Gens Ace 3S 1550 25C vs. Sky Lipo 3S 1600 40C
Let me start by saying this certainly won't be as comprehensive, nor as scientific as many of the other more experienced tester's threads. Rather, this is meant to be a general idea of what kind of real world results you could expect to see with these two packs.
I have several Gens Ace packs ranging from 2S 450's up to 4S 2500's, all 25C, and all are performing extremely well. I needed something in this 3S 1600mah size for a profile jet. Knowing the performance of Gens Ace, and having heard some talk about the Sky packs, I thought I would order both to do a comparison. Seeing that most people who have tested Gens Ace packs have found them to be more in line with other brand's 30C-45C packs, I decided to compare the Gens Ace 25C to the Sky 40C. Both packs were purchased at the same time from Hobbypartz.com, both roughly $13 and some change, and both have exactly the same number of cycles. The Gens Ace came perfectly balanced at 3.83v per cell. The Sky Lipo came with a slight imbalance, 3.77v 3.82v 3.83v. I independently charged cell 1 up to the rest, and then completed a full charge on the whole pack. Since then the pack has remained well balanced. The Gens Ace weighs 138g while the Sky is only slightly heavier at 144g. The two packs are similar in construction, well assembled, appropriate size wiring for this size pack, flexible silicone wiring on both the main leads and balance leads. The Gens Ace pack is noticeably shorter in length, although a touch thicker than the Sky pack. They both came with the typical red 4mm bullet connectors, but I changed them out to Ultra type connectors. The IR's were nearly identical for the two packs, measured using my iCharger 208B at 70* F, packs fully charged, Gens Ace 4 5 5=14 and the Sky was 4 4 5=13. I did roughly 3 low C discharge cycles followed by 2C charges prior to the following 10C and 20C discharges below. The 10C discharge I did down to 10% capacity remaining, the 20C discharge I stopped it at 20% remaining capacity. As you'll see in the graphs, they both performed nearly identical in both test, and both did very well in my opinion. Considering that the Gens Ace is 25C and the Sky Lipo is 40C, I'd have to give the win to Gens Ace, but I'd feel comfortable recommending either pack, although I would personally not choose to buy a Sky pack that is less than 40C. Looking at some of the other graphs in the Battery Graph Vault, I'd concur with what most of the other test packs have shown, that Gens Ace 25C packs are conservatively rated, or maybe more accurately rated, and perform as well as most other brands 30C+ rated packs. It's also nice to see that the Sky Lipo packs are showing promise, at least in the high C rated packs. How they both hold up over time remains to be seen. Gens Ace http://www.hobbypartz.com/98p-25c-1550-3s1p.html Sky Lipo http://www.hobbypartz.com/77p-sl1600-3s1p-40c-3333.html |
Gens Ace could easy carry the label 40C
Or.... Are all other brands overrated and does Gens Ace have the first real C rated packs??? See also here, where they are compared to other brands as well: http://www.rcgroups.com/forums/showthread.php?t=1352332 |
vs. Sky Lipo 3S 1600 40C is rated until the point of explosion. but they perform about equally. |
I'm not ready to make a conclusion on the Sky Lipo brand based on this one pack, it could be just that, this one pack is a bad apple. I will pay attention though, and see if others do well with their packs, or if Sky possibly has some quality control issues if others have similar issues. |
I have several 6S 3000 to 3300 mah 30C lipos with balance of within 0.03V always after discharge. I don't parallel charge. |
The fact that this pack, and this specific cell came with a fair amount of imbalance is the real issue. I was able to balance it by charging that one cell as a 1S to match the others. And now, after only 10 or so cycles, if that, it's showing the same amount of imbalance even after it's been balanced. I think it's just a bad cell, it still works, and seems to put out power still, but for how long is the question. I'd say it will eventually fail before the other cells do, but how long that is, and how many cycles is anyone's guess. |
Renton, WA
Joined Nov 2006
Yeah, my experience with two imbalanced packs (not skylipo) was they needed 3 or 4 cycles to get so they could remain in balance. So I agree with you after 10 cycles, sounds like the cell is bad.
I wonder how blue lipos compare to skylipos, for the 3s 5K pack size I use, they're about the same price. |
| Thread Tools | |
| Discussion THUNDER POWER vs GENS ACE vs BLUE LIPO vs SKY LIPO | hobbypartz | Batteries and Chargers | 23 | Oct 11, 2011 06:00 PM |
| Discussion Sky Lipo vs Gens Ace | DannyT | Batteries and Chargers | 11 | Sep 20, 2011 07:33 PM |
| Discussion Blue LiPo vs Sky LiPo vs Gens Ace vs Thunder Power | hobbypartz | Vendor Talk | 3 | Dec 20, 2010 07:03 PM |
| Discussion THUNDER POWER LIPO versus GENS ACE LIPO vs BLUE LIPO | hobbypartz | HobbyPartz.com | 2 | Dec 13, 2010 08:48 PM |
| Sold Gens Ace 3s-2200mAh 25C | rsasaki | Aircraft - Electric - Batteries & Chargers (FS/W) | 3 | Oct 10, 2010 02:26 PM |
