Old Mar 17, 2011, 11:08 AM
feiyudz is offline
Find More Posts by feiyudz
中国, 广西壮族自治区, 桂林市
Joined May 2010
New Product
FY91Q with GPS Position Hold-Telemetry,Firmware and Configuration Software
Tips:Any news will be updated in the first 3 posts in the first page,please keep an eye on it any time.Important files will be uploaded and attached at the end of this post.
How to contact FY?
Technical support : tech@feiyu-tech.com
Consult and purchase: sale@feiyu-tech.com
Website of feiyu-tech: http://www.feiyu-tech.com/
FY91Q firmware1.1:
http://www.rcgroups.com/forums/showa...5&d=1310722483
Brief manual for upgradation of FY91Q firmware 1.1:
http://www.rcgroups.com/forums/showp...&postcount=801
Detailed manual for upgradation of FY91Q firmware 1.1
http://www.rcgroups.com/forums/showa...=4162405&stc=1
New PID parameters configuation software(in smaller window):
http://www.rcgroups.com/forums/showa...6&d=1310722409
Some tips to make the flight more safe and more easy(thanks for Jim)
- FY91Q components: http://www.rcgroups.com/forums/showp...&postcount=819
- Rx Failsafe settings: http://www.rcgroups.com/forums/showp...&postcount=698
- Tips for flying a multicopter with GPS: http://www.rcgroups.com/forums/showp...&postcount=593
- Initial GPS testing: http://www.rcgroups.com/forums/showp...&postcount=472
ESC recommendations for standard PWM: Bidproduct HW25a, ExceedRC Volcano series, HKSuperSimple (the programmable type not the basic), HK Blue Series, Mystery Blue series, www.quadroufo.com 30a, RCTimer, Towerpro, Turnigy Plush, YGE.
For GPS &Compass(thx for steve):
http://www.rcgroups.com/forums/showp...&postcount=748
[/COLOR]
Including 2 standard items:FY91Q controller and GPS&compass module.Total retail price :$399
Important Informs:
1.Check for Answers to any problems found in the real flight here:
http://www.rcgroups.com/forums/showp...89&postcount=2
2.Download the lastest manual (draft 6 in 7th July)here:
http://www.rcgroups.com/forums/showa...=4129579&stc=1
PS:in page 7,the pic at right top showing how to set the 3 way SW.It is not a standard setiing,please note you should set the order according to your own habbits.
3.Firmware updating software:
http://www.rcgroups.com/forums/showa...6&d=1310251184
4.Com port driver software for Win7&vista:
http://www.rcgroups.com/forums/showa...=4132826&stc=1
5.How to do the firmware upgradation:
http://www.rcgroups.com/forums/showp...&postcount=717
Key feature:
1.Self-stabilization and mixing controll for quad and other multi copters such as y6 and x8.
2.Bera Altitude Hold.
3.GPS Postion Hold.
4.RTH.
5.FPV with OSD.
6.Simple Autopilot functions via GCS and dataradio,such as real time track recording and replaying offline,PID settings,and so on.
7.Firmware upgraded.
8.Almost all parts in one unit,easy to plug and play.
Some Videos:
FY91Q - Quadrocopter Controller - Position Hold Test GPS (1 min 44 sec)
http://static.youku.com/v1.0.0141/v/...did=-&showAd=0
http://v.youku.com/v_show/id_XMjc1OTY0NDA0.html
GPS position hold,Baro altitude hold,telemetry with OSD and dataradios,firmware upgradable,configuration software available,self stabilization for camera mount,and so on.
Yin
Important:
According to the agreedment between FY and me,I will manage the marketing and tech supporting for the FY as a part time job in the next 6 months or a little longer,untill the new members can take my position back.Please note that I was a main member of FY,and is knowing almost every details about FY products.And I am appointed as the distributor of all FY products all over the world.
Any questions,You can email me at feiyutech@qq.com.
where to buy?Sb ask me this question,em,Then I will list them out.
Greece:http://www.nemhobby.com/index.php?ta...r=&page=&sl=EN
Sorry,will update other webshops later.
feiyudz is offline Find More Posts by feiyudz
Old Mar 17, 2011, 11:09 AM
feiyudz is offline
中国, 广西壮族自治区, 桂林市
Joined May 2010
FAQs
0.Some tips to make the flight more safe and more easy?
For beginners(thx for Jim):
1.To the Y6 and X8 connections.
There is a stardard Y cable for the Y6.
Connection from FY91Q to y6 using Y cable:
2.Q:Are the data radio(606,602,605),Ap117 OSD,remote adaptor ,GCS can be used in FY91Q as well as in FY21AP and FY3ZT?
A:Yes! If you got any of them,then you need not to buy them for twice.
3.How to understand the working princeple of the FY91Q hovering and RTH?
Please check here:
http://www.rcgroups.com/forums/showp...&postcount=564
4.How to active hover function?
a)Take off,let go the stick for AIL and ELE,but maintain the altitude via THR stcik.
Trim out the AIL and ELE in flight.Leave that of RUD in its middle position and not trimed.
b)Ensure you can "hands free" with the quad leveled and altitud hold.
c)Change to hover mode via RC-TX,record the neutrol values in AIL,ELE,RUD and THR.
d)If the THR is not in middle position now,then the quad will be up or down.So move the THR stick to middle position(1400us-1600us),in order to remove any manual controlling signal in THR.The controller will offer auto controlling signal to maintain the current altitude.
5.How to active the RTH function?
a)Active Hover before letiing the quad to fly far away from you.But do not change to hover mode again before you active the RTH mode.
b)Change to RTH mode via RC-TX.
6.Why my AP117 can not display the right working modes?
Sorry to tell,AP117 was designed for FY21AP,there is 5 working modes in FY21AP,and 3 working modes in FY91Q.They are not the same.
A mistake was found in the manual for this problem.
And it had been solved in the firmware v1.1.You can get it work normally by firmware upgradation.
7.How to do the firmware upgradation?
--check here:
8.What's new to the firmware 1.1?
Two key points:
Hover Hold Activation
1) You now do not need to move the THR stick to the middle position after engaging hover hold (Mode 2).
2) When you engage Hover Hold, your hovering THR position will be recognized by FY91Q as the Hold altitude Throttle position (plus or minus range of 100Ás).
3) However, you need to remember this throttle position, especially for engaging RTH.
4) In this new firmware, you can change the altitude up or down during Hover Hold. But you need to bring your throttle stick back to the hover position when you first engaged Hover Hold.
5) Alternately, you can disengage Hover Hold, move to another location, hover and engage hover hold again. This way you don’t have memorize the throttle location.
AP117 OSD Display
The protocol of FY91Q Data output has been modified to fit that interface of AP117. Display flight mode display will now show as per the manual:
ABM=auto balance mode = stabilization mode
FAF=fixed altitude flight= hover mode
RTL=return to launch = RTH mode
We have two ideas about throttle setting for RTH mode. Please feedback which one you prefer:
1. Make the FY91Q altitude lock the moment RTH is engaged. FY91Q will control throttle level and fly the aircraft back to you at the same altitude as when RTH was engaged.
2. RTH will be engaged only if you put your throttle level to the hover hold level (you need to remember that level).
Yin
Old Mar 17, 2011, 11:10 AM
feiyudz is offline
中国, 广西壮族自治区, 桂林市
Joined May 2010
More informations
More informations:
Quad X4 FPV with OSD
FY-91Q FPV with OSD (3 min 37 sec)
Y6 Scorpion Frame
FY-91Q Y6 Scorpion Frame (4 min 13 sec)
V2 configuration
FY-91Q V2 Frame (2 min 10 sec)
Where to buy?
Check FY distributor/reseller list:
http://www.feiyu-tech.com/?page_id=43
More will be updated.
And you can buy from me or Adrian as well:
Email me in feiyutech@qq.com
(I have no time to take care my own website yet.)
Adrian's website:www.fyetech.com
Where to get help?
FY official emailbox:
feiyudz@yahoo.cn
Access FY official website:
www.feiyutech.com
I am in charge of the official website now,but no time to refresh the datas recently.Have to finish the tech files such as manuals and FAQs for all FY current products first.
Visit www.fyetech.com for latest news.
Testers that will get the samples sent from FY(though delay for some time,testers are still needed) :
1.jesolins
2.randall1959
3.ThaiskyDigital
4.patricklupo
5.MOE
6.warthox
7.saabguyspg
8.alll
9.Heiko
10.BB
11.Blunderbum
Old Mar 17, 2011, 11:18 AM
eli is offline
eli
Find More Posts by eli
eli
Sderot, Israel
Joined Jan 2003
Reserved
eli is offline Find More Posts by eli
Old Mar 17, 2011, 11:27 AM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
Woohoo, the thread/controller I've been waiting for!
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Mar 17, 2011, 11:33 AM
Rc Heli Halle is offline
Find More Posts by Rc Heli Halle
Rc Heli Halle's Avatar
Berlin / Germany
Joined Feb 2010
Please Yin , let us Test one Unit here in the Rc Heli Halle Berlin.
Please set us on the Tester List.
Rc Heli Halle is offline Find More Posts by Rc Heli Halle
Old Mar 17, 2011, 12:43 PM
ThaiskyDigital is offline
Find More Posts by ThaiskyDigital
Thailand
Joined Apr 2006
I am strong hope that you will not forget me.
ThaiskyDigital is offline Find More Posts by ThaiskyDigital
Old Mar 17, 2011, 12:49 PM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
price?
titeuf007 is offline Find More Posts by titeuf007
Old Mar 17, 2011, 12:51 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
Congratulations!
can we see a video of the OSD please?
Moe
Edit:
Y6 Scorpion Frame
V2 configuration
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Mar 17, 2011, 01:14 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
great to hear (see) about what u have talked about some month ago
warthox is offline Find More Posts by warthox
Old Mar 17, 2011, 02:29 PM
Hamanu is offline
Find More Posts by Hamanu
Hamanu's Avatar
United States, MI
Joined Nov 2003
Can't wait for this to be available I already have an airframe built for it........
Hamanu is offline Find More Posts by Hamanu
Old Mar 17, 2011, 07:07 PM
feiyudz is offline
中国, 广西壮族自治区, 桂林市
Joined May 2010
@Helidaho ,thanks!
@Rc Heli Halle ,sorry to tell,the public test will not be taken in large ranges.But I will try to match my promission to some of my old friends several months ago.Any news changed,I will anounce here.
@ThaiskyDigital ,Havn't seen you for ages!But I did not forget you ,my friend.You will get yours as promissed ASAP.
@titeuf007 ,Compared to the samilar products from other brands
@mkmkmk13 ,more videos coming soon,still under shooting and editing.
@warthox,yes,time passed quickly.Shamed to keep silent in a long time.But now it come true and I can apear again.
Old Mar 17, 2011, 07:42 PM
Thailand
Joined Apr 2006
I really glade that you still do not forget me, after last information I do not have any contact anymore, really really glade to see you over here again, I did sent MSN to you but no any reply.
Hope everyting be better.
Old Mar 17, 2011, 09:03 PM
milo12 is online now
Find More Posts by milo12
Joined Feb 2011
Will a Y6 configuration be supported? If so please have all top props CW and the lower props CCW.
milo12 is online now Find More Posts by milo12
Old Mar 17, 2011, 09:49 PM
nicnaimless is offline
Find More Posts by nicnaimless
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
subscribed!
Watching closely.
nicnaimless is offline Find More Posts by nicnaimless
Contest GPS Position Hold Development Universal ?? Rc Heli Halle Multirotor Talk 33 Jan 15, 2011 06:22 AM
Discussion Quad - Position Hold \ Back to Home GPS Info guyg Aerial Photography 1 Nov 22, 2010 02:06 PM
Discussion A GPS to hold position whenever I flick a Tx switch? GaryGress_1 Aerial Photography 2 May 21, 2010 09:51 PM
Discussion GPS position hold for helis? zaguruinzasky Aerial Photography 6 Dec 31, 2008 11:19 AM
