Old Mar 15, 2011, 03:15 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
reversing an ESC
Is it possible to reverse the "direction" of an ESC ? I would like to use 2 models on the same transmitter without fiddling with reversing the throttle channel. But they require opposite stick settings for low throttle ie one needs long pulses for low throttle the other one needs short ?
Regards
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Mar 15, 2011, 03:38 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Thats very unusual, Futaba Tx have reverse pulse from everybody else but I had the impression that all esc had the same signal protocol! Maybe you could use an electronic servo reverser between the Rx and esc.
http://www.emsjomar.com/SearchResult.aspx?CategoryID=6
coriolan is online now Find More Posts by coriolan
Old Mar 15, 2011, 03:51 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
It is easy with brushless ESC. Just switch any two wires and rotation can be reversed.
Wtih brush ESC, switch wires at the motor terminals.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Mar 15, 2011, 03:55 PM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
He doesn't want to reverse the prop direction. Like coriolan, I've never seen an ESC that has a "Futaba-style" throttle. But if, so, maybe that ESC has a reversing option. Perhaps it is that way because a reversing option was already selected accidentally.
Dave H. is offline Find More Posts by Dave H.
Old Mar 15, 2011, 10:27 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
There are a few ESCs that require "Futaba direction" input. Nothing you can do about it other than get another ESC.
Don't confuse this with reversing the direction of rotation, which, as notes above, is easy.
Daedalus66 is offline Find More Posts by Daedalus66
Discussion Is there a way to test an engine without an ESC? TheNiceGuy Power Systems 7 Feb 23, 2011 03:17 PM
Question Hurricane 30 amp esc reversing motor Thermalin Electric Plane Talk 2 Dec 19, 2010 08:15 AM
Help - Reversing an Astro 60 DavidMC Power Systems 3 Nov 28, 2003 09:40 PM
Reversing an Astro 020 motor tenover Electric Plane Talk 10 Jun 26, 2003 10:19 PM
"un-reversing" an astro dottney Electric Plane Talk 1 Oct 19, 2002 06:09 PM
