This thread is privately moderated by HawkerTyphoon, who may elect to delete unwanted replies.
Old Mar 20, 2011, 09:25 PM
HawkerTyphoon is offline
Find More Posts by HawkerTyphoon
HawkerTyphoon's Avatar
United States, NY, Patterson
Joined Jan 2009
More Metal Shop
My blog has been neglected a lot recently so here is a quick post to get it back on track,.
Last week, I was looking at the other forum I frequent, oldminibikes.com and saw this great thread on how to make your own "stinger" exhaust pipe. I looked through our scrap bin at home and didn't find anything usable, so after scrounging around at school, I found a perfect piece of thin-wall tubing on the remnant rack.
They way you make the taper is you first cut a wedge shape out of the pipe using a plasma cutter. Then using a vice, you squeeze the pipe so the gap closes up, once you do this you end up with a rough tapered pipe. To smooth things out, I used the anvil and a hammer to coax the pipe back into a round shape.
Once you are happy with the results, you weld the seam back together. To finish things off, we took a soft grinding wheel and ran it along the surface, giving it a polished look. You could also paint it but I think it will look cool once the hot exhaust turns the pipe a bluish purple tint.
The only thing left to so is to put a spark arresting screen into it, because wildfires are not so good.
HT
HawkerTyphoon is offline Find More Posts by HawkerTyphoon
Discussion More "KX"s than a pastry shop! :) gizmointhesky FPV Talk 163 Jan 30, 2012 09:22 PM
Discussion Bad weather time to work in the shop = One more New Plane Can Fly Land?? Aerial Photography 1 Dec 05, 2007 08:47 PM
Good and cheap shop selling all gws items and more! in singapore YZYgold Foamies (Kits) 0 Apr 16, 2002 05:47 AM
