Old Jun 08, 2011, 04:06 PM
Vectorflyer is offline
Find More Posts by Vectorflyer
Joined Feb 2011
Premier RC Delta Box Sport Lave 2-D
vector kite your life 21: Lava Sport (1 min 47 sec)
Vectorflyer is offline Find More Posts by Vectorflyer
Old Jun 09, 2011, 04:09 PM
Joined Feb 2011
Devil-kite with 2 D-unit
i maiden my new 2-D devil-rc-kite today. i will add a video soon. the 2-D-devil fly`s very tight curves and climbs very fast. i used a new motor: the premier red V580. The motor has the same size as the premier V780, power is not so strong, but with a 750mAh lipo i fly over 15 minutes! vector-unit is the same as i used on my other 2-D-kites like rc-vectorman, rc-nose, rc-dart, rc-peak....
the devil is a single line from HQ-kites, wingspan 100cm, length 110cm, think it is only avaiable in europe, but i am not sure. i changed all the gfk-sticks into carbon, keel and cross sticks 4mm, all others 3mm. kite solo: 80 gramm, kite RTF 240 gramm.
Description:
Description:
Description:
Old Jun 09, 2011, 04:11 PM
Joined Feb 2011
Devil-kite as a single line
Name: Teufel ebay1.jpg
Description:
Name: Teufel ebay3.jpg
Description:
Old Jun 09, 2011, 04:36 PM
Joined Feb 2011
short devil video
vectorkite your life 22: rc-devil (0 min 57 sec)
Old Jun 09, 2011, 05:56 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
very nice
rcrich is offline Find More Posts by rcrich
Old Jun 12, 2011, 10:01 AM
Joined Feb 2011
gardenflying
flying my new 2-D-devil kite this morning in my smal garden (8 meter x 16 meter).
........who needs 3-D when 2-D works perfect ?
vector kite your life 23, 2 D garden flying (2 min 3 sec)
Old Jun 12, 2011, 10:08 PM
flattermann is offline
Find More Posts by flattermann
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
Hi vectorflyer,
it's nice to see the exact controllability of such a vector kite, within the small space of Your garden, using only 1 servo for 2D - vectoring.
But, I think You'll agree - for some 'develish maneuvers', You might need a 3D vectoring
Good job!
flattermann
flattermann is offline Find More Posts by flattermann
Old Jun 26, 2011, 04:03 PM
Joined Feb 2011
2-D vector jet
first shoots of my new 2-D jet
Old Jun 26, 2011, 04:04 PM
Joined Feb 2011
first video of the 2-D-jet
vector kite your life 25 (1 min 51 sec)
Old Jun 26, 2011, 04:38 PM
Joined Feb 2011
2-D-jet
the jet is a dual-line kite from x-kites, size only 80cm x 80cm, printed sail.
The 2-D-vector unit is my new slime line construction which belongs to all my figurative kites (see thread) and is definitively to big for the jet (motor premier V580, metal gear servo, lipo 800mAh 11,1 Volt). But with a high CoG the jet makes nice rolls.
i will look for a jet with a bigger size.
by the way: commercial scratching of my 2-D unit is not allowed (all rights reserved)
thanks,
vectorflyer
Old Jul 04, 2011, 03:02 PM
nvmike is offline
Find More Posts by nvmike
Joined Nov 2009
AOA or AOI Question on 2-D kites
Is there a rule for the angle of attack on a 2-D RC kite?
I have used 10 degrees down on the motor on Rogallo kites using a fuselage with rudder and elevator and this works great. I now want to build with VT unit on top of the wing.
Any ideas would be appreciated, thanks
NvMike
nvmike is offline Find More Posts by nvmike
Old Jul 06, 2011, 01:43 AM
Joined Feb 2011
angel of attack
10 degrees down is to much.
if the vectorunit is very high (what is nonsense, but i also test nonsense)
the motor must shown up, because the long lever arm is pulling the nose always down if the throttle is open. If the prop is near the sail surface the motor must show down, but this is also nonsense, because the sail stops the input of fresh air and you have reflexions between sail and the output air of the prop.
..so start with 0 degrees and make sure that the air in front and after the prop is not to much interferensed by sail.
Old Jul 06, 2011, 12:18 PM
nvmike is offline
Joined Nov 2009
Thank you Vectorflyer
Thanks for the reply, I will try zero degrees to start with, I hope to fly in a few days.
NvMike
Old Jul 21, 2011, 04:23 PM
Joined Feb 2011
new 2-D kites
working on new 2-D kites, will inform you soon...
see first pictures...
Old Jul 21, 2011, 08:37 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
very nice! waiting on video.
Discussion VECTOR UNITS - typology flattermann RC Paragliders and Kites 79 Nov 11, 2014 10:04 AM
Sold (2) Wm 400 70mm fan units beachflyer Aircraft - Electric - Jets (FS/W) 3 Oct 21, 2010 01:07 PM
Wanted (2) HET 6904 Fan Units captnem Aircraft - Electric - Power Systems (FS/W) 3 Sep 07, 2010 02:11 PM
Sold Sold Pending: Two NIB Turbo Vector kits Wattage/Hobby People w/o fan units 50% off jcstalls Aircraft - Electric - Airplanes (FS/W) 7 Oct 21, 2008 06:13 PM
