Old Mar 18, 2011, 06:52 AM
Fox-composites is offline
Find More Posts by Fox-composites
Thailand
Joined Aug 2010
How do I know what timing to set the ESC to?
I know you can alter the timing on the ESC but how do you find out what to set it at?
Is it the motor that determines the timing?
Is there any way to find out what the timing should be set to?
I wish the motor manufacturers would say what the timing should be.
I'm a bit confused and need to learn about it.
Jim
Fox-composites is offline Find More Posts by Fox-composites
Old Mar 18, 2011, 07:05 AM
jfflyer is offline
Find More Posts by jfflyer
John Foltz
jfflyer's Avatar
Woodstock, GA
Joined Jan 2011
For a brushless motor, the number of poles (magnets) determines the optimum timing. Less timing advance is more efficient and higher timing advance is more powerful but uses more juice, within the range that a particular motor can use.
I set my 14-pole motors at 20 degrees. Fewer poles need a lower timing advance. Some ESC's give you a guide in their instructions. Here's the one from E-flite:
E-flite Pro ESC timing recommendations:
Low Timing Advance
Timing Degrees – 5 & 10
Motor Poles – 2 to 4
Expected Performance – Good balance of power and efficiency
Motor Poles – 6 or more
Expected Performance – Best efficiency and run time (lowest power)
Standard Timing Advance
Timing Degrees – 15 & 20
Motor Poles – 6 to 12
Motor Poles – 14 or more
High Timing Advance
Timing Degrees – 25
Motor Poles – 12
Expected Performance – Highest power, less efficiency
Don't confuse stator arms with poles, poles is number of magnets on the outer rotating part of a brushless outrunner. Inrunners on the other hand (magnets in the center) are almost always 2 pole.
You might find more help for your motor here:
http://www.rcgroups.com/forums/showthread.php?t=1105695
jfflyer is offline Find More Posts by jfflyer
Old Mar 18, 2011, 07:26 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Here is a link to a timing test that I did on outrunners.
http://homepage.mac.com/kmyersefo/timing/timing.htm
Ken Myers is offline Find More Posts by Ken Myers
Old Mar 18, 2011, 07:52 AM
Thailand
Joined Aug 2010
Thanks guy, all very useful stuff.
I have Turnigy 4030 880 kv that runs great if not a little hot.
I will reduce the timing to the low setting.
8 pole with 12 windings.
Thanks again.
Jim
Old Mar 18, 2011, 11:13 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
As Ken found out... in most cases, if a motor runs well on low, don't bother to change it.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 18, 2011, 12:38 PM
meshyx is offline
Find More Posts by meshyx
meshyx's Avatar
Norway
Joined Feb 2010
Yeah, start on low, and if the motor screeches (means the esc is loosing sync with the motor), or other weird things, try going higher.
meshyx is offline Find More Posts by meshyx
Old Mar 18, 2011, 08:45 PM
Thailand
Joined Aug 2010
Meshyx, there was a guy at our flying field with a smallish motor in a sport model. It screeched at full throttle.
This other guy had a programme card and put the timing to the high setting and it stopped the screeching.
Not sure what other problems it may cause, overheating or whatever?
This is all useful stuff. Thanks again to everyone.
Jim
Old Mar 18, 2011, 09:33 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Jim,
Certain motors seem to need high, certain motors seem to need low... but predicting which and why is beyond me!
My first experience with screeching was a Nippy Black 1812/100... horrible noise until I lowered the timing.... perfect after that.
Old Mar 18, 2011, 09:54 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
The ESC that have user changeable timing will usually have like a low, medium, and high and use the medium as the default.
Generally higher timing will increase RPM and motor temp and lower timing will drop the RPM and the motor will run cooler. So most of the time you can just leave it on medium. But if it stops a screeching problem, then it makes sense unless the motor gets too hot.
Too hot is also a result of the throttle use, if it is getting too hot you can prop down or back off on the throttle some to drop the temp.
This is no free lunch, if you get more power out of a motor there is always a price somewheres else, motor temp, battery duration, etc.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Mar 19, 2011, 09:16 PM
Thailand
Joined Aug 2010
Thanks again for all the advice.
I guess it is all a learning process and each motor ESC combination is different?.
Start with low and advance at your peril then? lol
My new Turnigy motor that I thought was really good appears to have a noisy bearing after only 2 flights. Looks like it has been fitted rather roughly.
Down the SKF shop on Monday again then. lol
Jim
Old Mar 19, 2011, 09:30 PM
jfflyer is offline
John Foltz
jfflyer's Avatar
Woodstock, GA
Joined Jan 2011
Low is not the best setting for high pole count motors, and may not even work well on some of them, depending on the degree of automatic timing advance your ESC has for varying motor speeds.
Old Mar 19, 2011, 09:50 PM
Thailand
Joined Aug 2010
Ok. I will need to get my watt/amp meter, temp gauge out and do some serious testing.
Who including me thought going electric would be easy? lol
Jim
Old Mar 19, 2011, 09:56 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I run virtually every 14-pole motor I test on "low"... and even Steve Neu's Neutrino (26-pole), which I reviewed for him, ran well on "low".
Old Mar 19, 2011, 11:35 PM
jfflyer is offline
John Foltz
jfflyer's Avatar
Woodstock, GA
Joined Jan 2011
Then you probably use an ESC with dynamic timing that detects the optimal setting for the motor and adjusts it according to motor speed. A fixed 5 degree advance isn't going to work well with such a motor.
Old Mar 20, 2011, 12:09 PM
Jack
USA, ME, Ellsworth
Joined May 2008
I'm told that the Castle Creations ESCs will not normally show major changes when you changed the timing because of the "quality of their algorithms" or something like that. You can see that, at least to some extent, in the timing testing I did on a motor here using a Phoenix 80 ESC:
http://www.rcgroups.com/forums/showp...&postcount=984
The link has the full details and images from the eLogger, the summary was:
Low (0) timing - 10 second full throttle averages:
6,775 RPM, 10.8V, 16.9A, 183 Watts - temp 68F to 75F
Medium (5) timing - 10 second full throttle averages:
6,904 RPM, 10.8V, 17.4A, 188 Watts - temp 81F to 86F
High (10) timing - 10 second full throttle averages:
6,885 RPM, 10.8V, 17.7A, 192 Watts - temp 71F to 78F
On the Phoenix ESC the default is Medium or 5 degrees of advance. But I don't see much incentive to fool around with changing the timing much...
Jack
Help! How do I know if ESC or motor is burnt out? demuddy Electric Motor Design and Construction 24 Sep 15, 2010 03:59 PM
Help! How do you know what C rating your ESC can handle? Rayzors Edge Foamy EDFs 9 Jan 31, 2010 01:10 PM
Discussion Timing : after so much years of using BLM ..... What Do we know about timing barney 69 Power Systems 3 Oct 15, 2009 11:44 AM
Help! what timing do I set on my ESC for the Feigao 540 8L motor mechengineer03 Electric Motor Design and Construction 0 Nov 24, 2008 10:45 PM
Discussion Beginner Question: How do I know what ESC/Battery/Motor combo to get? The L Power Systems 28 Oct 10, 2006 05:16 PM
