Old Mar 20, 2011, 11:44 AM
BLuEArMy is offline
Find More Posts by BLuEArMy
Joined Mar 2011
JXD 340 Drift King BATTERY
Hello, i have just bought my rc heli! It has inbuilt 3.7v Lipo 180mah ! It flies for around 7-8 minutes so i am very happy for this time! But i was wondering if i can use a CR123A battery (which is 3.7v and around 1000mah)! Will be there any problem? This battery only weighs 16grams so there won't be any problem! Is there any chance that i can fit that battery and have a longer flighting time? like half an hour? (180mah 3.7 flies for 7 minutes so ... 1000mah 3.7v may fly around 30 minutes +) What do you think? Does it worth trying removing the inbuilt battery and puting this one? Thanks for your help!
BLuEArMy is offline Find More Posts by BLuEArMy
Old Mar 20, 2011, 02:29 PM
SubtleT is offline
Find More Posts by SubtleT
Vroooom putta putta putta
SubtleT's Avatar
Joined Feb 2011
I think your substitute will be far heavier than the stock pouch cell weighing something like 5 grams. It probably isn't designed to handle the high discharge rate required ether.
These things are engineered as a system, and major changes in one area can have impacts in others. Running the helicopter longer would probably result in burnt up motors even if it got off the ground.
7 minutes is a quite reasonable time though 5 might be safer to prolong battery and motor life.
SubtleT is offline Find More Posts by SubtleT
Old Mar 20, 2011, 02:46 PM
Frank_fjs is offline
Find More Posts by Frank_fjs
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
You'll never get half an hour flight time out of any electric helicopter.
The battery will be too heavy and the longer you run it the quicker the motors will catch fire. The electrical components are only designed to be ran for less than 10 minutes at a time, at which point they need a cooling down period.
Frank_fjs is offline Find More Posts by Frank_fjs
Old Mar 21, 2011, 01:46 PM
BLuEArMy is offline
Joined Mar 2011
Thanks for you replies. Ok, most probably i won't even try it! Maybe if i buy a cheaper 3ch heli i will make some experiments on it! Thanks!
Old Mar 28, 2011, 04:00 PM
Hawzzy is offline
Find More Posts by Hawzzy
Canada, ON, Bracebridge
Joined Feb 2011
At litehawk.ca...they have taken the original LH...(comparable to s107) and replaced its 150 mah batt. with the one from the XL...500mah...the battery is ten grams heavier...but after lightening the heli a little it more than makes up for it...flight times of 17-21 minutes!!!!!
This is an in-house Mod...the company shot the vid and posted it for us all to see...they have tons of vids on repairs...and some threads on Mods on FB too!!!
It cant be too bad....if the company did it themselves!!!!!
At least they try!!!!!!
Tye
Hawzzy is offline Find More Posts by Hawzzy
Old Mar 29, 2011, 08:56 PM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Skunkworks Battery Mod
http://www.youtube.com/user/Borgfeld.../6/1frjkYmX18I
Brosol is offline Find More Posts by Brosol
Old Apr 02, 2011, 11:04 AM
Hawzzy is offline
Joined Feb 2011
thanks for posting the link...
Old Jan 16, 2012, 02:49 PM
electrojolt is offline
Find More Posts by electrojolt
Joined Jan 2012
I upgrated the battery on my drift king and it now runs for over 12 minutes. Replaced the original 200mah with a 240mah battery and added 2 100mah batteries. weight is not the only limitation on these little toys, you also have to balance the weigth.
electrojolt is offline Find More Posts by electrojolt
Discussion Just ordered my first RC. JXD 340 Drift King _pokey Coaxial Helicopters 252 Feb 25, 2014 05:23 AM
Discussion 4-CH JXD 340 or G.T. 5888? THE_SHRUB Coaxial Helicopters 9 May 06, 2011 08:38 AM
For Sale Hitec CG-340 Battery Charger RV4DRIVER Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 30, 2010 05:42 PM
Discussion JXD 921 or JXD 990? Cralis FPV Talk 84 Oct 12, 2009 08:26 AM
Discussion need some advice "Mattel Drift King" harold938 On-road Cars 3 Jan 01, 2007 08:46 PM
