Old Jun 23, 2011, 11:21 AM
Gary Binnie is offline
Find More Posts by Gary Binnie
Late for work again!
Gary Binnie's Avatar
Northampton, England
Joined May 2004
Hi Fede, I've just had a week on holiday so no progress to report!!
Yes, I have used that company but only for small items like metal rod, I am sure they would help you.
When my MN is finished it will have a Spektrum 2.4 ghz receiver (possibly a simple AR500) and JR NES291 servos for the fuselage. I have not decided on wing servos yet but will probably be Hitec.
Cheers
Gary
Gary Binnie is offline Find More Posts by Gary Binnie
Old Jul 02, 2011, 11:21 PM
az_gila is offline
Find More Posts by az_gila
Joined Oct 2008
Originally Posted by birdofplay View Post
FYI:
Those Flap / Brakes were used on the Full Sized Duster!
Not really, the Duster ones were pure dive brakes, while the Mini-Nimbus ones had a flap component, and the upper portion only activated after you exceeded full flap deflection.
The Duster brakes rotated about a torque tube in the brake.
The Mini dive brakes were spectacular and speed limiting - you could safely do a true vertical descent with them fully deployed.
The Duster brakes could be best described as wimpy - but the plane did side-slip nicely.
I owned both a Duster and a Mini-Nimbus....
az_gila is offline Find More Posts by az_gila
Old Aug 14, 2011, 06:59 AM
JimMcWhorter is offline
Find More Posts by JimMcWhorter
JimMcWhorter's Avatar
United States, VA, Chantilly
Joined Apr 2011
Can You Tell Where I can by these?
Originally Posted by Gary Binnie View Post
Hello folks,
I went after this kit and ended up with an unbuilt Graupner Cirrus as well. This is the early built-up wing and tail version, circa 1977.
The Mini Nimbus is a very special glider type to me as I owned and flew a full-size one for 20 years.
I have wanted to build one of these for ages and it will be my next project, hope to start building in a month or so.
The kit is fantastic quality, I have one small gripe with it though; the outline is not very scale. The forward fuselage is much thinner than it should be and the tail system rocker mount is a bit of an eyesore but model designers have to make compromises. Won't even mention the lack of trailing edge airbrakes!! Shall not be entering any scale competitions with it so who cares?!
The plan is to build it exactly as designed, the 'Variopop' linear servos might be difficult to get hold of though!
Some photos.
GB
I have been searching all morning for these. I first saw them on www.rcaerotow.com. See attached. I stumbled upon your post and the Lande-Klappen look to be the same. Can you tell me where to buy these?
Jim
RCG / USA / Region IV / NOVA Park Flyers
JimMcWhorter is offline Find More Posts by JimMcWhorter
Old Aug 14, 2011, 09:57 AM
Joined May 2004
Hi Jim, got your PM's thanks.
I believe this item is discontinued. Try searching for 'Graupner 93', they do come up on eBay sometimes, I'll look out on the UK site for you, they are probably more common on eBay 'de'.
Search there for 'Graupner Raritšt' or 'landeklappen'.
There is a Mini Nimbus kit on there at the moment, 301 Euros and climbing!!
No progress with mine recently, busy painting the house and making the most of the summer!!
Cheers
Gary
Old Aug 14, 2011, 11:56 AM
Robert Hansen is offline
Find More Posts by Robert Hansen
United States, HI, Kamuela
Joined Dec 2008
Try Hobby Lobby! They had them A year ago, Might be able to back order them? Worth A try. Bob Hansen
Robert Hansen is offline Find More Posts by Robert Hansen
Old Aug 16, 2011, 12:00 AM
iflytailies is online now
Find More Posts by iflytailies
aka Schleppmeister
PA
Joined Feb 2006
Jim
these air brakes have been discontinued
http://www.iflytailies.com/
iflytailies is online now Find More Posts by iflytailies
Old Nov 11, 2011, 08:50 AM
Bongai is offline
Find More Posts by Bongai
Antwerp - Isle of Man
Joined Mar 2008
Great job Gary !
Very happy to read and see the pictures. I still have one from 20 years ago. Only one leading edge and wingtip to glue and polish and it is ready to cover ... with real silk and dope. I hope I will soon find the place and time.
You will be as happy to fly it as to build it.
Bongai is offline Find More Posts by Bongai
Old Nov 11, 2011, 09:32 AM
Joined May 2004
Cheers, I thought Antwerp was in Belgium? Went to the TT races in 1982, good times.
This build is on hold at the moment (building other stuff) but I was able to help out a friend recently who needed to build a tailplane for a Cirrus 75, it's the same apparently.
Jim got his airbrakes BTW, I found some on eBay in the UK and the seller was kind enough to post them to the States.
Post some photos if you like (and welcome to RC Groups!).
Cheers
Gary
Old Nov 11, 2011, 10:14 AM
Richard N is offline
Find More Posts by Richard N
Lost in the Sky
Richard N's Avatar
Burleson, Texas
Joined Jun 2003
Alloy Airbrake Servo Operated
These look very similar in construction and function to a set of Graupner Teck-Doppel-Landeklappen System Schempp-Hirth that I have. All of the Graupners are very hard to find and these are available on Hobby King's site here: http://www.hobbyking.com/hobbyking/s...dproduct=19609
The blade length of these is about the same as the plastic Graupner Lande-klappen at 10".
They look like clones of the full scale ones.
Richard
Richard N is offline Find More Posts by Richard N
Old Nov 11, 2011, 10:31 AM
Paul Naton is online now
Find More Posts by Paul Naton
Paul Naton's Avatar
Lewisburg, PA
Joined Apr 2002
Found a nice shot of a mini in my collection.
Paul Naton
Radio Carbon Art Productions
http://radiocarbonart.com/
http://glidefast.typepad.com/
Paul Naton is online now Find More Posts by Paul Naton
Site Sponsor
Old Nov 11, 2011, 10:43 AM
Joined May 2004
With winglets no less! An aftermarket modification. The Mini Nimbus is a good glider but what it really needs is another 10 metres of span!! Always ran out of daylight in mine trying to get home!
The current Graupner brakes are easy enough to get hold of, Graupner 93 is the spoilers mentioned here (they are plastic flaps that hinge up from the front) are discontinued but people still have them in their lofts and sheds.
I'm pretty sure that you can build this kit without the spoilers, I found some mystery numbered pieces of balsa sheet which I discovered was a blanking panel for the spoilers.
Must get back to it sometime.
GB
Old Nov 13, 2011, 12:17 AM
Martini is offline
Find More Posts by Martini
Known Wind User
Martini's Avatar
USA, ID
Joined Jun 2004
[QUOTE=Paul Naton;19846855]Found a nice shot of a mini in my collection.
Awesome picture! is that a model or full scale?
Thanks, Martini
Martini is offline Find More Posts by Martini
Old Nov 13, 2011, 09:14 AM
Paul Naton's Avatar
Lewisburg, PA
Joined Apr 2002
These are full scale, from the UK.
Here is another shot.....
Paul Naton
Site Sponsor
Old Dec 14, 2011, 06:06 PM
Martini is offline
Known Wind User
Martini's Avatar
USA, ID
Joined Jun 2004
Mini Nimbus Model
Do'in some minor repair/work on my mini nimbus today and shot this cockpit photo.
Just wanted to share...
Gary - looking forward to when you get back to the build
Cheers,
Martini
Old Dec 15, 2011, 03:51 AM
Joined May 2004
Yep, so am I!!! It will be while though unfortunately, just too many other things on the go.
Great job on the cockpit, takes me back!!
GB
Gallery 6.6M HKM Nimbus 4 - yet another one takes to the wing SPasierb Scale Sailplanes 31 May 09, 2011 11:43 AM
Build Log Graupner Cirrus (the really old one!) Gary Binnie Scale Sailplanes 22 May 04, 2011 08:09 PM
Graupner Mini Nimbus build help ptlpc Scale Sailplanes 87 Mar 17, 2011 08:31 PM
Idea Yet another parallel balancing by dumping one battery into another one. everydayflyer Batteries and Chargers 11 Oct 23, 2010 08:12 PM
Discussion Another great TED Talk ... this one got me really thinking. logan5 Life, The Universe, and Politics 0 Sep 10, 2010 09:25 AM
