Old Aug 10, 2003, 12:35 AM
KatanaGuy is offline
Find More Posts by KatanaGuy
Design, Build, and Fly
KatanaGuy's Avatar
Pleasant Grove, Utah
Joined Nov 2001
Micro Air Vehicle Science Project
I've been interested in MAV and UAV type planes for a year and a half. I'm interested in building these vehicles in the future, and have gained some experience by converting my Slowstick into a partial UAV with a cheap "Hong Kong Special" Ebay wireless camera.
In anticipation of school, which is in 2 weeks, I want to find out as much information on MAVs, UAVs, and RPVs. Any websites, tech papers, and people to contact will be appreciated.
What would also be very useful is general information on aerodynamics, airfoils, and plane design. I'd like to learn more about aeronautical engineering and flight.
I plane to design, build, and fly a working 3x sized (18 in) MAV for my science project early next year. I wonder if I will make it to the National Science Fair ?
Steve
KatanaGuy is offline Find More Posts by KatanaGuy
Old Aug 10, 2003, 09:13 AM
propfan is offline
Find More Posts by propfan
Propellers are cool.
propfan's Avatar
Toronto
Joined Jan 2003
http://www.elkhart.net/~miked/Ulinks.htm
propfan is offline Find More Posts by propfan
Old Aug 10, 2003, 04:21 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
http://www.pages.drexel.edu/~weg22/CQAR.html
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Sep 03, 2003, 11:32 PM
KatanaGuy's Avatar
Joined Nov 2001
Update
Instead of two weeks to school, I'm now two weeks into it! I've experimented with my Slowstick UAV more, and have tried designing a small plane.
My current questions are:
1) How do I find the CG of a delta wing (Mathmaticly). I think I know how to do it graphicly, but that dosen't feel accurate enough.
2) How is the CG affected by haveing canards in front. Do I need to place the CG between the two according to their areas or something similar?
Steve
PS: To find the CG on a delta wing graphicaly, you take the wing root length, and put it on both sides of the wing tip, and visa-versa with the wing tip length, right? You then measure 30%-40% back on the Mean-Aerodynamic-Chord, and thats the CG, right?
Old Sep 04, 2003, 03:19 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
1) There is a good book on model aerondynamics called "model aerodynamics" it is in there. The best way is test gliding really. That's how they would do it for real if they could
2) Same book I suspect
As these are really just Aerodynamics questions you may consider posting in the modelling science section of the forums
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Sep 04, 2003, 06:26 PM
TeamSME is offline
Find More Posts by TeamSME
40%, 5% whats the diff?
TeamSME's Avatar
Baltimore Greenbelt, Maryland, United States
Joined Jul 2003
Well if ur scaling a plane down just use original cg/original span time x (new cg)/ span. Cross multiply. I just love algebra in my high school.
TeamSME is offline Find More Posts by TeamSME
Old Sep 04, 2003, 07:53 PM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
the math part is really just to find the MAC... which is going to be the average chord length. The average chord then is as you suspect: (Cr + Ct)/2
Cr = root chord
Ct = Tip chord
Then its a matter of finding where you want your cg... a normal good starting point is 25%, so once you find your MAC, you use 25% of that as your cg... For a constant taper, your mac usually falls dead center on the wing profile.
The way we do it in my Aerospace engineering classes is this:
Draw the planform for the wing (top view outline). Find your MAC (mathematically if you wish), and if you like, you can verify it by measuring the chord at the center of the wing... From there, mark a dot on the root chord at 25% chord length (1/4 of the chord length from the leading edge. Then do the same at the tip. Connect these two dots to find your quarter-chord line (this is a very important line). Now, draw a line perpendicular to the centerline of your plane from the intersection of your quarter-chord, and your MAC line, to the centerline of your plane... follow? This will give you the exact location of where you want your cg to be on your model... You can do it mathematically, but you'll have to do more or less math depending on the shape of the wing... and to do it graphically works really well, never screwed me up so far
Phreakish is offline Find More Posts by Phreakish
Old Sep 05, 2003, 11:04 PM
Aaron13 is offline
Find More Posts by Aaron13
look the sun.....AHHHHHHH
Aaron13's Avatar
Bremerton,WA
Joined Jul 2002
dang your what? 17? how did u get into flight school? i want to. you could build a bit plane they can get pretty small. im building a lifter for my project but i cant get a hold of a 25KW power supply.
Aaron13 is offline Find More Posts by Aaron13
Old Sep 06, 2003, 12:58 PM
Mr_Bazball is offline
Find More Posts by Mr_Bazball
Annandale Va
Joined Nov 2002
Thanks guys
U just reminded me i need to start thinking about a science project for my physics class.
Chris
Mr_Bazball is offline Find More Posts by Mr_Bazball
Old Sep 06, 2003, 09:32 PM
JordanKBowles is offline
Find More Posts by JordanKBowles
Springfield MO
Joined Dec 2002
i'm resreching mine now for my physics 2 class, I think i'm going to go with a sub 6" VTOL heli thats fully robotic
JordanKBowles is offline Find More Posts by JordanKBowles
Old Sep 07, 2003, 01:58 AM
Nickel what?
Phreakish's Avatar
Joined Jan 2003
actually, I'm 20, and a junior in Embry Riddle Aerospace University
Anyhow, I forgot to answer #2... basically, you want your cg at the center of your lift... so, if you have canards, and they have null lift (symmetrical airfoil) then you should be fine, and it SHOULD fly like any other airplane, with the cg based on the wing alone... The same is done for std tail aircraft, but the tail is usually null lift (sym airfoil) so its not a consideration... if the same is true for your canards, you're fine. So long as you remember that if you're pulling up with canards, you're increasing the lift on the front, not decreasing it in the back (as a normal plane works), so AOA comes into effect... which is what causes the canards to typically stall before the wing (typically, not always).
Best way is to glide test... which you can do with no equipment on the aircraft... if it flies empty (and you dont add too much weight) then it'll fly fully loaded. You could add balast to make sure it'll fly with the load... glide testing really is the best way, thats how Ive gotten all my models to fly
25% mac is a rule of thumb, you'll NEED to adjust from there depending on how heavy the nose/tail is...
Old Sep 07, 2003, 08:31 PM
Annandale Va
Joined Nov 2002
I was just thinking of that too. Maybe one with an rffs100 and actuators. Also im thinking about designing a micro/submicro plane.
Chris
Micro air Vehicle propulsion system charles27 UAV - Unmanned Aerial Vehicles 7 Jul 31, 2005 01:05 AM
WASP Micro Air Vehicle nanoflite Scratchbuilt Indoor and Micro Models 3 Apr 07, 2005 09:13 PM
Question Micro Air Vehicle Project Viper2000 Scratchbuilt Indoor and Micro Models 101 Apr 19, 2004 02:26 AM
Build a WASP Micro Air Vehicle!? Nowell York Electric Plane Talk 16 Mar 04, 2003 09:01 PM
DARPA's Micro Air Vehicle has batteries for wings.... Steve McBride Batteries and Chargers 0 Dec 31, 2002 01:17 PM
