Old Mar 13, 2011, 06:22 PM
madmax14 is offline
Find More Posts by madmax14
Joined Jan 2011
Help!
Use only one channel for dual ailerons with a 6 ch receiver?
Hi,
I am new to this. Is it possible to use only one channel on a 6 channel receiver with a Y extension to control both aileron servos?
I've tried channel mixing on my transmitter, but it doesn't seem to work. None of the servos are responding.
Here is my equipement: The plane is an AXN Floater Jet and my transmitter is a DX6i.
I've ordered servo extensions to connect both aileron servos separately, but I would like to use my plane right now.
Any help appreciated
Max
madmax14 is offline Find More Posts by madmax14
Old Mar 13, 2011, 07:25 PM
freechip is online now
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
If you want to use Dual aileron servo with the DX6i you MUST enable DUAL AILERON WING type. This will enable the AUX1 channel to be used for ailerons and it will be reffered to as FLAP in the DX6i servo menus.
Yes you can use a simple Y harness BUT you will need to make every adjustments MECHANICALY
freechip is online now Find More Posts by freechip
Old Mar 13, 2011, 08:24 PM
madmax14 is offline
Joined Jan 2011
Thanks for the answer. I've made all the trimming directly on the servo rods and everything worked fine. I've also made a test flight and it flew well.
Thanks again for your help
Sold 72 MHZ FUTABA FP R138DP DUAL CONVERSION 8 CHANNEL PCM1024 RECEIVER with Bat/Crystal Postalflyer Aircraft - General - Radio Equipment (FS/W) 1 Jan 10, 2011 03:31 PM
Discussion EFLH1036 equivatent with 6-Channel Micro Receiver FM 72MHZ/Neg Shift pvgoutham Electric Heli Talk 2 Sep 22, 2010 06:23 AM
Off Site Futaba 6 Ch Radio with Receiver for RC Airplane CH#48 jodini Aircraft - General - Radio Equipment (FS/W) 0 Jan 16, 2009 04:35 PM
Use 6 channel transmitter with 4 ch rcvr? durrence Power Systems 2 May 05, 2002 09:28 AM
