Old Mar 20, 2011, 07:32 AM
fluxno is offline
Find More Posts by fluxno
Joined Feb 2011
what do you use as umbilical cable to your ROV?
what type of cable do you use as umbilical for your ROV?
i've been looking at some pvc hybrid cable with 1x coax(video), 2x0.14mm2 (com) and 3x1mm2(pwr) but the downside is a price of 15$ per meter!(approx 5$ pr feet) and its quite heavy.
http://www.kabeltronik.de/audio-cabl...m-k-van-1-2-1/
i would really like a neutral buoyancy cable in a lower price range.
i'm using it with the rov-asia boards.
fluxno is offline Find More Posts by fluxno
Old Apr 01, 2011, 02:01 AM
eerrp is offline
Find More Posts by eerrp
Joined Aug 2004
Two-Wire Tether
I use an off-the-shelf data over power-line system. This allows for data transfer and also powers the ROV, but is about as thick as two strands of fishing line. Also very inexpensive. Here's the configuration.
http://openrov.com/forum/topics/twowire-tether
Eric
eerrp is offline Find More Posts by eerrp
Old Apr 01, 2011, 10:18 AM
martinjdw is offline
Find More Posts by martinjdw
Aberdeenshire
Joined Jan 2011
Hi Eric,
Have you thought about running a ground wire to the ROV itself as your circuit looks like it relies on the water to make a circuit which for sea water is still quite a high impedance and fresh water is very high.
Normally we tie a wire to the chassis of the ROV from our GFD modules, to basically anything metal that can zap you
Martin
martinjdw is offline Find More Posts by martinjdw
Old Apr 01, 2011, 10:46 AM
fluxno is offline
Joined Feb 2011
i'm also thinking about using high voltage and downconverting in the rov.
i would need a total of 4 wires for power and communication(2 for power and 2 for coms), the boards i use have a own communication protocol on a 2-wire line that can be run up to 500 feet.
i would also need a usb or video to power-over-ethernet converter like used on the link.
Question What TX do you use for your multicopters? JossyRC Multirotor Talk 12 Mar 12, 2011 12:20 PM
Discussion What Kind of Camera do you use for FPV on your Quad? awa202 Multirotor Talk 34 Feb 28, 2011 04:53 PM
Question 12v source for LiPo 1-3 CELL 250ma-2AMP CHARGER (12V) what do i use as 12v source neildakill Batteries and Chargers 8 Oct 19, 2010 06:38 PM
Discussion What stopwatch do you use for DLG contests? Fly2High Hand Launch 34 Sep 20, 2010 06:30 PM
What do you use as a weighted bar for your wing core cutter ? NetForce2K Foamies (Kits) 1 Jul 26, 2002 07:27 PM
