This thread is privately moderated by Jay Burkart, who may elect to delete unwanted replies.
Old Mar 21, 2011, 12:44 AM
Jay Burkart is offline
Find More Posts by Jay Burkart
SAM Elec GrdChmp04,07,10,12,14
Jay Burkart's Avatar
Smithfield, Ky.
Joined Sep 2001
Airborn 1600 build landing gear and shaping cowls and window block
I cut and shaped the front window blocks, Quite a lot of balsa butchering to be had here.
That window block is massive.
Also the nose cowl blocks on the firewall motor mount is made for most of the models.
Piece of 1/2" balsa here and some 1/16 balsa strips around the edge of the motor mount themselves
to have them blend in with the sheeting of the fuselage and give the motor mount a balsa sheath
all the way around to make the covering adhere better.
Lastly bent up all the landing gears of 5/32 music wire, plan on heat treating all the gear
so that it toughens it up quite a bit and makes it not bend so easy now that the music
wire we get is about as soft as solder.
Jay Burkart is offline Find More Posts by Jay Burkart
