Old Mar 20, 2011, 05:51 PM
sherlockshah is offline
Find More Posts by sherlockshah
Joined Feb 2006
Okay time to change things out, need some opinions
THE Nitroplanes T-45 Hawk flys really good on 10s but I think the speed is maxed out because of the airframe. I am going to use that powersystem in a F-16 which might perform better. I am looking for a 90mm fan and motor that can run on 5s? is there such a poweful system for 5s on a 90mm fan?
sherlockshah is offline Find More Posts by sherlockshah
Old Mar 20, 2011, 08:03 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Perform beter??what are your goals?? Just how fast you can get it to go or???
falcon5 is offline Find More Posts by falcon5
Old Mar 20, 2011, 08:11 PM
Joined Feb 2006
No looking for a motor to run on 5s
with a 90mm fan, I know it wont go as fast but I want to build a F-16 with the current 10s system.
Old Mar 21, 2011, 09:07 AM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Yes we got that part, but what kind of performance are you looking for? A ballpark figure of Watts or thrust wanted is a good start. And what kind of battery size do you plan to use? You need to give us more details.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Mar 21, 2011, 09:52 AM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
If you want 5S and to be powerful your amps may be high. Most likely in the 80's or 90's.
Are you takeing the power system out of the T-45?
Old Mar 21, 2011, 10:33 AM
gjhernandez is offline
Find More Posts by gjhernandez
Joined Apr 2008
Check out the HET F-16 thread, seems that it is perfect for 10s
By the way... I`m just starting to build the T-45 you mention
gjhernandez is offline Find More Posts by gjhernandez
Old Mar 21, 2011, 11:21 AM
Joined Feb 2006
okay sorry for not being detail so here goes.
SO i have tested the HET 700-60-1485kv motor with HET 90mm fan and CC HV120 with the T-45 and seems to be good flyer. I am however wanting to go faster so my idea is to change the airframe to F-16. I want to buy a Motor for 90mm fan most likely HET 90mm fan that can run on 5s. I dont mind having shorter flights, but want to stick with 5s because I can interchange between planes. I am however looking at buying the tamjets F-16 1/8th scale so battery options might change but that is not 100% yet. I do have two jets right now. I have the T-45 hawk and the F-104 by HET. Both of my current jets can use the 5s packs. I have a 90amp speed controller. And the T-45 is already built. I just have to take the current power system out and put in a new fan and motor and the the speed controller I mentioned. MY 5s packs are 3200mah 65c xps. SO if I can get 3-4 minute flight I am okay with that. So which motor can go into the HET 90mm fan and run on 5s and perform well? I know it will not be as powerful as the system I have now but just to get it flying and having a little fun is all I want because I already have the jet built. I will make the F-16 a rocket. I have two choices for 90mm,either the HET F-16 90mm or the airpac F-16 90mm, or if I want to spend a big more the TAMJETS F-16 for 90mm. All three will have to be bungee launched.
Old Mar 21, 2011, 05:21 PM
gunradd is offline
Find More Posts by gunradd
KingtechUSA
gunradd's Avatar
United States, FL, Spring Hill
Joined Apr 2009
gunradd is offline Find More Posts by gunradd
Old Mar 21, 2011, 06:28 PM
Flip Flop is online now
Find More Posts by Flip Flop
Flip Flop's Avatar
United States, UT, Syracuse
Joined Oct 2009
I dont think you should spend that money for a Tam f-16, and good luck trying to get a Air pac f-16. So I think you should do the Het for your experiments, and as always take video and dont listen to anything anybody tells you. Just watch out for middle age women and there dogs.
Flip Flop is online now Find More Posts by Flip Flop
Old Mar 21, 2011, 06:46 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Please don't bungee launch a tam 1/8 F16. If you do then you are a bigger tard then I thought.
Ha..ha...Lmaorof! Don't tell him that, I want to see a Tam F-16 bungee'd!(or handlaunched off a big hill) Should not worry tho..Flip Flop has is right.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Mar 22, 2011, 09:50 AM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
Fuzz
LOL too much! I wanna see it now! Tams F16 cart wheeling down the field , parts flying everywhere, while the dogs are chasing it and a middle aged woman is yelling in his ear! LMAO!
Be sure you get video of that tarderiffic event!!
stoneenforcer is offline Find More Posts by stoneenforcer
Old Mar 22, 2011, 07:41 PM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
No one mentioned how difficult it would be to fly a 90 size jet on a 3200 5s pack either....
ApexAero is online now Find More Posts by ApexAero
Old Mar 22, 2011, 08:13 PM
Joined Feb 2006
IM running the T-45 right now on 10s 3200mah
WHY cant it work on 5s??
Old Mar 22, 2011, 09:20 PM
Flip Flop's Avatar
Joined Oct 2009
sigh...........
Old Mar 22, 2011, 10:31 PM
Matt Howard is offline
Find More Posts by Matt Howard
Dyess AFB
Joined Apr 2009
really? you want to cut the voltage in half and still expect the same power system to have enough power to fly a plane? I honestly think your pulling our leg with this one
Matt Howard is offline Find More Posts by Matt Howard
Sold No time to build, thinning things out... dfalcon Non R/C Items (FS/W) 9 Jan 07, 2011 12:15 PM
Question Need some opinions about which 3d/sport plane. Nitrouss Sport Planes 2 Dec 17, 2010 10:16 AM
Discussion I just finished this build, need some opinions sherlockshah Electric Ducted Fan Jet Talk 19 Nov 12, 2010 09:26 PM
Idea esc fan idea i need some opinions on! TRAXXAS DEMO Electric Power Cars 12 Oct 17, 2010 04:52 PM
Discussion Might buy a Blade 120SR - I need some opinions APJudson Beginner Training Area (Heli-Electric) 15 Oct 05, 2010 08:01 AM
