Old Mar 17, 2011, 07:28 PM
WAFlyer15 is offline
Find More Posts by WAFlyer15
Kirkland/Redmond, WA
Joined Feb 2010
Recommendations: Scale Electric Float Flyer
Hey Guys,
I am looking for recommendations:
I have been flying my Easystar and UM P-51 and have an order on the way for a HK Cessna 182 w/ floats. I have helped my friend do some building on balsa models and am interested in doing one. I am looking for a mid size plane, 50"-80" wingspan, that is both land and water flyable. I have zero building equipment and a little bit of knowledge through assistance of friends and observation but thats about it. Let me know what planes you would recommend.
Jack
WAFlyer15 is offline Find More Posts by WAFlyer15
Old Mar 17, 2011, 09:07 PM
Kiwi is offline
Find More Posts by Kiwi
New Zealand, Otago, Harwood
Joined Sep 2004
I'm sort of following the same path as you from the easystar onwards and want a float plane. As a change from the very hackneyed bl**dy Piper Cub I am doing an Auster.
The thread is here if it is of any interest to you.
http://www.rcgroups.com/forums/showthread.php?t=1109897
Kiwi is offline Find More Posts by Kiwi
Old Mar 17, 2011, 09:17 PM
Joined Feb 2010
I have done a quick search and only found plans for this plane. Is it a kit build or cut from scratch? If so how hard is it to do that and what tools would it require?
Jack
Old Mar 18, 2011, 03:23 PM
wallis_100 is offline
Find More Posts by wallis_100
build like there is no 2moz
wallis_100's Avatar
United Kingdom, England, Bristol
Joined Apr 2009
If you are looking for a good scratch built model, that works well with either wheels or floats, then i can suggest loooking no further then any of the IVAN pettigrew designs.
http://www.rcgroups.com/forums/showthread.php?t=710485
He designs mainnly twins, but does do plans for both an Auster, and a chipmunk. Like all of Ivans designs they are relatively simple (though slightly time consuming to make) and fly beautifully.
I have his twin otter, which i fly with and without floats.
Scott
wallis_100 is offline Find More Posts by wallis_100
Old Mar 18, 2011, 04:52 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Sounds like maybe and ARF is the next step. Like an e-flite Beaver on floats.
http://www.horizonhobby.com/Products...FL4525#quickMM
Or are you looking for a kit? TW
TripleW is offline Find More Posts by TripleW
Old Mar 18, 2011, 09:37 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
I have always like the looks of this plane:
http://topnotchkits.com/index_files/TN_Kit7.htm
It's the Top Notch Bush Hawk. I haven't ordered mine yet and I haven't built one of their kits but it's on my list of ones to do.
-Stone1295
Stone1295 is offline Find More Posts by Stone1295
Old Mar 19, 2011, 10:38 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
From what I have read, successful scale float planes need quite a strong power system and large enough pontoons installed at the proper angles with retractable water rudders. Lightly built Piper Cubs are a fairly popular float plane conversion. You can get some ideas from IC float plane threads on this and other forums. I expect some will try floats on the PZ foam Stinson Reliant, a number of them are flying on skis.
PS: Found a short You Tube video of PZ foamy Stinson Reliant using Multiplex Fun Cub float kit. Requres modifying front landing gear and adding rear float supports. Comments didn't mention power system mods if any.
E-Challenged is online now Find More Posts by E-Challenged
Old Mar 19, 2011, 09:19 PM
Joined Feb 2010
Scott
I have been looking at these, they look like excellent planes, but I am not sure if a plan only plane should be my first balsa build. What sort of skills does it require? I have a friend who builds lots of balsa planes so I may be able to get a bit of help now and again. Would this require any special tools besides knife, heat iron, heat gun, glue, ect.
That looks like an excellent ARF, I have been looking at it every time I get to the hobby store... but I am more interested in the building side of things. Thanks for the recommendation.
Will have to check this one out. Looks quite interesting. Have you built one of their kits before? If so are they good quality?
Jack
Old Mar 19, 2011, 09:32 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Classicaero will be selling this kit when he gets done with it.
http://www.rcgroups.com/forums/showthread.php?t=1398744
Old Mar 19, 2011, 09:48 PM
Joined Feb 2010
Thanks for the heads up. Will keep an eye on that one.
Old Mar 19, 2011, 10:21 PM
Kiwi is offline
Joined Sep 2004
The Auster I am doing is from plans however lot's of bit's on the plan just don't work and also no floats are shown so maybe it's not really suited for a first build.
Have you had a look on the waterplanes forum
http://www.rcgroups.com/waterplanes-174/
you may get some ideas there
Old Mar 19, 2011, 10:25 PM
Joined Feb 2010
Ok, not too much of a problem as I did not really like the looks of the Auster. Will keep an eye on the waterplane threads.
Old Mar 19, 2011, 10:53 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
W15, Check out this forum.
Discussion Advice/Tips for a New Float Flyer???? (please?) MaximumBob Waterplanes 4 Mar 15, 2011 09:26 PM
Discussion Electric Float fly strawcuter Waterplanes 26 Feb 21, 2011 03:52 PM
Discussion Float flying with electric 3D plane? Krxtopher Waterplanes 7 Sep 20, 2010 12:25 PM
Discussion Shep mammoth scale fly in or float fly billarms Australia 1 Sep 09, 2010 06:36 PM
