Old Mar 13, 2011, 02:34 PM
speedemo is offline
Find More Posts by speedemo
speedemo's Avatar
Munich, Germany
Joined Jun 2009
Chimera: 10" All balsa Delta, brushed 8.5mm motor, 30mm fan
Just a few pics of my latest project. Its still a work in progress but the maiden went well today so I had to post
After my MiG-15 with JS components I was looking for something with a bit more performance, so decided to try the 8.5mm Mustang motor. With the JS fan and Mustang motor I only measured a marginal increase of 12g thrust@1.1A so that wasn't the solution. I scouted around in my junk for something suitable and found a scrapped silverlit Gyrotor. Cut the 3-blade tail rotor down to 30mm and popped it on the Mustang motor. 18g@1.4A
I felt like building something "traditional" out of balsa for a change. I calculated by using 1mm balsa I would only be adding 1 or 2 grams max. I could also save 1g by glueing the motor straight into the airframe and leaving the plastic fan mount away.
I decided to do a tailless delta because then I could use the mixes of my DX6i It ended up as a sort of cross between a Fairey Delta 2 and Mirage III ( hence the name)
While building I realised the C of G is way too far forward but decided to give it a go anyway. Trimmed in loads of up and she flew great from the start The trim needs to be sorted, either weight backwards or wing forward or canards...
Specs:
Rx: AR6400
Motor: 8.5mm Mustang
Battery: 70mAh Hyperion
Fan: Gyrotor Tail 30mm
Span: 260mm
Weight: 22.8g
Thrust: 16g
Cheers
speedemo
speedemo is offline Find More Posts by speedemo
Old Mar 13, 2011, 03:19 PM
stegla is offline
Find More Posts by stegla
stegla's Avatar
Guernsey
Joined Jan 2002
Nice design................good build.......... I like this one!
Steve
stegla is offline Find More Posts by stegla
Old Apr 06, 2011, 01:25 PM
speedemo is offline
speedemo's Avatar
Munich, Germany
Joined Jun 2009
Got the trim sorted out with small wing extensions and canards. In the air it now reminds me of a Eurofighter...
Performance is definitely a lot better than my similiar sized Mig-15, speed at half-throttle is about the same as the Mig at full throttle. Ailerons are also a bit more fun than rudder The next upgrade might be to a slightly bigger lipo, the 70mAh cell is being pushed a bit@1,4A.
Old Apr 25, 2011, 10:30 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
awesome
any vids?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Apr 26, 2011, 01:08 PM
speedemo is offline
speedemo's Avatar
Munich, Germany
Joined Jun 2009
Are you psychic? Shot some vids yesterday and will post them as soon as I've edited/compressed them.
cheers
speedemo
Posted a vid in the vid gallery...
http://www.rcgroups.com/forums/showthread.php?t=1430318
Old Apr 26, 2011, 06:30 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
sweet
looks like it flies well and pretty quick too
very nice!
cheers
speedemo
Old Apr 26, 2011, 06:35 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Good job. Looks great and moves along nicely.
Joe 1320 is offline Find More Posts by Joe 1320
Old Apr 29, 2011, 04:29 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
very nice, and great wood working as well
derk is offline Find More Posts by derk
Sold E-flite Delta V15 fan and motor remote pilot Aircraft - Electric - Power Systems (FS/W) 2 Jan 08, 2011 06:05 PM
Sold E-Flight BL 15 Ducted Fan Motor, 3600kv And E-Flight Delta-V 15 Ducted Fan, 69mm RCFlyingForLife Aircraft - Electric - Power Systems (FS/W) 12 Nov 09, 2010 10:08 PM
For Sale Kyosho 75mm F16 Brushed edf fan with motor *REDUCED* splitpilot Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2010 11:16 PM
Wanted well, I bought the cc 80hv all I need now is the motor and fan sherlockshah Aircraft - Electric - Jets (FS/W) 0 Oct 02, 2010 08:50 PM
Discussion Need help, Greatplanes XPD-8 brushed motor question airbagit13 Foamy EDFs 4 Sep 26, 2010 09:53 AM
