Old Apr 18, 2012, 09:58 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
32 is WAY too light. Use it for indoor flat foamies, that's it!
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Apr 22, 2012, 09:22 AM
pach is offline
Find More Posts by pach
United States, FL, Miami
Joined Aug 2009
Spektrum GPS sensor manual is already on the webite: http://www.spektrumrc.com/ProdInfo/F...587-Manual.pdf
And I really like this one, a genuine Spektrum 4 channel full range dual diversity DSMX receiver 2048 resolution with data output for only $29.99
http://www.spektrumrc.com/Products/D...rodID=SPMAR400
pach is offline Find More Posts by pach
Old Apr 22, 2012, 10:17 AM
Left Coast DJ is online now
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
AR400 looks sweet! The price is right. And the antennae come out of the case at 90 degrees.
Left Coast DJ is online now Find More Posts by Left Coast DJ
Old Apr 22, 2012, 07:49 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Originally Posted by stgdz View Post
So I asked this in the dx8 thread.....
But how accurate is the voltage sensor on the tm1000? It concerns me because I have seen 4.3 volts on my readout for high low voltages, until last night where I saw 3.1.
The bec is 6amps at 6volts so I should have more than enough juice, but the alarm that I set to 4.8volts is not going off. Someone mentioned it in the dx8 thread that it may be dropping really fast and the alarm can't catch it.
Servos are new also
The maximum deviation I had was 0.3V with a 3S LiPo. That would be 1.2V with 12S. Depends on the telemetry module's voltage divider. Tried various TM modules, one is more accurate, one not. Not as accurate as I liked it to be. It is a shame that they are not calibrated....
Mukenukem is offline Find More Posts by Mukenukem
Old Apr 22, 2012, 08:50 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Actually, it would probably STILL be 0.3V with 12S. The error tends to be an offset error more than a slope error.
Andy
Site Sponsor
Old Apr 22, 2012, 09:04 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
How long does it take for the rpm to level out? Getting some high rpm numbers before it levels out.
stgdz is offline Find More Posts by stgdz
Old Apr 22, 2012, 11:02 PM
RCBlackSheep is offline
Find More Posts by RCBlackSheep
I'd Rather Be Flying
RCBlackSheep's Avatar
Stockton CA
Joined Feb 2009
I just got the DX8 with TM-1000 and first I have to say overall I'm happy with it and having a realtime altimeter has helped me learn some things I didnt know before with my glider. I'm kinda just starting out with gliders and the nearest glider club is an hour away. Learning has been slow even with all the info I have been finding on the web. My only hitch with the DX8 has been binding but that was before I found out that I was releasing the bind button too late. Now that I know to release it when the "binding" shows on the screen, it binds every time. I still have a few questions for which I havent seen answers yet.
1) Roller tension: I sometimes press the roller unintentionally when trying to get to different screens in the telemetry. Is there an adjustment for this?
2)Altimeter: Is there a way to get the altitude on the same screen as the Rx volts, Battery volts and Temperature? I've been able to customize some readings but havent figured out this...
3)Altimeter alarms: Is there any plans to make the DX8 make some sort of noise when there is a change in altitude? A low frequency click/beep when dropping and high frequency click/beep when rising would be enough for me. The alarm I heard today when I powered up with flaps on would WAY too annoying and setting max altimeter alarm wont serve my purpose. It would be nice to hear a positive or negitive change without having to take my old eyes off my specked out glider.
RCBlackSheep is offline Find More Posts by RCBlackSheep
Old Apr 23, 2012, 08:04 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
1) No adjustment. However, how you position your thumb makes a difference for click tension. I put my thumb up at the top for clicking.
2) No, the screens are not configurable like that. It's something I would like to have time to work on, though.
3) If you push the CLEAR button it will stop the alarm on the screen until you reset the condition from the plane, which will activate it again.
The frequency/ticking thing you are asking for is called a Vario. We announced/showed one at the Nuremberg Toy Fair in February this year. I cannot give you a ship date.
Andy
Site Sponsor
Old Apr 23, 2012, 12:55 PM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
If you opt to purchase the STi, the screens are configureable. It plugs into an iPhone/iPad and also has an audio output that you can configure to "speak" values. Actually, you can easily get into information overload, having read outs occur too often and too much. I've settled on read outs for 3 sensors, and at a 15 second interval. I didn't see an option to "Speak" or click/tone an output for Variometer, but it will probably come in an upgrade once Spektrum makes the Vario available.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Apr 23, 2012, 12:59 PM
Joined Jan 2011
stgdz,
What kind of motor, and what kind of sensor? My Hall effect sensor on both a Speed Webra .91 and the ole SuperTiger .61 read as soon as they exceed 2700RPM. The Electronic Speed Brushless sensor, never stabilized to my satisfaction. The optical sensor on the other hand, starts reading below 2000RPM and tracks down to 1700 on the two brushless motors I am using.
KKKKFL
Old Apr 23, 2012, 01:37 PM
Stockton CA
Joined Feb 2009
Andy
Thank you for your answers. When I read your answer about the Vario, I must have giggled out loud. My wife just asked me, "what are you buying now?" I'll be keeping an eye out for the next .sax file too.
Old Apr 23, 2012, 03:05 PM
Vienna, Austria
Joined Oct 2010
Seems you use a brushless sensor. Those show high rpms during spoolup (and complete crap with castle creations).
Old Apr 26, 2012, 04:41 AM
glambert is offline
Find More Posts by glambert
France, IdF, Châtenay-Malabry
Joined Aug 2010
Hello,
I had recently 2 bad experiences with TM1000. One on my T-Rex550 using AR8000 and the other on a quad multirotor using AR7000. In both case, I don't use UBEC. When the low battery alarm triggers, I was preparing to land, the ESC low-voltage was still not triggered when the RX voltage went to zero... failsafe and crash...How is this possible that with individual lipo cell not going below 3 Volts, you could have RX that is not power supplied anymore.
I initially blamed on the T-Rex integrated BEC but then I had the issue with the multicopter (there are 4 ESCs which all 4 contribute to Power the flight controller and RX). The TM modules are 2 separate one as well as RX, so it is not a faulty unit issue. One common point is in both case that was an old battery which did not have the initial C rating and did not well handle quick high throttle (decrease of the voltage). In both case the min Volt value recorded in flight was 10 Volts (3S) and 22V (4S) while the RX went to Zero!!!
Please tell me if this issue sound familiar to you and how to solve it... I don't want to go to separated BEC or Lipo to supply the RX...
Gregory
glambert is offline Find More Posts by glambert
Old Apr 26, 2012, 05:49 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
What kind of ESC besc do you have for your quad and what kind of quad that you have ALL FOUR esc/brc powering the unit. Unless specified by the manufacturer of the esc that they are design differently most esc setup when you have more then one esc YOU MUST REMOVE the bec from the other esc.
They will all be fighting each other and that is not good. The TM unit require power to work. if you are having bec problem or are running them at there limits adding the TM 1000 could caused them to overload and shut down.
You need to re-think your power systems, not wanting to add seperate bec when its recommend results in crashes most of the time.
freechip is offline Find More Posts by freechip
Old Apr 26, 2012, 07:22 AM
glambert is offline
Joined Aug 2010
I agree with you for the power of the Quad. So far I never had an issue with 4 Turnigy plush 10A, addind the TM unit may have resulted in overload. The board is a Paris Multiwii from multiwiicopter in australia. I can easily in this setup add an CC separated BEC plugged in the board and disable the power from the ESC. That is what I do in my bigger Quads and Y6... But in this case, this is a mini quad and I used the TM instead because I wanted to keep it a simple setup compared to of all the LRS RX and OSD stuff including telemetry I use on the bigger multirotors I have.
Regarding the T-Rex 550, this is the standard 70A Align ESC. I would like to use the CC BEC as well but I am not sure where to plugin the BEC as the batt port is used by the TM ?
Gregory
Discussion Telemetry Options Paul5910 Radios 18 Mar 04, 2011 08:57 AM
Alert Spektrum Telemetry TM1000 shuts down!!! freirem Radios 15 Oct 14, 2010 07:13 PM
Sold spektrum telemetry $45 shipped ff954 Cars - Accessories (FS/W) 1 Oct 03, 2010 10:25 PM
Sold Brand new Spektrum AR8000 RX & TM1000 Telemetry birdy233 Aircraft - General - Radio Equipment (FS/W) 2 Sep 30, 2010 09:44 PM
Poll Telemetry options Daemon Xtreme Power Systems 181 Jul 02, 2008 09:59 PM
