Old Mar 17, 2011, 10:09 PM
buddman36 is offline
Find More Posts by buddman36
Aircraft Addict
buddman36's Avatar
Jersey
Joined Mar 2010
Twin 55mm edf twin setup getting hot ??
I AM USING THIS MOTOR(AEORC.COM Model#ADH300XL EDF MOTORS AND 55MM FANS) IN THE HC HOBBY MIG-29 TWIN SETUP WITH TWIN EXCEED RC 40 AMP ESC AND 2200MAH 3S 30C LIPO AND THE ESC'S AND BATTERY GOT REALLY HOT,THE MIG FLEW NICE WITH LOTS OF THRUST BUT WHY DID MY ESC AND BATTERY GET SO DARN HOT, THE ESC'S ARE MOUNTED OUTSIDE THE AIRFRAME TO BREATH??? ANY ANSWERS WOULD BE GREAT !!! Model#ADH300XL EDF MOTOR FOR 55MM EDF (TWIN ), EG: NOT ENOUGH BATTERY,NOT STRONG ENOUGH ESC'S, TO MUCH BATTERY ??? CAN'T FIGURE THIS ONE OUT ?
buddman36 is offline Find More Posts by buddman36
Old Mar 17, 2011, 10:14 PM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
Bigger ESC's would run cooler as they wouldn't be as close to their limit. 60 Amp speed controls would probably run a lot cooler. How long does the plane fly on that battery? If the battery drains too fast or doesn't have enough cooling, it will get hot.
Please try not writing in all caps, it is hard to read.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Mar 17, 2011, 11:42 PM
Wintr is online now
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Which kv motor is that, the 5250 or the 4250? If it is the 5250, it should draw about 30 amps with a 55mm fan; the 4250 would clearly be less. In either case, that current is well below the limits of the battery, ESC and motor. Are you certain the fan isn't rubbing inside the duct? At full throttle, that would be about a 4 minute flight; you didn't fly more than 4 minutes, did you?
Wintr is online now Find More Posts by Wintr
Old Mar 17, 2011, 11:45 PM
cryhavoc38 is online now
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
need to have info on your batteries. what brand?
how old etc
cryhavoc38 is online now Find More Posts by cryhavoc38
Old Mar 19, 2011, 04:36 PM
Aircraft Addict
buddman36's Avatar
Jersey
Joined Mar 2010
No, it was close to 4 minutes but think the timing on esc's should be set to medium ?? I have the 5250's in the 55mm edf's, need to know if these motors are 2 or 6 poles or what ?? Timing setting could also have a heat effect right ??
Old Mar 19, 2011, 04:38 PM
Aircraft Addict
buddman36's Avatar
Jersey
Joined Mar 2010
how old etc
New Thunder Power 30c 2700 3s Lipo, was going to try a higher c rating battery ? Thought it was a 2200 mah Lipo, it's a 2700 ! Mostly flew at 1/2 throttle for this Jet was Groov'n, Landing this HC Hobby Mig-29 is a Blast, just glids in with the nose up !! afraid to make it to nose heavy with a bigger Lipo, seems to fly so nice with a 3s 30c, adding weight is making Plane handle a little harder and making it touchy in flight. The old equipment was somewhat junk with 2 20 amp esc's and 4300kv edf motors/55mm fans. New set-up was overkill I think, not trying to go 100 mph just that old system had lots of under powered problems (Junk!!)
Old Mar 19, 2011, 05:09 PM
Aircraft Addict
buddman36's Avatar
Jersey
Joined Mar 2010
Fans do not rub and are balanced perfectly !! They are synchroed perfectly as well, need to find out how many poles, 2, 4, 6 or ?? Timing on esc is set to low, should it be set to medium ?
Old Mar 19, 2011, 06:26 PM
Aircraft Addict
buddman36's Avatar
Jersey
Joined Mar 2010
Playing around with the timing and still gets hot, esc's at 140 degree's!! Lipo was 120 degree's and motors at 100 Degree's. That was on the bench without any airflow over the esc's or the Lipo. I only have a Ton of 2200 30c batteries nothing higher than 30c ! Waiting for a couple 40-45 C rated Lipo's that I ordered !!! What about a 25-30c 4 cell Lipo ?????
Old Mar 20, 2011, 08:47 AM
Aircraft Addict
buddman36's Avatar
Jersey
Joined Mar 2010
Sorry for the caps ! I have a pair of 55 amp esc's ordered and a few 40 & 45 C Lipo's ordered too. Don't want to pull motors to swap, will be a real pain to tear them out so will have to add the weight of bigger esc's and Lipo, luckily the new edf's were 80 grams lighter so will move the esc's as far back as possible and help compensate the added Lipo weight in the nose, need the same C.G. for this plane flies so smooth, glides nose up and Dead-stick all the way till 2 feet off ground and Flar-out for nice Landing's, So the bigger esc's it is !!
Build Log HC MIG-35 Twin 55mm w/Thrust Vectoring. AEO 5250KV EDF Units No Good :( Orion Pax Foamy EDFs 125 Feb 12, 2012 01:25 PM
Help! question about futaba and twin edf setup underpoweredPNPs Foamy EDFs 4 Sep 10, 2010 04:12 PM
Discussion Whats a good twin BL setup for 55mm fans? Speedfreak Power Systems 1 Jul 19, 2008 06:29 PM
Discussion Whats a good twin setup using Jetscreamers or Dons motors for 55mm fan? Speedfreak Foamy EDFs 0 Jul 18, 2008 05:25 PM
Discussion whats a good twin 55mm setup? Speedfreak Foamy EDFs 2 Jun 29, 2008 01:52 AM
