Old Jan 27, 2012, 09:23 PM
JimTMich is offline
Find More Posts by JimTMich
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
Good point on the cg check.
That must have been some crash to crack a circuit board.
That reminds me of a crash back when I was trying to fly as a kid. It hit so hard the servo case screws stripped out and the servos opened up spilling gears all over the grass lol
JimTMich is offline Find More Posts by JimTMich
Old Jan 28, 2012, 09:36 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Hi Jim
No point in having a half- hearted crash!
D
Dereck is offline Find More Posts by Dereck
Old Jan 29, 2012, 06:43 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
In my worst crash I only saved the cylinder head from the Enya 60. Another bad crash smashed all of the diodes in the Bonner 8 receiver. Most of the transistors, resistors, and caps were bent over and/or broken. The IF cans were torn off the board and the wire came off the coils. The two circuit boards were separated and it took me several hours to straighten the case. Then, like a fool, I sent it for repair. It was but I was afraid to use it again and got a new one. That crash spilled most of the servo gears, but all of the balls. Also lost the battery pack ( a screw went through most of the old button cells) The engine survived but the airframe didn't.
Al M is offline Find More Posts by Al M
Old Feb 02, 2012, 01:14 PM
Dereck is offline
Joined Dec 1996
Al
That was a serious black belt, 10 out of 10, 100% A grade crash!
D
Old Feb 02, 2012, 07:03 PM
Al M is offline
Wallingford, Ct
Joined Sep 2001
Dereck,
It was! The glow plug even broke. The pin bent and pulled loose. Hit an abandoned concrete foundation for a railroad signal. First flight.
Al
Old Feb 22, 2012, 11:04 AM
Racerx4 is offline
Find More Posts by Racerx4
Racerx4's Avatar
United States, OK, Norman
Joined Jun 2011
Ok, sky boy question... I went to go get some ca hinges at my lhs but they only had actual nylon hinges. My issue comes in that I built my elevator halves a bit off when joining them togther in the middle. I sanded it so it now fits flat and square. I have worked and worked trying to hinge the elevator but have not luck! I built a sky buggy 300 and used tape hinges only for the elevator and rudder. Is this bird too big to use tape hinges? I have already cut many slots in the trailing edge of the stap trying to use the hinges. I'm going to use 3 standard ca hinges on the rudder. Have I cut up the elevator too much to use robart hinges?
I installed the windshield on the plane then promptly dropped glue on the glass, trying to cleen it I ended up making it white and streaky. As a replacement I used a plastic piece of a tomato carton. Looks decent. Do I need to be concerned with wind flapping?
Also in some places my plane has a case of the wrinkles in the covering mainly in the rear stringers. Is this an issue?
Hopes this isn't too much...
Noah
Racerx4 is offline Find More Posts by Racerx4
Old Feb 23, 2012, 10:52 AM
fleaz is offline
Find More Posts by fleaz
fleaz's Avatar
United States, CO, Colorado Springs
Joined Apr 2007
Tape hinges should work, but you'll need to tape the top AND bottom of the hinge. Lay the tape on top first, then fold the elevator up on top of the stabilizer, exposing the bottom. Apply the tape to the elevator or stab first, pressing the tape down into the hinge area, then rub it down on the other surface. If you've already sanded a bevel in the top AND bottom edges (which I assume you did in preparation for CA hinges) use the procedure for the bottom on top as well. I find it easiest to set the stab/ elevator up tee-pee style when doing this part, but with the curves on these surfaces it might make things harder than they need to be.
The wind shield should be fine. Either it stays, or on the first flight it will come off. You can get replacement windscreens from StevensAero, call Bill for a quote.
Wrinkles aren't going to hurt anything. You can, cautiously, use a heat gun to work the wrinkles out, but you risk burning a hole in your covering. Glue up a simple frame and cover it, wrinkles included, and practice on that before you apply heat to your plane.
Mark
fleaz is offline Find More Posts by fleaz
Old Feb 27, 2012, 09:23 PM
Racerx4 is offline
Racerx4's Avatar
Joined Jun 2011
Ok... finally got this bird done! but I have a few questions.. It seems like the tail wheel is rather bendy and the bottom of the wing hits on the ground a bit (see pics) Would it be a good idea to remove the tail wheel? or just reinforce it or make it stiffer. Making a metal/plastic tail skid work of? I will be flying off a grass field 99.9% of the time, my guss is that it will not to much ay way.. Also the alerons dont have much throw. At first I had them at the sugested 45 degrees but they seemed to not work evenly so I opted for a parrell to hindge line control horn set up (issue?) and is even per side BUT the alerions bang on the ground in full deflection!(good for flying?) I have installed the wingtip skids... Is this wrong? also I have herd that this plane is very tail heavy, if I remove the tail wheel parts and wire will this combat this issue? I havent checked the cg yet. any first flight tips? Is there a specific surface deflection is inches per aleieron rudder and elevader or just preference and flying style?
Thanks again
Noah
thanks fleaz! tape hinges worked great! I can hold the plane by the tail with such strong hinges! I have a heat gun and yess, I am the king of burning holes in monokote! no doubt!
Ps. do you guys have any info on the A main hobbies eco power 2200Mah batteries? good price and great warranty
Old Feb 27, 2012, 10:11 PM
JimTMich is offline
God is my pilot
JimTMich's Avatar
Joined Aug 2006
I've had zero cg issues. I used aerofilm and a 103gr motor.
Yes, wingtip skids per the directions.
Get as much throw out of the aileron setup as you can, this plane is quite relaxed about rolls. Just be aware of this when you are on the ground.
This plane does sit low...you can bend the main gear a little to get some more ground clearance. Remember to make the rubber bands on the main gear stiff so the wheels don't smash the wings on landing, this will also give more clearance.
Tail wheel works fiine stock. It works great for taxiing in the grass.
Set your cg, pick a calm day with a big field, and go enjoy!
Old Feb 27, 2012, 10:35 PM
simages is offline
Find More Posts by simages
AMA# SIMAGES
simages's Avatar
United States, NY, Cold Spring
Joined Dec 2006
Originally Posted by Racerx4 View Post
Ok... finally got this bird done! but I have a few questions.. It seems like the tail wheel is rather bendy and the bottom of the wing hits on the ground a bit (see pics) Would it be a good idea to remove the tail wheel? or just reinforce it or make it stiffer. Making a metal/plastic tail skid work of? I will be flying off a grass field 99.9% of the time, my guss is that it will not to much ay way.. Also the alerons dont have much throw. At first I had them at the sugested 45 degrees but they seemed to not work evenly so I opted for a parrell to hindge line control horn set up (issue?) and is even per side BUT the alerions bang on the ground in full deflection!(good for flying?) I have installed the wingtip skids... Is this wrong? also I have herd that this plane is very tail heavy, if I remove the tail wheel parts and wire will this combat this issue? I havent checked the cg yet. any first flight tips? Is there a specific surface deflection is inches per aleieron rudder and elevader or just preference and flying style? Thanks again Noah
-CUT-
Ps. do you guys have any info on the A main hobbies eco power 2200Mah batteries? good price and great warranty Thanks
Looking Noah -
For personal reasons I have not yet flown my SkyBoy however; with confidence I can say..... that the tail wheel is bendy and you could reinforce it or angle it differently to raise it slightly, but with a soft 3 point landing..... Tail Skid, I suppose.... IMO, I would bend it first and see if it gives you the desired result which it should. then if needed you could stiffin it....
The Wing tip "skids" are correct hence being close to the ground....
any first flight tips? Yep..... first tip before maiden.... Check, verify and adjust CG we will all have slightly different adjustments based on things like our power system i.e. motor, battery type, size, weight and location. Check both the fore-aft balance as well as side to side.
Specific surface deflection is inches per aileron, rudder and elevator or just preference and flying style? Both..... think of your dual rates High and Low (up and down) or depending on your radio you could have 3D rate - High rate - Low rate settings which would be the amount of throw in inches, mm or degrees.
For example, but NOT this model
Ailerons 31 / 31 / 31 or 1-1/4" / 1" / 3/4"
Elevator 31 / 31 / 31 or 1-3/4" / 1-3/8" / 1"
Rudder 31 / 31 / 31 or 4-1/2" / 3-1/2" / 2-3/8"
Hope this helps - Keith
simages is offline Find More Posts by simages
Last edited by simages; Mar 03, 2012 at 05:50 PM. Reason: Anal Retentive Correction....
Old Mar 03, 2012, 05:19 PM
Racerx4 is offline
Racerx4's Avatar
Joined Jun 2011
Thanks the maiden went great!! very fun plane to fly! very floaty! some how managed to park it in a tree! on the 11th flight no damage just a couple of holes in the covering very lucky! dose anybody here gave their pilot figure that was not used? mine ejected... I would be happy with ether the paper cut out or the wood, with one i could make my own other pilot cut out or vice versa. Thanks to all you guys helping me along with my great new plane!
just PM me and i can give you my address and paypal and such.
Noah
Old Mar 03, 2012, 05:34 PM
Scott C is offline
Find More Posts by Scott C
son of a pilot
Scott C's Avatar
United States, GA, Peachtree City
Joined Aug 2000
Congrats. Just keep it out of the trees. I know easier said than done.
Scott C is offline Find More Posts by Scott C
Old Feb 08, 2013, 07:01 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Specsheet
Changed some electronics so, I've added.... an Updated Spec Sheet
Old Dec 03, 2015, 07:10 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Wing Repair.......
Prompted this modification to convert the wing and eliminate the rubber bands.
"A while ago I had a hard landing and the LG took out a small section of the wing. Finally put it on the bench to fix the leading edge and decided to ad a spoon and rear bolts. I'll keep the bands on the wheels because I like the flex it gives."
Latest blog entry: Strega MK2 "P-51 Mustang" by...
Old Dec 03, 2015, 09:00 PM
Scott C is offline
son of a pilot
Scott C's Avatar
Joined Aug 2000
Good to see you getting it back up in the air. Just had my SkyBoy down at HHAEFI in south Georgia a few months ago. A great venue for a great plane.
Discussion Stevens Aero Skyboy 7rider Parkflyers 272 Jun 11, 2013 11:35 AM
Sold Stevens Aeromodel Shaft .25e (Big One) Colorado Springs ShoGinn Aircraft - Electric - Airplanes (FS/W) 3 Dec 12, 2010 03:59 PM
Discussion Stevens AeroModel Shaft 400 for RealFlight haiduk Parkflyers 1 Nov 30, 2010 08:35 AM
Discussion Stevens Aeromodel Adrenaline Rush, Anyone? Mr. Wiz High Performance 12 Nov 14, 2010 11:58 AM
