Old Mar 19, 2011, 12:14 PM
Mathelo is offline
Find More Posts by Mathelo
USA, CT, Stamford
Joined Jun 2006
2.4 GHz Antenna Placement
There is an excellent article by Sherman Knight on 2.4 GHz antenna placement in the April issue of R/C Soaring Digest, page 14. You can find it free online here. http://www.rcsoaringdigest.com/pdfs/...011-04Orig.pdf.
Anyone interested in optimizing their 2.4 GHz installation should read this article. Itís not just for sailplanes.
One of the authorís observations I found very interesting was the positive impact on fade count of ďusing the plastic tubes that come with the Spektrum 9300 receiver (or some other RF transparent tube).Ē
This tubing can be purchased as part of the Spectrum 2.4GHz Antenna Exit Guide [SPM6824] kit but there must be a generic source for this tubing.
Or would any tubing work?
What do you all think?
Louis
Mathelo is offline Find More Posts by Mathelo
Old Mar 19, 2011, 06:00 PM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Louis
Thank you for the link. I have a similar follow-up question.
Does bending the "active" 31mm of the antenna reduce its effectiveness, and if so to what extent?
I'd imagine that puposefully scrunching up that little bit of wire into a tight ball would drastically cut down on its ability to "see" the signal, but that's no more than intuition. The author of the article shows the active portion of his antennae following a curved path through a plastic tube. Sure, the _length_ of the wire may still be 31mm overall, as it is in the reductio ad absurdum "scrunched ball" example, but the straight-line 31mm dimension is a thing of the past.
To what extent is it OK to bend the "active" 31mm?
H2SO4 is online now Find More Posts by H2SO4
Old Mar 28, 2011, 06:17 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Not good to bend it.
For the tubing, I use teflon thin-wall. Of you use coax-based antennas, I strongly urge you not to cut the shielding yourself, but rather to buy replacements.. it is impossible to perfectly trim the shielding without damaging the inner wire unless you have the right tools.
My neighbor sells replacements on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=280640661211
But I can also pick them up from you and send some over you want to pick some up on rcgroups.
P.S. The tubing that comes from spektrum is about 3 times too big... makes a huge hole in the fuse
la528it is offline Find More Posts by la528it
Old Mar 30, 2011, 07:09 PM
Mathelo is offline
USA, CT, Stamford
Joined Jun 2006
Where do you purchase the teflon thin-wall?
Louis
Old Mar 30, 2011, 07:15 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
Louis
How much do you need? Mcmaster carr its around $1.70/ft... I bought in bulk, shoot me a pm for a better deal
Old Feb 25, 2012, 10:41 PM
g725s is offline
Find More Posts by g725s
United States, CA, Laguna Niguel
Joined Jan 2012
Thanks for posting that article. I'm new to RC planes and just putting a Radian together with my own RX. From reading that article and the Futaba manual, I get that the most important part of the 2.4GHz wiring is the roughly 1.5" exposed portion of the wire. And my Futaba manual also seems to indicate that this portion of the wire, which they refer to as the "antenna" is to be as straight as possible. And that the two antenna's are to be 90 degrees to each other.
So the author of that article has some good info but he seems to be wrong in bending the antenna in its placement.
g725s is offline Find More Posts by g725s
New Product New 2.4 Ghz Ground Station with integrated Vrx and Patch antenna nakelp86 FPV Talk 409 Apr 02, 2013 12:19 PM
Discussion is Hitec 2.4 GHZ Single Antenna (BODA) is as Good as Dual Antenna system ? lazy-b Radios 383 Mar 22, 2011 06:47 AM
Help! 2.4 Ghz system with 2.4 Ghz radio xlork FPV Talk 13 Jan 15, 2011 03:52 PM
Discussion Is it safe to use 2.4 GHZ Video Transmitter on Spektrum DSM2 2.4 GHZ ? lazy-b FPV Talk 2 Sep 04, 2010 11:28 AM
Question 2.4 GHZ receiver antenna placement sleep4 Sailplane Talk 15 Jun 13, 2009 04:01 PM
