Old Aug 08, 2003, 06:14 PM
eaglesoar777 is offline
Find More Posts by eaglesoar777
Joined Jun 2003
Help! Need info on gearbox/pinion, etc. to use on MH Razor attached to Mini IFO....
Help.....
Addicted Mini IFO flyer seeking to fly higher with the Razor Micro Heli. Not sure what type of gearbox, pinion, etc. to use.
Hurry, I am experiencing serious withdrawal symthoms....
AHHHHHHHHHHHHHHHHHHHHHH!!!!
The GWS A Motor just isn't giving me the Thrill anymore....
AHHHHHHHHHHHHHHHHHHHHH!!!
Help!
Desperatly yours,
Fredrick
eaglesoar777 is offline Find More Posts by eaglesoar777
Old Aug 08, 2003, 06:59 PM
mbcone is offline
Find More Posts by mbcone
Albuquerque Intl, New Mexico, United States
Joined Jun 2003
Look in Power Systems. MKH has a few postings on this setup, his may be a full-sized IFO, not sure. Also, there is a custom aluminum gearbox you might want to check into if you fly your IFO like I do.
Here is a thread on the gearbox:
http://rcgroups.com/forums/showthrea...hreadid=119124
Here is a thread where the Razor MH in an IFO is being discussed:
http://rcgroups.com/forums/showthrea...12#post1188312
Brian
mbcone is offline Find More Posts by mbcone
Old Aug 08, 2003, 07:28 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Fredrick,
Welcome to the Ezone. It looked like you were having trouble with starting new threads. I deleted the your other two threads as they had identical information. Follow Brian's links to the Power Systems forumn as there is a lot of Razor information there.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
HELP Need Info on Graupner ME108 Taifun Knoxie Scale Fuel Planes 6 May 26, 2004 04:36 AM
Help!! Need Info on paint matching Solite! boomerace Electric Plane Talk 3 Oct 01, 2003 04:14 AM
Need info on an Ikarus pack! Please help! doc-e Batteries and Chargers 0 Aug 09, 2003 07:41 PM
HELP: Need info on building hot wire foam cutter Chic The Builders Workshop 4 Jan 11, 2003 11:13 AM
Help with info on NiMH flight pack hmpecker Electric Plane Talk 2 Oct 01, 2001 04:37 PM
