Old Mar 17, 2011, 10:06 PM
SC2000 is offline
Find More Posts by SC2000
SC2000's Avatar
Joined Feb 2011
PIXIM Camera!!!!!
690TVL Ultra WDR Pixim HD CCTV Mini Camera 3.7mm Pinhole Lens
US$106.50
Weight:0.18 LBS
Features and selling points:
1.Pixim's innovative SEAWOLF image sensor chip
This camera adopts innovative DPS (Digital Pixel System) image sensor and image processing technology. The sensor picks up details from each pixel based on hundreds of samples per video frame. vs CCD's limited exposures, to ensure wider dynamic range than is possible with analog CCD. The image quality is good.
2.Ultra Wide Dynamic Range
The captured wide dynamic range is 102dB typical and can reach 120dB maximum
3.High Effective Resolution:
Image resolution as high as 690TVL, offering enhanced horizontal and vertical resolution useable in existing as well as new CCTV systems.
4.Auto D/N shift mode
Adopt color mode in day, because the light is enough in day; at night the illumination is lower which need higher sensitivity and better image quality, so it change to B/W mode automatically.
5.High Class Menu Operation
6.3D-DNR
7.DNR (Digital Noise Reduction)
8.High Resolution, 690TVL-E
9.Power input: DC12V
10.3.7mm pinhole lens
11.With OSD menu, of great performance.
12.Suitable for FPV
More Details Pls View: http://www.securitycamera2000.com/pr...hole-Lens.html
please contact us via FAQ support center http://support.securitycamera2000.com/
More FPV equipments:http://www.securitycamera2000.com/FPV/fpv.html
Best Wishes,
SC2000
SC2000 is offline Find More Posts by SC2000
Old Mar 18, 2011, 03:14 AM
SC2000 is offline
SC2000's Avatar
Joined Feb 2011
690TVL Ultra WDR Pixim SEAWOLF HD CCTV Mini Camera 2.8mm Lens OSD
US$107.50
0.17 LBS
This camera adopts innovative DPS(Digital Pixel System) image sensor and image processing technology. The sensor picks up details from each pixel based on hundreds of samples per video frame. vs CCD's limited exposures, to ensure wider dynamic range than analog CCD.
5.High Class Menu Operation (OSD)
6.3D-DNR
10. 2.8mm wide angle lens
11.High performance OSD menu
12.Suitable to install on FPV model
More Details Here: http://www.securitycamera2000.com/pr...-Lens-OSD.html
More FPV Equipments Here: http://www.securitycamera2000.com/FPV/fpv.html
Best Wishes,
SC2000
Old Mar 18, 2011, 04:50 AM
borneobear is online now
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Please provide a list of Lenses that you may recommend if we want to upgrade from the stock lense.
Also, we would be grateful if you could post some videos taken with this camera.
Cheers,
BB
borneobear is online now Find More Posts by borneobear
Old Mar 18, 2011, 12:44 PM
Fred79 is offline
Find More Posts by Fred79
Ithaca, NY
Joined Jan 2011
I just came across this new camera today. I thought it was eye-catching the way their description has in RED letters "Suitable for FPV"... after all, their site is dedicated to SECURITY CAMERAS! I guess they see a significant amount of purchasing by RC nuts.
I'm curious how this Pixim Seawolf stacks up against the Sony Super HAD II. I notice that the resolution is up on the seawolf from 600TVL on the sony to 690TVL on the Pixim, but the Sony has better low light illumination (0.01 lux vs 0.1lux). The pixim may have better algorithms (at least newer) than the Sony for wide dynamic range, which might help if you are flying trying to see the ground if the sun is visible in the sky at the same time... but tests are in order to compare these two.
I would also caution against confusion between the Sony Super HAD I and the Super HAD II. The Super HAD II (in my experience) is better than the older Super HAD I. Here is a brochure on that.
http://www.sony.net/Products/SC-HP/c...eaturing52.pdf
SONY SUPER HAD
http://www.mintron.com/htm/q&a/htm/s...d%20camera.htm
Sony EXview (0.001 lux)
http://www.mintron.com/htm/q&a/htm/e...d%20camera.htm
Although it is touted as "the industry's proven greatest wide dynamic range (WDR) and accurate color performance at half the hardware build cost," the pixim is certainly more expensive than a super HAD ii camera. Also, note that anyone flying with goggles showing a max resolution of 640x480 will not even be able to appreciate the full resolution of 600TVL, let alone 690TVL. You will only see those gains if you have Headplay 800x600 resolution goggles, an external display screen with at least 800x600 resolution, or a DVR capable of recording at least 800x600.
Originally Posted by borneobear View Post
Please provide a list of Lenses that you may recommend if we want to upgrade from the stock lens.
BB
I believe they are standard CS lenses, so any one you want will screw in to the mount, you will just need to adjust the focus yourself.
Fred79 is offline Find More Posts by Fred79
Old Mar 27, 2011, 12:14 PM
Fred79 is offline
Ithaca, NY
Joined Jan 2011
I contacted SecurityCams2000.com and they told me that this PIXIM Seawolf camera uses a CMOS sensor, not CCD. It has two selling points:
1) 690 line high resolution.
2) very advanced dynamic range.
Old Mar 28, 2011, 11:38 AM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
It is also about 2 inches by 2 inches. Certainly not small.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Mar 30, 2011, 01:50 AM
SC2000 is offline
SC2000's Avatar
Joined Feb 2011
Hi,
We can only sell the board camera. Means sell them without case.
Take PZ0482 for example,pixim camera with 3.6mm lens, board camera only without case, it is USD 101.5, USD 5 less than the case one. The size would be 38mm*38mm.
So, to sum up, the case pixim camera only USD5 expensive than the board one for these three kinda pixim cameras.
Best Wishes,
SC2000
Old May 11, 2011, 04:44 PM
Jmmonti is offline
Find More Posts by Jmmonti
Joined May 2011
Pixim Seawolf Resolution
Hi,
Someone commented below that the higher 690 HTVL effective resolution of Pixim's new Seawolf chip cannot be seen in 640 x 480 displays, but that is not correct. The new higher resolution capability of Seawolf improves the vertical TV lines so the video output viewed at 640 x 480 has visibly higher resolution than SuperHAD II CCDs as well as our older Orca image sensors.
Videos captured with Seawolf can be found here (look for the clips marked as New):
http://www.pixim.com/image-compariso...by-side-images
John Monti
Pixim, Inc.
Jmmonti is offline Find More Posts by Jmmonti
Old May 19, 2011, 11:19 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
Has anybody tried one of these cameras on an FPV ship yet? I'm curious how well the signal is broadcasted & received.
Wind_of_Change is offline Find More Posts by Wind_of_Change
Old May 20, 2011, 03:47 AM
fpvnick is offline
Find More Posts by fpvnick
My other vehicle is unmanned
fpvnick's Avatar
Joined Jan 2010
I have the cased cam didn’t see there was an uncased version which is a shame as I was going to remove the heavy metal case from the one I have. but it holds the lens over the sensor so if removed would have nothing to screw the lenses in I have tried it in the garden and seems good not had it on the plane yet as it pushes my c of g to far forwards. My only concern is how it handles vibration as it’s a cmos sensor could suffer from wobble vision but then again if the plane is setup well vibration should not be an issue.
fpvnick is offline Find More Posts by fpvnick
Old Sep 22, 2012, 05:05 PM
ronmen is offline
Find More Posts by ronmen
ronmen's Avatar
Israel, Tel Aviv
Joined Feb 2010
Little misty results with 690TVL
Hi,
I am new to the FPV area and recentally mounted the 690TVL
http://www.securitycamera2000.com/pr...-OSD-Menu.html
on Multiplex FubCub
I got little misty images as you can see in:
FPV from FunCub canopy at Gur-Arie airfield (2 min 1 sec)
What could be the reason and can it be solved via camera parameters?
Ron.
ronmen is offline Find More Posts by ronmen
Old Sep 23, 2012, 08:11 AM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Did you try focusing the lens? How the hell can you see where you're going? All I can see is about 90% sky!
subsonic is offline Find More Posts by subsonic
Old Oct 07, 2012, 02:56 PM
ronmen is offline
ronmen's Avatar
Israel, Tel Aviv
Joined Feb 2010
Thanks sub, I focused the lens and tilt down the camera, now it is much better
Discussion DX201 pixim or WDR700 OSD Color Camera 550 Lines SONYŽ Super HAD II wiper1974 FPV Talk 4 Mar 28, 2011 09:59 PM
Discussion Pixim / DX201 owners - got some questions... EyeFlyPlanes FPV Talk 2 Mar 01, 2011 01:15 AM
Discussion Pixim DX 201 for $80 + Shipping EyeFlyPlanes FPV Talk 9 Feb 21, 2011 12:14 PM
Question Camera mount (GoPro and FPV camera) on a servo? rclab1 FPV Talk 1 Nov 12, 2010 12:51 PM
Wireless Video Camera or Digital Camera Netman Aerial Photography 3 Nov 17, 2004 12:10 PM
