This thread is privately moderated by myrcmart, who may elect to delete unwanted replies.
Old Mar 14, 2011, 12:40 PM
myrcmart is offline
Find More Posts by myrcmart
Joined May 2009
New Product
RC Lost Model Alarm (Finder/Tracker) for Plane/Glider/Helicopter
Features
* With this device, you can locate or find your lost plane/helicopter easily
* Within the effective range for that tracker can over 50M
* Simply turn off your TX, the tracer will start to scream ( just like the engines sound from the real airplane)
* Follow the lead and you can find your beloved plane
http://www.myrcmart.com/rc-lost-mode...er-p-3145.html...]...
Specification
* Weight: app. 4.7g
* Operating Voltage : 4-6 volts DC
* Low Current consumption : < 35 mA (1 mA at standby mode)
* Alert Level : 85dB
* Can be heard in 50 meter distance
* Suitable Controller: AM/FM PPM, FM/PCM
Operation
* Connect the lost alarm between the servo (the one which runs when flying) and the receiver, i.e. act as a servo extension cord
* Turn on your transmitter
* Turn on your receiver then you will hear two beep sound
* To test if it is functioning:
o Do not move any of the control stick on the transmitter for 1 min. or simply turn it off
o You will hear a continuous beep sound after 1 minute
* If you cannot find you plane, do not move the control stick or turn off your transmitter for 1 min for the alarm sound
* By the tracking sound, you will be able to locate your RC plane / Helicopter
myrcmart is offline Find More Posts by myrcmart
Old Apr 04, 2011, 11:32 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
I am a bit confused. Your information above says it only works with FM/PCM systems which I presume are on 72 MHz
However in the video you demonstrate this with a Futaba radio that looks like it has a 2.4 GHz antenna.
Does this work with 2.4 GHz systems?
aeajr is offline Find More Posts by aeajr
Old Apr 04, 2011, 12:48 PM
rcxHobby is offline
Find More Posts by rcxHobby
rcxHobby.com
Joined Nov 2010
We tried it on both 2.4Ghz and FM systems, both worked. Factory changes the specification from time to time without notice.
rcxHobby is offline Find More Posts by rcxHobby
Discussion No More Lost Planes!!!! GPS Tracker Plane Finder Locator rc_ron Electric Plane Talk 73 Jul 27, 2015 10:28 PM
Discussion Real-Time GSM/GPRS Plane Tracking or lost plane finder. for 59$ ganapati08 FPV Aircraft 12 Nov 05, 2010 10:21 AM
Idea Lost plane finder for the Radian cbusse1 Electric Sailplanes 8 Aug 26, 2009 02:57 PM
New Product 3A~5A electronic switchjack with lost model alarm and low voltage alarm (4 & 5 cell) Inflexo Slope 0 Aug 15, 2009 09:55 PM
