Old May 20, 2011, 12:20 AM
elecfryer is online now
Find More Posts by elecfryer
The 6 P principle works for me
elecfryer's Avatar
United States, CA, Camarillo
Joined Aug 2007
Originally Posted by vashon10 View Post
Yeah, my experience with two imbalanced packs (not skylipo) was they needed 3 or 4 cycles to get so they could remain in balance. So I agree with you after 10 cycles, sounds like the cell is bad.
I wonder how blue lipos compare to skylipos, for the 3s 5K pack size I use, they're about the same price.
I am using 25C rated Blue LiPo's 5000's, 2 5S1P packs in series for a 10S1P pack. They are in an 87" IMAC plane and at full throttle, static, they are being hit for 17C (about 85 amps) A typical flight is 8 - 10 minutes and I am recharging them at 1C - 2C. Ten cycles so far and no problems. I am very happy with their performance. I paid $50 per pack and as delivered, cells on both packs were within .02v. This is the third set of batts in this plane so far and is the best performing.
P.S. first two packs I bought in '98 set me back $400! Just based on price alone, hard to complain about the Blue LiPo's!
Michael (if your not fryin, your not tryin!)
elecfryer is online now Find More Posts by elecfryer
Old May 20, 2011, 06:15 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
I got my two SkyLipo 3s1p 2200 40c packs today. One pack was perfectly balanced at 3.77v per cell. The other was 3.77, 3.76, 3.77v. Not bad. I will start using in my heli and SkyFun.
ridge_racer is offline Find More Posts by ridge_racer
Old May 21, 2011, 04:29 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
HobbyPartz is having a sale on Batteries.
I was looking at some 25C 3S 1300mah pack last week that were $12.05.
They are $9.70.
HobbyPartz Coupons
Melnic is offline Find More Posts by Melnic
Old May 21, 2011, 07:39 PM
Joined Nov 2010
Can't go wrong with those prices considering a 40c Skylipo will cost you more and you get a better pack (presumably) over the long run. Wish they had this sale before I bought the SkyLipos...
On another note....I wish I only bought 40c packs from day one...Pitch pumps hardly bog the motor in my heli now and the pack doesn't even get warm after 8 mins of flying.
Old May 21, 2011, 08:02 PM
Raydee is offline
Find More Posts by Raydee
RC Addict
Raydee's Avatar
United States, NY, Niagara Falls
Joined Jun 2002
I ordered Four 4s5000mah 40c Hard packs for my Electric HPI Baja. My only concern is that I was told the wire Gauge is small compared to the Turnigy packs which come with 8g wire.
Raydee is offline Find More Posts by Raydee
Old May 22, 2011, 10:37 PM
100mph is offline
Find More Posts by 100mph
Our God's Alive
100mph's Avatar
United States, NE, Bennet
Joined Mar 2011
I have a 2200 mah 40C 3 cell sky lipo and I run it at 50 amps almost constant and it takes in 2150 mah and all the cells balance except one is .02 volts off. It has about 8 cycles
100mph is offline Find More Posts by 100mph
Old May 22, 2011, 10:40 PM
jonnyspeed is offline
Find More Posts by jonnyspeed
jonnyspeed's Avatar
North Royalton, Ohio
Joined Jan 2002
Gens Ace = 5c charge rate
jonnyspeed is offline Find More Posts by jonnyspeed
Old May 23, 2011, 09:16 AM
100mph is offline
Our God's Alive
100mph's Avatar
Joined Mar 2011
When I charge my 450 mah 3 cell 25C Gens Ace at 5C it doesn't take in as much mahs
Old May 23, 2011, 11:33 AM
EricJ320 is offline
Find More Posts by EricJ320
EricJ320's Avatar
Knoxville, TN
Joined Dec 2005
It's likely because the way your charger calculates cutoff. On my charger it will cutoff when the amperage in the CV phase reaches 1/5th the amount the user sets for the charge rate. On 5C charges you are setting a much higher rate than 1C, and the voltage rise is higher, so those two combined lead to a cell that doesn't get as packed completely full of mah. After it cuts out you could turn the rate down and have it top them off if you are really concerned with having a 100% charge pack. But, many would argue that the roughly 95% charge you will get from 5C is much easier on the pack and will lead to longer life and more cycles.
EricJ320 is offline Find More Posts by EricJ320
Old May 23, 2011, 11:46 AM
100mph is offline
Our God's Alive
100mph's Avatar
Joined Mar 2011
Thanks.
Old May 23, 2011, 03:21 PM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
The sale price got me to jump on two of the 3S 450mah 25C that I need for some small planes. I hope these small packs perform as well (equivalent to 40C) as its bigger cousins that has undergone testing. Would be nice if I can use 1 for the small planes and parallel them for slightly bigger planes.
dude_109 is offline Find More Posts by dude_109
Old May 23, 2011, 03:57 PM
EricJ320 is offline
EricJ320's Avatar
Knoxville, TN
Joined Dec 2005
I'm using Gens Ace 2S 450 25C's in a LF Yak 55 and they perform great. More amps and higher voltage than the Hyperion G3's they replaced. I think you will be more than happy with them.
Old May 24, 2011, 06:34 PM
EricJ320 is offline
EricJ320's Avatar
Knoxville, TN
Joined Dec 2005
Originally Posted by ridge_racer View Post
Hummm...that is a fair amount of imbalance. Have you checked the IR of the weak cell again.? I have 2 smaller 2s1p 800mah packs for my Uflys that are 30c and they never are more than .01v difference per cell even after 2 weeks on storage charge.
Just rechecked this Sky pack after sitting for several days, and checked the IR's again. This time cell #1 was roughly .18v lower than cells #2 and #3, which were equally balanced. Oddly enough, all three cells showed an IR of 4, and a pack total of 12. So, cell #1 and #2 have remained unchanged, while cell #3 came down a bit since the pack was new.
Old May 24, 2011, 10:24 PM
alexf1852 is offline
Find More Posts by alexf1852
alexf1852's Avatar
United States, FL, Inverness
Joined Jan 2010
Maybe that cell's package has ruptured?
I had two Hyperion 6S lipos that had a slow leaking cell. Those cell's voltages got lower than the others pretty quick.
alexf1852 is offline Find More Posts by alexf1852
Discussion THUNDER POWER vs GENS ACE vs BLUE LIPO vs SKY LIPO hobbypartz Batteries and Chargers 23 Oct 11, 2011 07:00 PM
Discussion Sky Lipo vs Gens Ace DannyT Batteries and Chargers 11 Sep 20, 2011 08:33 PM
Discussion Blue LiPo vs Sky LiPo vs Gens Ace vs Thunder Power hobbypartz Vendor Talk 3 Dec 20, 2010 08:03 PM
Discussion THUNDER POWER LIPO versus GENS ACE LIPO vs BLUE LIPO hobbypartz HobbyPartz.com 2 Dec 13, 2010 09:48 PM
Sold Gens Ace 3s-2200mAh 25C rsasaki Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 10, 2010 03:26 PM
