This thread is privately moderated by Lindy757, who may elect to delete unwanted replies.
Old Mar 17, 2011, 12:47 PM
Lindy757 is offline
Find More Posts by Lindy757
Trader Rating: 4
"Hey Watch This!"
Weston, FL
Joined Apr 2009
Trader Rating: 4
For Sale
Mini Ultra Stik EP Ready-to-fly + new ARF kit! $225
Mini Ultra Stik EP Ready-to-fly + new ARF kit!....the original wing was destroyed when I moved so, I bought a whole new ARF kit to use only the wing on my original Ultra Stik. So, it's like getting two full planes. $400 invested...[B]BUY IT NOW for only $225!!
E-flite Mini Ultra Stick ARF
[EFL2250]
Motor: Turnigy C3530-1100
Spektrum AR-500 receiver
HexTronic 36 Amp ESC (Deans)
E-flite S75 servos install
Required BatteryLiPo 3S 2200mah
Based on the popular Hangar 9 Ultra Stick, the E-flite Mini Ultra Stick comes 95% prebuilt from balsa and light-ply and is covered in genuine UltraCote. At the heart of the Mini Ultra Stickís fun factor are two firewall options that let you use a wide variety of motor sizes, types and brands. This along with the ample clearance for larger props that its tall, lightweight aluminum landing gear provides gives the Mini Ultra Stick huge performance potential. You can push the envelope even further by adding the optional split quad-flaps.
The Mini Ultra Stick can be assembled and ready for flight in just 1 to 2 hours thanks, to:
Preinstalled control surfaces and hinges
Preinstalled control horns
Preinstalled pushrods
Bolt-on horizontal and vertical stabilizers
Preassembled landing gear with wheels attached
Features
Perfect transitional airplane for advancing pilots who want to learn aerobatics and for sport flyers who want easy comfortable sport flyer
95% factory-built; get flying in 2 hours or less
Lightweight balsa and plywood construction
Two firewall options to use a variety of motor sizes, types & brands
Includes molded firewall stick mount
Control surfaces have factory-installed hinges and control horns
Bolt-on tail requires no gluing and secures with two lock nuts
Optional quad-flap configuration
Tough, lightweight aluminum landing gear that's factory-assembled and tall enough to accommodate larger prop sizes
Covered in genuine Hangar 9 UltraCote
Great match for E-flite Park 450 Outrunner Brushless Motor
Easy access top battery hatch
Design based on Hangar 9ís popular line of Ultra Sticks
Specifications:
Wing Span: 38.75 in (985mm)
Overall Length: 34 in (865mm)
Wing Area: 325 sq in (21 sq dm)
Flying Weight: 22 - 25 oz (625 - 710g)
Motor Size: Park 400 Inrunner or Park 450 Outrunner
Radio: 4-channel or greater (7-channel for quad flaps)
Servos: 4 sub-micros (6 sub-micros for quad flaps)
Trim Scheme Colors: UltraCote Fluourescent Blue, Flame Red, Transparent Red & White
CG (center of gravity): 2.25 in (57mm) behind the leading edge
Prop Size: 10x7 - 11x7
Hardware Included: Yes
Speed Control : 20A Brushless
Recommended Battery: 2100 mAh 3-Cell 11.1V Li-Po
Flaps: Yes (optional)
Control Throw (Ailerons): 1/2 in (15mm) Up/Down Low Rate or 5/8 in (19mm) High Rate
Control Throw (Elevator): 9/16 in (18mm) Up/Down Low Rate or 7/8 in (23mm) High Rate
Control Throw (Rudder): 7/8 in (23mm) Right/Left Low Rate or 1-1/4 in (32mm) High Rate
Approx. Flying Duration: 10-20 minutes
Scale: Park Flyer
Approx. Assembly Time: 1-2 hours
Gear Ratio: 6.5:1 when using Park 400 Brushless Inrunner
Lindy757 is offline Find More Posts by Lindy757
Old Mar 18, 2011, 12:00 PM
Jon Craig is offline
Find More Posts by Jon Craig
Trader Rating: 43
ModemMisuser
Lafayette, IN
Joined Dec 2007
Trader Rating: 43
Just letting you know - MUS are very, very easy to ship. No need to resort to GHound; UPS will handle just fine. MUS = tiny.
Jon Craig is offline Find More Posts by Jon Craig
Old Mar 18, 2011, 07:10 PM
Lindy757 is offline
Trader Rating: 4
"Hey Watch This!"
Weston, FL
Joined Apr 2009
Trader Rating: 4
Cool! Thanks Jon. I should know that...I'm a UPSer too!
Article Hobby Express eRC Micro Stik Ready to Fly pda4you Micro Ready-to-Fly 143 Aug 19, 2013 10:59 AM
For Sale Brand new PZ Ultra Micro p-51D Mustang Ready To Fly Speed_Racer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Oct 02, 2010 06:39 PM
For Sale .60 Big Stik ready to fly kyle1745 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 06, 2010 02:45 PM
Discussion Great Planes Big Stik 40 ARF versus Hanger 9 Ultra Stik 40 ARF fishingships Scale Fuel Planes 2 Oct 23, 2008 10:29 PM
