Building the ultimate Ritewing Zephyr
As requested by Jim
http://www.rcgroups.com/forums/showthread.php?t=1279141 Closing a thread with invaluable information about one of the best types of FPV models is madness, just because of the bloke who started it. The politics on here is rubbish, rise above it RCG, if you was to alienate this froum from FPV then just remove the whole sub category, by closing useful threads you're just going to loose members elsewhere. |
Here's my 60" zephyr fpv maiden, video degrades badly at 500m not sure whats causing it??
setup is Hacker A30-10L Motor Hacker X70 SB Pro Esc 2 x 3300mah 4s Nantech Lipos EzOSD ExUHF Video on Bevrc 2.4ghz 500mw vtx (built in mic) and rx stock antennas channel 8 This is powered direct from 4s as it can accept this voltage, it then supplies 12v to camera. The vtx power has a sander style lc filter on the input. Any ideas on my bad video? |
Joined Mar 2009
what would be a better choice on a 3s 5600mah(2600mah x 2) witha 10x6 folder
Turnigy c3542 1250kv http://www.hobbyking.com/hobbyking/s...idProduct=3887 Turnigy c3542 1450kv http://www.hobbyking.com/hobbyking/s...idProduct=4917 |
![]() Quote:
Joined Jan 2009
FYI,
You can find him here. http://fpvlab.com/forums/showthread....d-Manual/page9 251 FPV pilots and counting............... |
Motors, there is a difference - Hacker/Axi/MVVS are more expensive for a reason and are more efficient and are more reliable, Turnigy are great for the money and I use them on most things foam, but never on breakable 3D plank where if it fails during certain maneuvers it will crash.
Joined Mar 2009
what do you guys think? turnigy 3542 1250kv with 10x6 folder lipo choice 2 x 3s 3000mah 2 x 3s2200mah 2 x 4s 2600mah |
New Zealand, Gisborne, Gisborne District
Joined Jul 2009
| Thread Tools | |
| Build Log Building the ultimate Ritewing Zephyr | trappy | Video Piloting (FPV/RPV) | 3902 | May 23, 2013 01:17 AM |
| Mini-HowTo A few notes on the Ritewing Zephyr | kyle7119 | Video Piloting (FPV/RPV) | 4 | Dec 30, 2010 12:11 AM |
| Build Log Building the ultimate Ritewing Zephyr | trappy | Video Piloting (FPV/RPV) | 49 | Jul 21, 2010 05:28 PM |
