Old Mar 16, 2011, 10:50 AM
szmyk is offline
Find More Posts by szmyk
szmyk's Avatar
United Kingdom, England, London
Joined Jun 2007
Build Log
"Swallow" mahogany runabout
Hello.
I was "playing" with DelftShip some time ago, trying to make some project to build. As I love the mahogany classic runabouts I was heading to make something pretty .
This is what I've made up..
Swallow mahogany:
Now I'm working in AI to make drawings for laser cutting service.
Just curious, what do you think about the shape..?
szmyk is offline Find More Posts by szmyk
Old Mar 16, 2011, 10:12 PM
MKC Syd is offline
Find More Posts by MKC Syd
United States, NJ, Waldwick
Joined Jan 2009
Topsides look great, but not sure if its an optical illusion or not, the side on the bottom looks like it bellies down a bit. almost like a type of rocker in it. I think that this could make it bounce when running at speed
MKC Syd is offline Find More Posts by MKC Syd
Old Mar 17, 2011, 06:07 PM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
I have to agree with MKC Syd, that there is way more rocker in the bottom planning surface for the hull to run right. If you put a straight edge against the bottom of the hull at the transom and go forward until the bottom of the hull no longer is against the straight edge you will see that the planning angle of attack will have the bow running far to high.
Also MKC Syd is correct in that the hull built as shown in your drawings will be very prone to hopping or bobbing up and down along with the very real problem of cavatation. I think you would be better off if you ran your bottom planning surface parallel to the base line or water line from its deepest point of transition from lifting to planning surface.
frankg is online now Find More Posts by frankg
Old Mar 18, 2011, 05:26 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Hello.
Thanks for the advise. You have right..I will correct it in Delft and then i will post the newer version.
In the mean time I've designed logo and letters.
Old Mar 18, 2011, 02:16 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Ok. I've modified the project..made the bottom lines more smooth..
I think it's better than before..
Swallow:
Old Mar 18, 2011, 03:24 PM
Nederlander is offline
Find More Posts by Nederlander
Joined Feb 2009
I think Don Aronow would have put his name on this one!
Nederlander is offline Find More Posts by Nederlander
Old Mar 18, 2011, 04:32 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Ok..I've changed the project a bit more and now I have more curvy transition from deck to the side.I think it's far better now.
And 3D view:
Now I think I can start serious drawing in AI for laser cutting.
Best Regards
Old Mar 19, 2011, 07:17 AM
Joined Dec 2004
BY JOVE!!! I THINK HE HAS GOT IT!!! Really looking good now. The boat design looks a lot like something that would come from the boat shop of VAN DAM. I will be looking forward to the hull layout and build.
Old Mar 19, 2011, 09:47 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
I've made first lines plan for model.It will be 1200mm long, 240mm wide and 113mm deep hull.
I'm going back to work..
Old Mar 19, 2011, 04:52 PM
kenludd is offline
Find More Posts by kenludd
Rochester Hills, Michigan
Joined Nov 2009
Szmyk,
Very cool looking. When you say AI - mean Adobe Illustrator? ...yes?
Never thought to use the 3D tranform, if that's what your using. What version are you running if so.
Thanks, ken
kenludd is offline Find More Posts by kenludd
Old Mar 19, 2011, 05:17 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Originally Posted by kenludd View Post
Szmyk,
Thanks, ken
Hi. I'm glad that you like it.
To design the shape of the hull I'm using DelftShip software,
this software provides 3D modelling.
To make drawings for Laser cut service, add strips to the project and make it strictly for modelling, I'm using Adobe Illustrator.
I don't have such experience in AutoCAD as in AI.
Old Mar 19, 2011, 08:24 PM
Joined Feb 2009
What scale are you thinking of building in?
Old Mar 20, 2011, 09:33 AM
Melih PEKOL is offline
Find More Posts by Melih PEKOL
Istanbul / TURKEY
Joined Feb 2005
prima
Melih PEKOL is offline Find More Posts by Melih PEKOL
Old Mar 21, 2011, 09:57 AM
Josť MOta is offline
Find More Posts by Josť MOta
Joined Apr 2009
Congratulations!
Its hull is very beautiful. Ha some time ago I made a somewhat similar boat to that his.
Mota
Josť MOta is offline Find More Posts by Josť MOta
Old Mar 22, 2011, 05:21 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Frames almost ready
I've done some parts for laser cut, Now will try to arrange the hull inside.
Working...working..
Old Mar 22, 2011, 06:19 PM
Joined Feb 2009
Thanks for sharing this beauty. Every time I look at it I think twin Lamborghinis.
Old Mar 23, 2011, 07:18 AM
finn is online now
Find More Posts by finn
USA, FL, Middle Keys
Joined Sep 2010
20 stations? I would recommend 5to 8
finn is online now Find More Posts by finn
Old Mar 23, 2011, 07:36 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Hello finn..yes there are 20 stations..
If someone will build the model later, he will have always option to make less than 20.
What I'm building is the prototype of this boat..
Old Mar 23, 2011, 02:56 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Just a few hours of thinking and planning and I'll have ready drawings for laser cutting.
In the mean time I've made sort of like side view of the boat.
I've changed the stern a little bit
Old Mar 28, 2011, 12:37 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
The parts arrived:)
Hello.
I've just collect the parts from laser cutting. NICE!
I've got to start this week.
Old Mar 28, 2011, 02:23 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Very neat and tidy work. must be great to have the tools to do it that nicely---.
der kapitan is offline Find More Posts by der kapitan
Old Mar 28, 2011, 03:28 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Deck
The very first drawings of the deck..yet without chocks and smaller parts.
Last edited by szmyk; Mar 28, 2011 at 04:10 PM. Reason: changed for colour version
Old Mar 28, 2011, 04:07 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
I think that boat will look really nice Szmyk. Is it ready for sea trials yet? No? Well get to work. Pete
norgale is offline Find More Posts by norgale
Old Mar 29, 2011, 09:44 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Aye, aye, sir!
Old Mar 29, 2011, 10:10 AM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Originally Posted by szmyk View Post
Aye, aye, sir!
Old Mar 29, 2011, 04:51 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Frames setting
Hello.
I bought the mounting board and set the frames today.
place some stringers to check if everything is on place and in right order.
So far so good...
Couple of pictures from my dockyard:
In the mean time I'm trying to find some metal laser cutting service to make the exhaust covers.
Tomorrow I will sand the formers to the shape of the hull..
Mariusz
Old Mar 29, 2011, 05:00 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Very nice!!!
DT56 is offline Find More Posts by DT56
Old Mar 29, 2011, 07:28 PM
cookiemonsta is offline
Find More Posts by cookiemonsta
cookiemonsta's Avatar
Australia, ACT, Canberra
Joined Mar 2011
oh wow... oh wow.... love that shape...
cookiemonsta is offline Find More Posts by cookiemonsta
Old Mar 29, 2011, 10:39 PM
Joined Feb 2009
Our local laser company is working on a 48 inch square machine. I can hardly wait for it to be up and running. I have visions of quarter scale Ditchburn Vikings and Minettes. Maybe with a Baby Boot thrown in for good measure. What are you planning to power Swallow with? About 41 inches I think you said?
Old Mar 30, 2011, 05:09 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Well..good question.
Im planning to use brushed Speed 600 with 35mm propeller.There's a 500mm shaft with about 300mm housing to provide low angle of thrust.
That will be temporarily set to make trials on water..
Later on i will replace the motor with marine brushless.
Mariusz
Old Mar 30, 2011, 04:14 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Small update
Everything fits without any problems so far..
Mariusz
Old Mar 31, 2011, 11:04 AM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
This is looking great and it's moving right along. Good build. pete
Old Mar 31, 2011, 11:21 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Thanks Pete
Old Mar 31, 2011, 12:42 PM
Joined Feb 2009
Is that a composition keel I see?
Old Mar 31, 2011, 01:13 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Yes, that's obeche/wallnut/obeche..
I need advice guys..
I should make first planking with obeche or balsa?..
Previously I was thinking about making one planking directly with mahogany..
But it will be better to make two I think..(?)
Mariusz
Old Mar 31, 2011, 02:47 PM
RGinCanada is offline
Find More Posts by RGinCanada
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Not only is the design beautiful, but you have a good eye for photography. I am thoroughly enjoying your work!
Would it be rude to ask how much laser cutting the frames cost?
RGinCanada is offline Find More Posts by RGinCanada
Old Mar 31, 2011, 02:57 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Thank you RGinCanada, I'm glad that you like it.
Laser cutting of my parts (20 stations and small bits) costs about £28 without material.
I've prepared all drawings for them, because if they would do it, they will charge you. I have no problems with this company, easy and painless..
And..my second hobby is photography..
Regards
Mariusz
Old Mar 31, 2011, 09:09 PM
Joined Feb 2009
I think double planking with 1/16 inch stock. I prefer linear inside and radial out but that is up to you. Balsa inside is easiest to fair, then soak with clear penetrating epoxy sealer but stain first to match the color of the finish planks to avoid white show through. Photography eh? What format do you prefer? I always enjoy setting up a view and waiting for just the right light. Unfortunately they finally did take my kodachrome away...
Old Apr 01, 2011, 03:02 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
I will go first for 1/16 obeche and 1/16 mahogany then.
In regards of photography, since I have 1st Pentax I began to be "Pentaxian" . I have K20D with some older and newer lenses.
My second camera is 645N medium format.
I've sent you PM with link to my works..
Mariusz
Old Apr 01, 2011, 10:45 PM
Joined Feb 2009
I am finally going to ask after giving this several days of contemplation; what are the cut outs in the transom for?
Old Apr 02, 2011, 06:04 AM
Cecil T is offline
Find More Posts by Cecil T
N.E.N.C.
Joined Oct 2010
Awesome build ! Look`n forward to the progression of it
Cecil
Cecil T is offline Find More Posts by Cecil T
Old Apr 02, 2011, 11:39 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Hello.
These are cut outs for the exhaust. I would like to cover it with some sort of heat cover.
Thank you Cecil
Old Apr 02, 2011, 12:03 PM
Gravman is online now
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Man oh man what a beauty. You have done a fantastic job.
Gravman is online now Find More Posts by Gravman
Old Apr 02, 2011, 05:03 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Thanks..
I'm planking the bottom of the boat now..will post some pic's tomorrow.
Mariusz
Old Apr 04, 2011, 03:05 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
There is a small progress in my work..
Old Apr 04, 2011, 03:14 PM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Small progress... pbthhhhp!
You are flying along!
Old Apr 04, 2011, 03:31 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
I've had busy weekend..First photo session in my life..
But i have to touch my boat every day..You know that..
Old Apr 06, 2011, 04:38 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Hello everyone.
I didn't asleep yet..
I'm not sure if I did it right by releasing the hull from the jig..
But it happened..
Bottom planking is almost ready, also the sides are partially covered.
It's starting to look like a boat now..
Mariusz
Old Apr 06, 2011, 05:22 PM
Pursuit is offline
Find More Posts by Pursuit
United States, MA, Rockland
Joined Mar 2011
that is one beautiful looking boat!!
Pursuit is offline Find More Posts by Pursuit
Old Apr 06, 2011, 11:32 PM
craig_c is online now
Find More Posts by craig_c
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
This thread added to WOODIES: Wooden Pleasure Craft Build Logs listing.
Path: RCGroups -> Boats -> Scale Boats ->"WOODIES..."
Lookin' forward to following along
craig_c is online now Find More Posts by craig_c
Latest blog entry: Ah, To be young again...
Old Apr 07, 2011, 01:21 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Thank you craig_c.
It's pleasure to be here..
Old Apr 08, 2011, 12:41 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
The rudder
I've made up the rudder. It will be more polished..later.
I found that the most difficult part of planking is transition from sides to deck..
I will back soon..
Old Apr 08, 2011, 01:07 PM
Joined Dec 2004
SZMYK- I have been studying the hulls line you have posted and the construction of the hull interior and see what I think could be a problem down the line. First I notice that you have taken the extreme rocker out the hull bottom, which is a good thing , but if you place a straight edge on the planning surface from the transom forward, I think you will notice that the keel and stem post will not be lifted clear of the water surface by much if at all.
The reason I think that this may be a problem is that a planning hull will drop its bow when it goes into a turn and with your stem post already touching the surface of the water could cause the hull to hunt or even dig in causing the boat to swap ends when in a hard turn.
The second thing I noticed is the extreme forward placement of the motor in the hull going by the where the stuffing box is entering the interior of the hull. I realize that you are trying to have a flat shaft angle for better thrust, but care must be taken to move weight of the batteries aft to get good balance of the CG on the hull. Normal balance on the hull is between one third and one half the over all length of the hull measuring from the transom. Also watch how much you tuck or roll in the chines going toward the transom from their widest point on the hull. Since it will cause suction or drag on the hull if done to extreme. You will also be loosing lift of the hull due to the decrease of bottom area.
Old Apr 08, 2011, 02:41 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Hello frankg.
I'm not specialist in designing and this is my first attempt.
What I was trying to design, is more racing runabout than pleasure boat.
I believe that you have more experience in boats than me, so maybe you have right.
I understand that this boat will not be able to make tight turns because of it's length.
Well..we will see, when I will finish and release the swallow to the water.
I know that CG must be in 1/3 of the overall length.
Before installing the equipment and first of all making the water lines, I will try to achieve the CG and compare it with the designing program.
Hopefully there will be no disaster on water..
I'm planning to make another boat in the future, so I will be in touch on this forum.
Of course I will post the movie and pictures from trials on water.
I'm sorry for misspelling.
Best Regards.
Mariusz
Old Apr 14, 2011, 02:50 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Update
Couple of pictures from dockyard:
I've just checked mahogany strips for planking ordered from CMB a week ago.This is amazing!!
They sent 53 strips instead of 80, 7 of them was 1,5mm as ordered, rest of it is 2mm!!
They're amazing..
Old Apr 14, 2011, 05:13 PM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Sorry to hear about your issues with planking from CMB. Have they offered to correct it?
Old Apr 15, 2011, 03:02 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
No, but i will send complain letter about that.
In regards of wood this company it's waste of time and money.
Old Apr 16, 2011, 10:23 PM
hazegry is online now
Find More Posts by hazegry
Joined Sep 2006
why dont you lazer the vents out of wood then use silver leafing on them you get the look of metal but the easy workability of wood just a thought. I love the lines on this thing what program did you use to draw it out? I would like to play around with this as well
hazegry is online now Find More Posts by hazegry
Old Apr 17, 2011, 07:16 AM
bboarder711 is offline
Find More Posts by bboarder711
bboarder711's Avatar
State College, Valley Forge PA, LBI NJ
Joined Jun 2008
i just drooled all over my desk thank you haha Great work I would really love to be able to draw up some plans like that and have some laser cut frames be sent in the mail.
bboarder711 is offline Find More Posts by bboarder711
Old Apr 17, 2011, 08:17 AM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
I agree. This is really a slick looking boat. I love the concave hollows which I assume are for the exhaust and the transome is very interesting. Great job . Pete
Old Apr 17, 2011, 10:19 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Thanks guys..
I've made the vent, but I'm not happy with this shape..should be more flat I think. It's just try.
Old Apr 17, 2011, 03:39 PM
MKC Syd is offline
Joined Jan 2009
The vent looks good to me. There were a lot of different shaped vents out there. The Hacker Craft vents at least the late 20's and 30's were not flat
Old Apr 28, 2011, 12:40 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
There's a little progress..:)
I have had lots of other things to do last couple of weeks, but the boat is getting better..Now I'm installing the rudder housing and hatch frames on the deck.
Old Apr 28, 2011, 12:47 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Maybe a little progres, but looks great.
GILL RC is offline Find More Posts by GILL RC
Old Apr 29, 2011, 02:02 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Thanks very much..
Old Jun 01, 2011, 08:38 PM
Apismelifera is offline
Find More Posts by Apismelifera
1/2 a bubble off
Apismelifera's Avatar
United States, NY, Schenectady
Joined Mar 2011
You haven't been posting. I hope everything is Ok.
Apismelifera is offline Find More Posts by Apismelifera
Old Jun 02, 2011, 03:40 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
I'll be back in a couple of days. I just came back from holiday..
Mariusz
Old Jun 03, 2011, 02:06 PM
Joined Feb 2009
Welcome back Mariusz! Hope the vacation went well.
Old Jun 06, 2011, 01:17 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Hello every one..
Yes, vacation went well, but I didn't rest too much
I'm doing finishing touches before the second planking with mahogany.
As is very hard to get pear wood in London, I bought mahogany strips from Model Shipyard. I must say that these are lot better than CMB and I have all 1,5mm as ordered.
I'm preparing some metal fittings before the second planking:
Did some one used UHU Contact glue for planking, or better to use cyanoacrylate?
Old Jun 20, 2011, 09:23 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Planking 2
Hello.
Shaft housing is on place glued with silicone to reduce the noise.
I've started the second planking today with mahogany strips.
Have thumbs all in cyanoacrylate
Old Jun 20, 2011, 09:26 AM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
I've been waiting for this update! Looking good!
Old Jun 20, 2011, 10:05 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
AWSOME is not a strong enough word for this magnificent boat it is Superp.
When i got to first read it in thread today the picture of the aft with beginning mahogany planking. it was a sight gods whorty.
This one sure gonna fly like a swallow.
I would wish i got a place here in Copenhagen where they did lazercuts its just stunning.
I use UHU hart for planking, and so far i have no problems.
Just one question.. Where did you get that shaft housing? It would look awsome on my Riva. as the one delivered in the kit were only worthy for a display boat. So i am going to get me 2 like your's.
THANKS for making this build log. I LOVE IT...
Robert
Sharky1dk is offline Find More Posts by Sharky1dk
Old Jun 20, 2011, 03:51 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
When i got to first unread in thread today the picture of the aft with beginning mahogany planking. it was a sight gods whorty.
Robert
Hello Robert.
Thank you for kind words. Hopefully it will "fly like a Swalow"..Have lots of work to do with my beauty.
I have shaft with housing from Model Dockyard, but manufacturer is "Caldercraft" that's their standard shaft.
Best Wishes
Mariusz
Old Jun 20, 2011, 04:35 PM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Ooh not the outer shaft... sorry i meant the support in the aft the the...the one holding it just in front of the propeller.
Thanks Robert.
Old Jun 20, 2011, 04:38 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
I've made it myself from 2 pieces of brass plates, soldered together.
Mariusz
Old Jun 20, 2011, 04:41 PM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Like the rest of your boat, they are superp..
Robert
Old Jun 28, 2011, 12:59 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Update
I've finished the bottom planking today. Now the most difficult part for me..the sides planking and transition to the deck..
Old Jun 28, 2011, 02:34 PM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Drool..
Awsome i absolutely love this wavesplitting swallow..
Im confident that you will susceed on your planking it is looking superb...
Old Jun 28, 2011, 02:44 PM
craig_c's Avatar
Joined Apr 2007
I am in love!!! Wow!
She is going to be something spectacular!
Old Jun 29, 2011, 12:00 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Looking good.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Jun 29, 2011, 05:59 AM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
You're gonna need a bigger pond
Old Jun 29, 2011, 06:51 AM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Oh yeah..certainly.. Thanks guys for encouraging me..
That's the beginning..She should look better and better
I'm considering to paint the hull under the waterline with dark green dye..(if I will find)to expose the wood structure..Just thoughts..
Old Jun 29, 2011, 08:14 PM
craig_c's Avatar
Joined Apr 2007
Sounds like a great plan... and Lockwood dyes can give you any color of green your heart desires (you can mix the dyes... just make enough so you will have some for future touch-ups)!
(BTW, I agree, your woodwork is just way too nice to cover up under paint!!!)
From the Woodies reference list... with references to dyes, dying and Lockwood Dyes.
For example:
Water Based Concentrated Powders
Forest Green . . . .
Moss Green . . . . .
Oil Soluable (Use mixed in Turpentine)
Green Concentrate
Also check out the stains that they have specifically for Mahogany
Old Jun 30, 2011, 01:22 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Thank you Craig!
The Forest green on the left side is what I'm looking for.
I will try to look for such color in local shops, if not, I will order it from "Lockwood Dyes".I've checked the prices and will cost me about £20 so it's not so expensive.
I have already spirit dye for all mahogany parts
Old Jul 11, 2011, 12:44 PM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Anny news?
Old Jul 11, 2011, 01:03 PM
Istanbul / TURKEY
Joined Feb 2005
uh, great
Old Jul 11, 2011, 02:54 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Anny news?
I'm working quietly
Side planking is done, just slowly trying to manage the transition from sides to the deck. After that I'm gonna sand all hull.
Thinking about to use steel wool for scraping, but before I would like to make some kind of pad.
I've made the black frame for the deck as well.
The deck will be made with Paduc strips with white caulking.
Best wishes.
Mariusz
Old Jul 11, 2011, 04:02 PM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Looking good, that baby got some curves...
Old Jul 11, 2011, 04:18 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
My baby will get some curves soon..
Old Jul 11, 2011, 08:00 PM
craig_c's Avatar
Joined Apr 2007
Ahhh.. SWEET!!!!!
Old Jul 12, 2011, 09:43 PM
1/2 a bubble off
Joined Mar 2011
Very nice.
Old Jul 19, 2011, 03:10 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Now she have some curves..:)
Finally I finished bottom and side planking..Looks better than I expected.)
I'm starting the deck with red paduc stips/ white caulking.
Today I bought 24ct gold leaves for some ornaments and name on transom.
Fresh pictures below:
I hate when cyanoacrylate covering my fingertips
Old Jul 19, 2011, 03:21 PM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
OOoooooooohhhhhh!!
Old Jul 19, 2011, 03:28 PM
Joined Apr 2007
aaaahhhhhhh!!!!
Old Jul 19, 2011, 04:39 PM
craig_c's Avatar
Joined Apr 2007
Oh baby, Oh baby, Oh baby!!!!
Lookin' great, Szmyk, you are doing a great job!
Old Jul 20, 2011, 02:27 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
Thanks guys!!
Old Jul 20, 2011, 02:47 PM
tghsmith is offline
Find More Posts by tghsmith
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
your making this look way to easy! are you planning a brass or chrome cutwater trim on the stem..
tghsmith is offline Find More Posts by tghsmith
Old Jul 20, 2011, 03:27 PM
szmyk is offline
szmyk's Avatar
Joined Jun 2007
The hull will be stained with deep mahogany dye above the waterline, below will be green dye to expose the wood grains.
Cutwater and all metal works will be in polished brass.
I hope it will look good..
Old Jul 20, 2011, 04:32 PM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
You hope it will look good??
Granted... it already does.. '
As before stated it is superb....
Old Jul 20, 2011, 04:48 PM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Outstanding model. The design is beautiful and I'll bet she'll go like the wind. Very nice work. Pete
Article "Mahogany in Scale: Modeling the Classic Runabout" Book Review Michael Heer Scale Boats 2 Dec 04, 2010 11:26 AM
Sold Dumas 1940 Barrel-Back Mahogany Runabout Bob SF Boats (FS/W) 1 Nov 07, 2010 08:59 PM
For Sale Sterling kit Mahogany Runabout sweptside Boats (FS/W) 0 Oct 14, 2010 01:25 PM
Discussion Sterling Models Mahogany Runabout MILLERTIME Scale Boats 10 Feb 26, 2008 01:39 AM
Off Site Sterling Classic Dual Cockpit Mahogany Runabout MILLERTIME Boats (FS/W) 0 Oct 14, 2007 07:57 PM
