This thread is privately moderated by flyhigh300, who may elect to delete unwanted replies.
Old Mar 14, 2011, 11:07 AM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
New Flight Board for Multi Rotor Craft
Hello all,
It has been a wild ride since I got interested in multi rotor.
From the get go .. I was interested in a board that used the following sensor array, and was compact.
WM+, or ITC-3200
ADXL345
BMP085
and.. BOB-08745 (for 3 volt setup)
Well after much waiting.. and waiting and waiting.. and more waiting here it is.
Well here is my own self review,
PROS
1. Its my own board so you know I have to love it.
2. It allows for many configuration.
3. In addition to (ITC-3200,ADXL345,BMP085,BOB-08745)
You can still use the standard ( WM+, NK or BMP020)
4. There is a pad marked ( 3v-****)
This is just an additional 3v pad that I added for any other 3v sensors that come up for future development and testing.
5. Compact Size ( You can mount sensor above or below )
Original Idea was to mount - ITC3200 below and ADMXL345 above.
6. I pulled out all the unused pins for any future development,
  • Pins - D8
  • Pins - A0
  • Pins - A1
  • Pins - A2
  • Pins - A3
COSN
1. Mount hole pattern ( sorry guy )
this was before I learned there was a "standard" 45mm hole pattern
2. bottom left mounting hole is very close to a trace you will have to use small bolt to not damage it.
TESTING
I have already tested with the standard.. WM+ setup that many people are running.. and tested with BMP020 - that works as normal.
I'm going to be offering these up for free to any one who want to test with - 3V sensor. I only have small qty - 10 to give out.
PM me for details.
Here are the takes so far...
Please send me your shipping address & email
As long as USPS will ship to you then we should be fine.
this will ship out in plain envelope.
KeesvR - 1
jim80 -1
itod -1
zirt57 -1
yawstick -1
Faronas - 1
witespy - 1
Quad_Addict - 1
Hamanu - 1
onlyifamppowered - 1
0 left
flyhigh300 is offline Find More Posts by flyhigh300
Old Mar 14, 2011, 11:22 AM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, NH, Amsterdam
Joined Jul 2010
Great for if you want to upgrade overtime
Just had some flight with it, great!.
What I like about the board is that you can start with a WM+ / NC and add sensors to your need so almost any combination is possible for any budget.
The quality of the PCB is great, the holes are large enough to use the pin headers.
Overtime a have a bunch of sensors that came very handy now, I even will drop in a magneto now because the 2nd version (73) of 1.7Pre it is supported.
Great job
http://www.youtube.com/watch?v=VYE7IM_H53E
//Frank
Frank.T is offline Find More Posts by Frank.T
Old Mar 14, 2011, 11:36 AM
mike2663 is offline
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Impressive........
mike2663 is offline Find More Posts by mike2663
Old Mar 14, 2011, 04:20 PM
itod is offline
Find More Posts by itod
Joined Sep 2010
Very nice, I like the LLC included in the design (finally).
itod is offline Find More Posts by itod
Old Mar 14, 2011, 10:16 PM
onlyifamppowered is offline
Find More Posts by onlyifamppowered
onlyifamppowered's Avatar
brisbane
Joined Jul 2005
Trial board
HI
I am only a newbi to wii but am keen to try.
I have a tri and a tee copter and fly fairly well, but am very new to Wii
I am in Australia so postage will be a little hassle but I am keen to help
Rob
onlyifamppowered is offline Find More Posts by onlyifamppowered
Old Mar 15, 2011, 06:14 PM
yawstick is offline
Find More Posts by yawstick
yawstick's Avatar
United States, SC, Spartanburg
Joined Feb 2011
Talk about being in the right place at the right time... I'm on the list for one of these boards... only found the MultiWii site a few days ago.
Currently have a homebuilt quad with a kkcontroller.
Frank is that the motion plus board on the back of your board in the pic?
Is it possible to use only the motion plus board for quad control?
I think I'm correct in thinking that is the part with the gyros?
I'm thinking of just using that to start if possible and though its a bit pricey going with Sparkfuns's ITG3200/ADXL345 combo board sooner or later.
yawstick is offline Find More Posts by yawstick
Old Mar 16, 2011, 01:57 AM
Frank.T is offline
Frank.T's Avatar
Joined Jul 2010
Yes you can fly a Quad with only the WM+.
On one Pic there is a WM+ which was removed when I put on the ITC-3200 gyro.
You can make any combination the only sensor that is always needed is a gyro, so a WM+ or a ITC-3200.
Example: Only WM+ or WM+ with Magneto, WM+ with Baro, etc...
Only ITC-3200 or ITC-3200 with Mageneto, etc.. you get the picture
//Frank
Discussion Single Rotor vs. Multi-rotor Mike Routen Aerial Photography 9 Mar 25, 2013 11:05 AM
Discussion New to Multi-rotor copters. JasperVan Multirotor Talk 0 Jan 20, 2011 11:38 AM
Discussion Droid and iPhone Apps for Multi Rotor Helis nicnaimless Multirotor Talk 6 Oct 29, 2010 08:17 PM
Discussion Multi-rotor autonomous stunt craft Smokytyrz Multirotor Talk 6 Jun 03, 2010 09:32 PM
Discussion What is the best platform for building a tiny multi-rotor craft? Smokytyrz Multirotor Talk 2 May 12, 2010 04:36 PM
