Old Mar 20, 2011, 12:43 PM
N0Glow is offline
Find More Posts by N0Glow
N0Glow's Avatar
Puerto Rico, Barceloneta
Joined Jul 2001
Question
Motor system for an GP Electrostreak ARF
I'm looking for an economical/moderate cost power system for an old Great Planes Electrostreak ARF. I'm looking for something I can buy from Hobby King (cheap), running with lipo's and no gear boxes. Any recommendations?
I found several similar, older, threads but they all seem too dated and many of the recommended motors are either no longer available or they're out of my budget range.
N0Glow is offline Find More Posts by N0Glow
Old Mar 20, 2011, 12:52 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
A brushed 550 is over 200g, but this 120g motor should spin an 7x7 well on 3s: probably if you can shove your Lipos as far forward as possible, the CG should come out okay. 700W-875W is ridiculously optimistic... but 400W-500W (say, 45A on 3s) should be okay.
http://www.hobbyking.com/hobbyking/s...dProduct=15169
Here is one useful review:
Conducted a test on EMeter firm Hyperion Controller TURNIGY TRUST 70A SBEC, battery ZIPPY Flightmax 2200mAh 3S1P 40C excellent battery is a very good current output is better than firms Turnigy
obtained the following results:
MAS 7x7 44A 16400
APC 8x6 64A 14100
MAS 8x7 57A 15000
JXF 7x6 37A 17000
JXF 8x6 46A 16100
JXF 8x8 55A 15000
APC 9x6 67A 14000
The result was a very good result this engine is the best in this series, I put 5 stars deservedly
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 20, 2011, 01:44 PM
N0Glow is offline
N0Glow's Avatar
Joined Jul 2001
MAS 7x7 44A 16400
APC 8x6 64A 14100
MAS 8x7 57A 15000
JXF 7x6 37A 17000
JXF 8x6 46A 16100
JXF 8x8 55A 15000
APC 9x6 67A 14000
Thanks! This sounds like what I'm looking for. I'll play with the weights and lipo location to see if I can get the CG right with this battery. Otherwise, I'll see if I can squeeze in a heavier/larger battery. I hate adding lead to balance CG.
Old Jun 18, 2011, 08:40 AM
N0Glow is offline
N0Glow's Avatar
Joined Jul 2001
I finally got around to mounting and testing this motor combination. I got 450 watts at 47 amps on an APC 9x6 folding prop which is very close to the predicted performance. The motor I got from Hobby King was of surprisingly good quality, in fact the motor might have been a bit TOO powerful. It ripped the motor mount during pre-flight testing, although I think the fuse was defective. I ordered another fuse to try again.
Discussion Want an easy to fly arf plane for a 2408 21t motor Stormed Electric Plane Talk 0 Nov 30, 2010 04:54 PM
Sold GP ElectroStreak NIB balsa kit funfly Aircraft - Electric - Airplanes (FS/W) 1 Nov 14, 2010 12:53 PM
Wanted Swap RTF Great Planes Electrostreak ARF for XBOX 360 System rcgreaves Non R/C Items (FS/W) 1 Oct 23, 2009 09:36 AM
Sold GP Electrostreak ARF + BL motor PerfectStranger Aircraft - Electric - Airplanes (FS/W) 4 Jun 01, 2007 05:43 PM
Wanted GP ElectroStreak ARF GuyP Aircraft - Electric - Airplanes (FS/W) 2 Feb 13, 2007 10:04 PM
