Old Mar 16, 2011, 10:34 PM
deegola is offline
Find More Posts by deegola
~Lookout below!~
deegola's Avatar
Las Vegas, Nevada
Joined Jul 2004
Help!
Charging a 6v flight pack with a standard 4.8v wall-wart
I recently bought a used plane. I didn't realize that the installed battery was a 5-cell 6v pack. I plugged in my standard 4.8v wall-wart charger.
Mt question is, do you think it's still safe to use?
deegola is offline Find More Posts by deegola
Old Mar 16, 2011, 11:06 PM
dmcquinn is offline
Find More Posts by dmcquinn
dmcquinn's Avatar
United States, MO, Chesterfield
Joined Jan 2004
yes, you can use a standard wall wart designed to charge a 4-cell pack to charge a 5-cell pack. It will take slightly longer but it will charge up fine. The wall wart charger is a fairly unsophisticated device that puts out more or less 50 mA of current at more or less 6 - 10 volts. It is current-limited, so that no matter what you hook to it, it is only capable of putting out about 50 mA. On my tests with a 4-cell pack I was getting a charge of 71 mA and with a 5-cell pack I was getting a charge of 48 mA. A 7-cell pack only charged at a rate of 18 mA. This was with a JR wall wart rated at 50 mA and 4,8 volts. But all the wall wart chargers are of similar design.
dmcquinn is offline Find More Posts by dmcquinn
Old Mar 16, 2011, 11:41 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
This is good advice, but why don't you tell us the specifics: What is the rated output current of the charger? What is the capacity of the battery. These numbers are readily available. Then we can offer more specific advice as to how long you should charge.
Daedalus66 is offline Find More Posts by Daedalus66
Old Mar 17, 2011, 01:08 AM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
I can confirm what dmcquinn wrote.
To measure current and/or voltage in receiver battery circuits while charging or discharging, you might want to build yourself a testing adapter like this one:
Miami Mike is offline Find More Posts by Miami Mike
Old Mar 17, 2011, 10:19 PM
deegola is offline
~Lookout below!~
deegola's Avatar
Las Vegas, Nevada
Joined Jul 2004
First off, thank you all for your replies.
Here's better specifics:
The wal-wart is a futaba - output 4.8vdc 100ma
The battery pack is 6v - 2500 mah (Previous owner not sure if nicad or nimh)
Thanks again!
Old Mar 17, 2011, 10:32 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Most wall warts don't have any sort of brains at all. They are constant voltage
and simply have limited current capacity so as not to cook a depleted
pack when you first hook it up. It's not regulated, it's just limited. The voltage
they put out is somewhere not far above the peak charge voltage of the pack, so the
current drops off as the pack gets closer to fully charged. My guess is, given
your particular wall wart, it will charge the 5 cell pack only a little bit,
and then then the current will drop off to practically nothing when
the pack voltage matches the charge voltage, long before the pack is charged.
You'd be better off just getting a real charger.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 18, 2011, 10:34 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Just to second that. Except that they are not constant voltage.
Even if it does deliver 100 mA, which is doubtful, a full charge will take days. You want at least 150 - 200 mA charger for that pack, rated for 6v, or a high rate one with peak detect.
The risk is not that you will damage the pack with your current charger but that it will be inadequately charged.
Old Mar 18, 2011, 10:46 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
I use this type charger all the time for both 4 and 5 cell packs. No problem, just takes a bit longer on the 5 cell packs and, yes, you will get a full charge--just takes a bit longer for a 5 cell than a 4 cell. If you have an ammeter just hook it up in series with the charge lead to see what the current is. As mentioned above, it will taper off a bit as the battery approaches full charge. The nice thing about using these for charging is that, if you forget and leave them on longer than necessary, no damage is done to the battery being charged. In fact, if this is the only type charger you use, you will get more lifetime (number of charge/discharge cycles) than you will get using a peak detecting charger.
Rodney is offline Find More Posts by Rodney
Old Mar 18, 2011, 11:32 AM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
Originally Posted by Daemon View Post
Most wall warts don't have any sort of brains at all. They are constant voltage...
No, no, no no, no! That's absolutely wrong. The one thing that wall-wart battery chargers are definitely not is "constant voltage"!
A power supply has constant voltage, to one degree or another, depending upon the degree of voltage regulation, but chargers meant for NiCd and NiMh batteries absolutely do not incorporate voltage regulation. Instead, they use current regulation. In fact, that's the basic difference between a power supply and a battery charger. A wall-wart battery charger has a simple circuit inside with essentially no solid-state electronics, but it's nevertheless designed to achieve a limited degree of current regulation while varying the voltage over a fairly wide range to accommodate the battery's varying state of charge.
When the label on a wall-wart battery charger denotes a specific voltage, that doesn't mean the the charger delivers that particular voltage, it only means that the charger was meant primarily to recharge battery packs that are nominally rated at that voltage. A charger labeled "4.8 volts" is primary designed to recharge 4.8 volts battery packs, but it will deliver a wide range of voltage during the course of recharging a battery as it maintains the current flow within certain limits.
Discussion charging a 4 cell pack with 10s furlan FMA Direct 1 Sep 25, 2010 10:07 AM
Discussion Charging 6v NiCads with 4.8v charger Mtn_Commando Radios 18 Aug 01, 2010 09:25 PM
Discussion Wall Wart charger for 6V? bverwolf Batteries and Chargers 4 Apr 10, 2009 08:23 PM
Wanted 4.8v AA Flat Standard Receiver pack... hcsk8ter Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 11, 2009 09:34 AM
Sold NIP Spektrum DS821 servos, 9.6v 1500 mah tx pack, 4.8v 1100 mah rx pack, accessories laughingstill Aircraft - General - Radio Equipment (FS/W) 1 Nov 13, 2008 04:26 PM
