Old Apr 10, 2011, 10:53 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
and what speeds and run time will i get out of this scorp?
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Apr 10, 2011, 11:08 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Stupid speed with the right prop..................you would need 2p for any runtime............
scorpion1 is offline Find More Posts by scorpion1
Old Apr 11, 2011, 01:21 AM
Diesel6401 is online now
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Maybe Low 60s with a m645 if setup right....2p would be a must.
Scorp I have a m645 I put on the Pursuit tonight. Hope to test tomorrow.
Diesel6401 is online now Find More Posts by Diesel6401
Old Apr 11, 2011, 04:42 PM
Joined Sep 2009
But will i atleast get 5 minutes out of my 2s1p 5000mah packs?
Old Apr 11, 2011, 05:19 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
5m of WOT I doubt it. That's a big ole motor.
Old Apr 11, 2011, 06:57 PM
Joined Sep 2009
So a leopard 4082 2200kv , turnigy 180a esc with a programming card with 2X 2s2p 5000mah 40c packs with a S&B m645 along with bullet connectors will be my next setup!
I would need a cooling jacket for this hot rod motor, and will i need to upgrade to dual cooling lines also?
I am excited for this project.
Thanks for all of the help and advices guys!
Old Apr 11, 2011, 06:59 PM
Joined Sep 2009
Scorp! stupid speed? too fast for this boat? bad idea?
Old Apr 11, 2011, 07:30 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
No......ever heard someone say "it was stupid fast"?..............means real fast. As Diesel pointed out.........most likely into the 60's.
I case you dont quite get all the "2p" stuff, you will need two more packs of what you already have and run two sets of two series packs for 10,000 mah. The 4082 will push the boat no problem, and the extra 16 oz. will only help it.
Another option is to run two of these packs in parallel. These are a super bargain and would give you 10,000 mah and 300amps constant!!
http://www.hobbyking.com/hobbyking/s...idProduct=8588
Old Apr 11, 2011, 08:00 PM
Joined Sep 2009
So technically im running on 8cells but still at 14.8v?
cant I use these 2s2p hardcase packs? http://www.hobbyking.com/hobbyking/s...dProduct=11614
I just took the boat out for a run and flipped it for the first time on 3-4inch chop. not a good idea but it stayed dry!
Old Apr 11, 2011, 08:51 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Yup, you'd have 8 cells in the boat, but you would have 2 pairs of 2x2 in series paralleled together.
Those hardcase packs won't give you the power you need. You will need 8000-10000mah of capacity. If you can find 2s8000mah or 2s10000mah packs you could run 4s1p like you are now, but it'll be much easier to find 2s4000 or 2s5000mah packs and just run them in parallel to get more capacity.
wparsons is offline Find More Posts by wparsons
Old Apr 11, 2011, 09:14 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I think you may have meant 4s...................
Airplane, the packs you posted are only 5000 mah, dont let the 2p fool you, they are 2p inside.........2 sets of series 2500 cells.
Old Apr 11, 2011, 09:47 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
No, I meant 8... Count the cells in a 4s2p configuration. It's only 4s in series, but there's still 8 individual cells...
Old Apr 11, 2011, 10:04 PM
Joined Sep 2009
Alright guys. I'm beyond confused. So i did a visual picture because i learn better visually .
So stock setup is running on two 2s 5000mah in series, because the the positive wire runs into the first battery then out to the next battery then back to multiply the voltage.
In the future upgrade setup, will be running on two 4s 5000mah in parallel, because the positive wire connects to both packs at the same time, and a negative wire draws both packs at the same time, keeping the voltage the same, but more capacity.
Is this all correct?
I drew out a diagram to help explain this.
Also i found an example of a parallel setup in somebody else's MG and it is a bit confusing.
Old Apr 11, 2011, 10:30 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
If you run 2s4000 or 2s5000's in parallel you have 2s 8000 or 2s 10,000.........that was my point.
He needs to run 4s5000's in parallel like i suggested earlier.
Old Apr 12, 2011, 02:07 AM
wilsta67 is offline
Find More Posts by wilsta67
Australia, QLD, Brisbane
Joined Sep 2010
why not a cc 2200kv you can buy them from ebay for 100$and a jacket for $20 save yourself the money and ditch the program card the t-180 is easy to program with out it.
http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
http://www.offshoreelectrics.com/pro...ham-castle1515
wilsta67 is offline Find More Posts by wilsta67
Discussion Miss Geico w/ New paint gettign some air iPOWERSi Racing Boats - Electric 6 Mar 22, 2011 06:24 AM
Discussion Miss Geico - Maiden voyage Boomer1 Racing Boats - Electric 359 Mar 13, 2011 07:24 PM
For Sale Miss Geico ProBoat RTR dhmojo Boats (FS/W) 5 Oct 06, 2010 03:39 PM
Discussion Maiden for Miss Geico scorpion1 Racing Boats - Electric 6 Sep 17, 2010 10:48 AM
Discussion NEW*** ProBoat Miss Geico 29 Offshore Cat! Darin Jordan Racing Boats - Electric 18 Sep 05, 2010 07:59 AM
