent, but consider:
1.
a 2-D-unit frame must be not so stiff as a 3-D, and in combination with only one servo all is very light-weight.
2.
prop and motor can fixed near the sail, because right and left works excellent there. motor up and down doesn`t work, if the vector frame is not high enough (prop blows in the sail)....so i can build very slim 2-D units
3.
i uses always same parts for my 2- and 3-D units (motors, esc, lipos.....)
....with my 2-D-units i fly always 30-50 percent longer than with 3-D
Old Feb 25, 2012, 12:55 PM
Joined Feb 2011
leon on a windy day
today was strong wind (4-6 Bft), so i fly my leon-kite as a single line kite.
i had to add a lot of tails, now the leon is really an "eye-catcher" and a very stable flyer!
enjoy pictures of my saturday afternoon flight !
Old Feb 25, 2012, 01:19 PM
Joined Jun 2006
Hi, Vectorflyer it was just a thought but I can see your reasoning and after all there's nothing like experience to iron out problems. Your new kite looks real smart.
cheers Ted
Old Mar 17, 2012, 08:03 PM
Cutter7 is offline
Find More Posts by Cutter7
United States, MI, Constantine
Joined May 2004
Can a Vintage-Hi-Flier Kite be Vectorized ?Name: HF Kite.jpg
Description:
Cutter7 is offline Find More Posts by Cutter7
Old Mar 23, 2012, 03:46 PM
Joined Feb 2011
hi cutter7,
looks like a plastic sail and a wood frame.
....maybe this is not stiff enough for a vectorisation.
Old Mar 23, 2012, 03:50 PM
Joined Feb 2011
2-D eagle
my new 2-D kite is the 2012 premier eagle with 200cm wingspan
i will add a video soon!
Old Mar 23, 2012, 03:53 PM
Joined Feb 2011
video 2-D eagle
2d eagle (2 min 9 sec)
Old Mar 23, 2012, 09:14 PM
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
looks great!!
Old Jun 06, 2012, 02:16 PM
Joined Feb 2011
vision 2 D
turned my vision from premier into a 2-D-vector kite.
...changed all 6mm gfk-roots in lightweight 4mm carbon tubes and fly with my selfbuild 2-D unit about 15-20 minutes (with 800mAh lipo)
..will add a video soon !!!
...enjoy fist pictures
Old Jun 06, 2012, 03:28 PM
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Very nice awaiting video
Discussion VECTOR UNITS - typology flattermann RC Paragliders and Kites 79 Nov 11, 2014 10:04 AM
Sold (2) Wm 400 70mm fan units beachflyer Aircraft - Electric - Jets (FS/W) 3 Oct 21, 2010 01:07 PM
Wanted (2) HET 6904 Fan Units captnem Aircraft - Electric - Power Systems (FS/W) 3 Sep 07, 2010 02:11 PM
Sold Sold Pending: Two NIB Turbo Vector kits Wattage/Hobby People w/o fan units 50% off jcstalls Aircraft - Electric - Airplanes (FS/W) 7 Oct 21, 2008 06:13 PM
